Question about Kenmore 24.8 cu. ft. Trio French Door Bottom Freezer Refrigerator
How do I troubleshoot a Sears Kenmore Elite Refrigerator Model #795.75193401 ice maker that allows water to go through the ice maker directly into the tray without freezing into cubes
dididsaythat
  • 291 Answers
SOURCE: KENMORE REFRIGERATOR
Need a model # ... mostly likey better to just replace ice maker if that old.. 12-15 if same age as ref.
Posted on Sep 07, 2007
  • 1122 Answers
SOURCE: kenmore refrigerator
THE ICEMAKER HAS TO GET BELOW 32 DEGREES TO WORK RIGHT,IS THE FREEZER GETTING DOWN TO TEMP.?LET ME KNOW-MIKE
Posted on Oct 22, 2008
tborn6
  • 700 Answers
SOURCE: ice maker problem
Good Morning,the solinoid valves are crossed in the back of the refrigerator. shut the water off and switch the tubing around that comes off of the valves
Posted on Dec 21, 2008
Bat1956
  • 585 Answers
SOURCE: I just replaced the icemaker in my Kenmore
Congratulations, you have very good water pressure. I am not aware of any adjustment for the time the fill solenoid opens. The easiest thing I can suggest is to adjust the water flow with the supply valve. If you have the typical saddle valve, it has quite a taper to the piercing needle, and you could possibly use that to reduce the water flow, thus the volume of the fill. A little trial and error will be needed to find the right number of turns for the valve to be opened. I also recommend a water filter in the line to reduce contaminants, which makes the ice taste better. The filter should be replaced every 6-months or so depending on the amount of impurities.
Posted on Feb 13, 2010
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite side-by-side ice maker creaking!
Look behind the freezer rear trim panel for frosted/iced evap. coils and thaw if necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
I have a Kenmore Elite side-by-sr ide refrigerator Model 106. The ice making system is putting too much water in the ice tray, making the cubes too big. These large cubes are clogging up the dispenser. ...
With out the full model number it is hard to say. Most 106 model referigators have a modular ice maker. If you take the cover off of the front of the ice maker and look on the right hand side of the motor module you will notice a small plastic adjustment screw. If you turn this screw you can adjust your water fill time to the ice maker.
Sep 01, 2011 | Kenmore Refrigerators
My ice maker does not make ice. my model # is 06.57362703
I am pretty sure a number 1 should come before the number you listed 106.57362703 so that is what I will go with. It appears that your Refrigerator was made by Whirlpool and sold to Sears. The first thing to check is if ice is still in the slots from the last fill. Then if not any ice remaining fill the ice slots with tap water and allow water to freeze. If the ice drops into the ice bin and the ice maker does not refill with water on its own would indicate a defective water control valve part number Click Here=> 4389177 Water Control Valve If water fills the ice tray on its own I would say that the ice maker is the problem. It is easier and less expensive to just buy the=> W10190965 Ice Maker Assembly. Let me know your results and if you have any questions I will be here to answer them for you, Thanks Sea Breeze
Kenmore Model 106.57362703 Ice Maker or Components Parts If helpful please rate this solution, Thank You
Jul 16, 2011 | Kenmore 53092 / 53094 Side by Side...
I have a Kenmore elite Model #795 7554 2501 MFg date 2005-01. The water container behind the left door is leaking I need a replacement. Can you help
in trying to locate this model # with sears data base it didn't come up. i don't know of any kenmore that has a water container behind the left door . left door being the freezer door .. the water container is located in the botttom of fresh food side in the back behind the crispers . if thers a leak in the freezer door i would think that it a water line that is carcked or come loose .. mm hope this helps .. pls reck your model # and in needed get back with me ..mm
Oct 21, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
No water coming from water dispenser.
It is possible the water control valve for that dispenser has failed and will not open. This happens a lot for those and the ice maker valves. All you need is the model number for your refrigerator and that will look like this for Kenmore. 213.564897 for example. and I will help you find the correct part number. Sea Breeze
Nov 24, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker issues - what to do next?
I have not found Kenmore to do the best with the icemakers; however, you want to make sure that the lever on the side was replaced properly. They have a slot that they need to go into. The other thing that is important is to see if the motor is running on the ice maker. It could be at fault, but if that is the case those units usually are better off replaced as a whole, which runs around $200. You will probably get them cheaper through an appliance dealor rather than going through Sears and there probably is one in your yellow page section of your phone book...hope this helps.
Oct 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Moldy Ice from Ice Maker
Hi: Does it have a water filter? Sears parts is offline at the moment, so I can't tell. Most of the newer models do. The 596.xxx tells me that it was built in the Amana factory for Kenmore. Most likely there is a water filter in the top of the fresh food compartment. It has been growing mold in storage, and the lines too. It's on the upper right side, behind a housing with a tab to release it. Lower the housing and remove the water filter. Did you receive the bypass plug with the ref.? It looks like a large plastic wing nut with the same fitting as the water filter. If so put it in and flush the system with city water. Most city water has chlorine to clean your lines. If you install a new filter without flushing the lines it will remove the chlorine as it's supposed to do, but the lines from the filter wont get clean. If you don't have the plug, buy one. Flush the system and then install the filter. I hope this helps, Jeff
Jun 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker not working properly
Make sure the fill tube going directly into the icemaker is not touching the part that receives the water, if it is touching the water will spray all over and not go into the cavity
Jan 11, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Trio Model 795.7757960 - Error Code 'IF'
Hi!!! You have a control board problem.Change the control board and you should be okay..Them boards did'nt come out good.Good luck..
Jan 04, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite refrigerator 795.775.62600
make sure the ice maker is turned on, push and hold the little round button on the front for 15 seconda and see if it starts up an cycles. Also check to make sure the fill tube isn't clogged to the ice maker and another thing to check is the water valve.
Sep 04, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
