Question about Video Game Consoles & Games
My call of duty ghost install disc won't work it keeps popping up an error saying selected storage device has been lost how do i make it work on my xbox 360
  • 85 Answers
SOURCE: storage device not found
Saving a game requires you to have a Hard drive or memory card did you purchase the premium edition xbox 360? you can look on the outside of the xbox 360 box it will give the specs and what came with the system. If the hard drive is not on the list then you will need to buy one the xbox doesn't come with any internal memory like the systems in the past have. you will need to purchase a HD or a memory card. If you have the premium edition let me know ill instruct on how to set it up.
Posted on Dec 27, 2007
SOURCE: comcast remote's ok button doesn't work with xbox 360
Sorry, the Red Button won't work, but you can map the A button on the Comcast remote instead. It's almost the same thing... Your fingers will barely know the difference.
1. Press the Aux button at the top of the remote.
2. Hold the Setup button until the Aux button flashes twice.
3. Enter 994 on the keypad. The Aux button will flash twice again.
4. Now push the Setup button once. Enter 00001.
Finally, push the A button The Aux button will flash twice. You now have the A / Select / OK / Green button mapped on the Xbox360.
--If you want to switch the A button back to default, just do the same sequence but this time push the A button twice.--
Posted on Apr 16, 2009
SOURCE: Discs won't start up when put in the Xbox 360
i had this before a few times, nt sure if it will work 4 u guys. when this happens what i done was that
i got my xbox (no disc inside it)
turned it on horizontal
made the console vertical (whilst still running)
and then back to horizontal again (whilst still running)
then turn it off
turn it on again, stick any game in and it should work. thats what i done when mine got broke. best of luck. if it doesn't work, take it Microsoft.
Posted on May 18, 2009
  • 3 Answers
SOURCE: call of duty world at war is not working on my xbox 360
Depending on when (and in what country) you bought your Xbox 360, you may just have a busted hard drive. Earlier generations are particularly difficult which is why Microsoft extended the "hardware failure" portion of the warranty.
If this is happening to multiple games you should be sure you are cleaning the discs very well with a fine linen cloth or something that will not scratch it. Remove all the debris from the disc and don't leave them in the sun or near sources of heat. Also you may want to get a can of air and spray out any dust that may be collecting inside the tray/lens inside the xbox.
If this is only happening to this one game, perhaps you have a corrupt file on the hard drive. Try deleting anything related to Call of Duty World at War from the memory and then putting the disc in.
Posted on May 27, 2009
SOURCE: xbox 360 arcade pal game read error
You will get this error when your laser is in need of replacing. The other message you will get is open tray. If your system will play regular movie dvd's but not games then replace the laser. You can find them pretty cheap on ebay.
Posted on Sep 13, 2009
My COD: Ghosts DISC2 won't install every time a pop-up appears saying "No Save Device Was Selected". What should I do I'm running it on Xbox360 with 320Gb Hard drive installed.
have you tried using a usb device ? have you tried removing the hard drive restarting your xbox and then puting the hard drive ?
Jan 31, 2016 | Video Game Consoles & Games
Call of duty ghosts on steam server
I doubt it. Directx is not usually something people scam. Chances are you have a driver that didn't install properly in the system. Go to microsoft website and re-install the direct x drivers. This should fix your problem.
Mar 26, 2014 | Computers & Internet
Call duty error
The disk might be corrupt.. so its saying that the device data has been lost.
Nov 02, 2013 | Computers & Internet
Alright my girlfriend just got an xbox and she has everything set up, but she cant connect to live because a text pops up that says that it requires an update but she said that it has said that 5 times....
The easiest way to update your console software is to connect to Xbox LIVE. To update your console by using Xbox LIVE, all you need is an Internet connection.
  1. Connect your Xbox 360 console to the Internet. To learn how, please see How to connect to Xbox LIVE.
  2. On the console, go to My Xbox, and then select System Settings.
  3. Select Network Settings.
  4. Select Wired Network or the name of your wireless network, if you are prompted to do so.
  5. Select Test Xbox LIVE Connection.
  6. Select Yes if you are prompted to update the console software.
If you receive a connection error, try using the Xbox LIVE Connect Solution.
Console update did not install successfully?
If her system says that she needs an update then likely her connection should be getting to Live. You might need to clear her cache first and then try the steps above. Here is how you will clear your cache:
To clear the system cache
  1. Go to My Xbox, and then select System Settings.
  2. Select Memory.
  3. Highlight any storage device, and then press Y on your controller.
    (It doesn't matter which storage device you select; the cache will be cleared for all storage devices.)
  4. Select Clear System Cache.
  5. When prompted to confirm storage device maintenance, select Yes:
Aug 03, 2011 | Microsoft Xbox 360 Console
Lost the disc to the webcamara.
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Feb 08, 2010 | Xtatix XCA-PP2A Webcam
I cannot find a driver for my Toshiba mass storage device.
Go to BIOS and change the USB setting to full speed and save it and continue. I am sure it will work after that....sodeep
Mar 24, 2009 | Computers & Internet
Can not format xbox 360 console
Well, just to make sure you understand, after you format your Xbox 360 Hard Drive, all your data that was on the hard drive will be lost and cannot be recovered (like Hexic HD, Gamerpics, etc...) make sure that you really would want to do this before you continue, okay?
In formatting your Xbox 360 Hard Drive, follow these steps:
1. Turn on your Xbox 360 console without any disc in the disc tray.
2. In the System section of the Xbox 360 Dashboard, select Memory to view the Storage Devices area.
3. In the Storage Devices area, select Hard Drive then press the Y button on your Xbox 360 controller or on the remote control.
4. In the Device Options area, select Format. You receive the message:
This will delete all content on this device. Do you want to continue?
5. To format your Xbox 360 Hard Drive, select Yes.
If you encounter any problem with this, I would strongly suggest that you contact phone support of xbox for the Hardware department at the following phone numbers:
Toll free: (800) 4MY-XBOX
Direct dial: (425) 635-7180
Hearing impaired (TDD device): (866) 740-9269 or (425) 635-7102
Hours of operation
Phone assistance is available seven days a week.
9:00 A.M. to 1:00 A.M. Eastern Time
6:00 A.M. to 10:00 P.M. Pacific Time
Hope this helps! :)
Mar 07, 2009 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
871 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
