Question about Sansui DTV2760 27" TV
Sansui tv i dont have the remote and apparently this is the only tv that doesnt have a menu button on the set. is this true or is there a secret that i need to know
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Please go to http://electronics.pricegrabber.com/televisions-tube/m/22194927/details/ go to the site & ask directly to the manufacture you will get positive reply. still if you have any problem please let me know. good luck.
Posted on Oct 08, 2007
I have a sansui flat with build in DVD but don't have a remote the DVD will load but when push play it says operation not possible with disk what is this do I just need a univ.remote
First, check which input you have the TV set on. There may be an Input button on the side of the TV. (On the SLEDVD197, the button just below the DVD Eject button.) Just press Input and use the Channel Up/Down arrows to navigate the menu to change to the DVD. Press Input again to Enter the selected option.
With the TV in DVD mode, try pressing Play again. If you still have the error, check the region code for the disc. The "Operation not permitted" messages is usually that something on the disc is locked. Frequently, it's the result of using a different region code disc than the DVD player knows how to interpret. Try a different DVD.
If your TV doesn't have the Input button on the TV, you absolutely need a universal remote. However, you will want one that can match the TV/DVD button, the Input/Select button and the Menu button. Usually this requires a higher end remote; you also need a remote that was programmed at least 6 months after Sansui released the TV. If you do have the Input button on the TV, a universal remote may make using the TV easier.
I hope this helps.
Apr 13, 2015 | Sansui Televison & Video
Have a sansui tvs273 tv. Need to switch it from
If your set does not have a menu button built into the set your out of luck unless you can find a replacement or universal remote.
Sep 11, 2009 | Sansui TVS203
Television picture bigger than screen (rear projection)
Aspect ratio. Should be on the remote itself. Or depending on cable or satelite provider you have (might of hit a button on that remote too) Simple fix buddy.. (it might have zoom on theremote)
Mar 11, 2009 | Televison & Video
Manual buttons on set will only accept 3 channels
found solution by holding down both volume buttons at same time which enables on-screen menu allowing to select channel auto program
Dec 07, 2008 | SansuiS3275 TV
I dont have vchip code fof my used tv
1. Hit the Menu button on the TV. 2. 'INPUT SECRET No.' should appear. 3. Press and hold both VOL (+) and CH DOWN on the TV set simultaneously until the message 'INPUT SECRET No.' disappears. 4. The vchip settings should be disabled now and the Parental controls menu should be presented, 'disable' Status if need be
Remember do it on the tv not the remote
Nov 14, 2008 | Televison & Video
New Sansui 27" and remote does not work
On later model Sansui tv's, you can bring up the menu by pushing both volume buttons on the front of the set at the same time. After the menu is on the screen, you can navigate using the channel and volume buttons.
Nov 01, 2008 | Sansui TVM1916 19" TV
Black box on screen
go into menu find
cc settings and
change setting to off
(make note of the one thats
causing the problem)
Dec 02, 2007 | Sansui DTV2760 27" TV
1999 sansui tvm1915 tv
You'll most likely need a Sansui remote made to work with your specific model TV. I have similar problems with my Toshiba TV. Check eBay.
Nov 10, 2007 | SansuiM1315 TV
Smartlock code
1.Press MENU to show the on-screen menu. 2. Press VOL+ or VOL- to highlight SET. 3. Press CH+ or CH- to highlight PARENTAL CONTROL. 4. Press VOL+ or VOL- to display the SECRET CODE screen. 5. Press VOL+ (on the remote) and the CH+ button on the front of the TV at the same time. 6. Press the Number buttons to enter a four-digit code. The code will appear on the screen as you enter it. The code "0000" is the default of the TV. If you have not set up a code previously,then "0000" is the code.You cannot use "0000" after you set your own code (unless you reset the code to "0000"). 7. Press MENU to save the code.
Oct 10, 2007 | Philips Magnavox 27MS343S 27" TV
Sansui DTV2760 27" TV Logo
61 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
