Thermonet 5259 thermostat
I have a 5259 touch screen thermostat, I want to know how to programme it as I don't understand the different periods I expected to programme it like a heating system
5 Suggested Answers
jbjaxiis
  • 95 Answers
SOURCE: I BOUGHT TWO DIFFERENT PROGRAMMABLE
heat pumps normally have what is called a jumper wire between you R and RC, RC run cooling. You may not have the jumper installed correctly. Instead of RC you may be using RH run heat
Posted on Aug 10, 2008
  • 38 Answers
SOURCE: Carrier Infinity Control Programming Issue
Open the flap, and press and hold the advanced button for 10 sec. you will be in the Installer setup screen. scroll down to the setup subfolder and select thermostat and it will be in there.
Posted on May 07, 2009
daddyo742001
  • 70 Answers
SOURCE: Hunter 44110 programmable thermostat not turning off ac
You may and an anolog stat and the old one was digital if so it won't work. Digital sends info to system anolog is just a set of points open or closed. Digital can carry tons of info to system like a computer. Like comparing a computer to a rock. Sorry but you need to go back to proper type stat.
Posted on Jun 30, 2009
nanbuenbrazo
  • 553 Answers
SOURCE: install programmable Carrier thermostat
you'll be needing an assistance from an A/C technician, If this a progammable you want, some configuration need to be done and a technician can only do that.
You can search the web for a local carrier dealer nearest to you
Posted on Nov 05, 2009
The green backlite on my honeywell programmable thermostat is not on...have to use a flash lite to see screen....is there a lite bulb to change?
In the configuration menu, there will be a 'Backlight Display Timer" setting or somthing similar. Usually they can be turned on continuous, off or on for a timed period after the display is touched. I set them all for 30 seconds, unless it is for really old people, then I set them continuous.
Apr 13, 2015 | Heating & Cooling
How to make sure thermostat is off
The MODE button controls the On/OFF. Touch the Mode icon and watch the top right of the screen. That's where the ON/OFF will appear. If the fireplace or gas logs is ON, touch the Mode icon twice. Off will appear in the top right or the screen and the gas appliance's burner will turn OFF.
The Mode icon is also used to switch to different functions of the remote. To help you more I have included a downloadable link to your Owners Manual. You will be able to print it for future reference.
http://www.skytechsystem.com/editor/assets/installation%20files/5301P%20Instructions.pdf
Feb 20, 2011 | Skytech 5301P Fireplace Remote touch...
Dont know how to program stat rth230b
you need to press the up-down buttons until the desired temperature is displayed or, if you want to maintain the temperature by a energy-saving schedule: press mode, and then you have 4 different periods to set up the temperature for.
Mar 12, 2010 | Honeywell Electronic Programmable...
Is the display intended to be illuminated or is it to be read 'in the dark' so to speak? As it is digital, and as the model in the store appeared to be illuminated, I don't understand why I cannot view the...
You should be able to just touch the thermostat and it should lite up to see the numbers. If it does not lite up you have abad stat. Working but no display lite. But just try touching the screen if it is touch type stat or just hit the up or down bitton qucikly and see if it lites up. Please leave feedback Rus
Dec 07, 2009 | Honeywell Programmable Thermostat Heater
I'm trying to hook up a honeywell touchscreen thermostat and need to know what wires go where.
i have a vison pro th8320u and i cant get aux heat to operate also aux heat on will not come up on the touch screen.
Jan 04, 2009 | Honeywell Electronic Programmable...
Replacing aging erratic honeywell chronotherm III
Hi, your replacement part can be purchased on amazon, take a look here: Amazon com honeywell chronotherm III thermostat. I hope this was helpful. Cheers
Nov 30, 2008 | Honeywell Programmable Thermostat Heater
Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Oct 23, 2008 | Honeywell Electronic Programmable...
Thermostat
That thermostat must be used with a THM5421C1008 Equipment Interface Module. The thermostat communicates with the module and the module is connected to the HVAC components.
Feb 08, 2008 | Honeywell Electronic Programmable...
Loss of temperature control
Is the heater staying on all the time? Most likely cause of themostat trouble is the sensor. Try to find it and measure its resistance at different temps to verify the trouble.
Dec 31, 2007 | Honeywell CT3200 5-2 Day Electronic...
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
