Staples SPL-TXC152A paper stuck & powered off
Paper got stuck how do i remove. wont power on now.
SOURCE: Staples SPL-1506X
Well, despite the manufacters warning label I choose to take the shredder apart and found that one of the plastic gears was broken. Hence the motor runs, but the blades do not turn. The thing I didn't understand, the there are metal gears and plasic gears...I can only imagine that the plastic gears at one point or another are going to give. I would suggest not to void the manufacters warrenty, take the shredder back, and get one that is built a little stronger. Hope that helps.
Posted on Aug 12, 2008
SOURCE: staples spl-710sh paper shredder stopped shredding
This exact thing has happened to my unit as well. Ive disassembled it to discover that 5-7 teeth on the gear that the motor drives have been stripped off. Unless the gear can be replaced (which is probably not worth the expense), then the unit is toast. Sorry. Good luck.
Posted on Nov 01, 2009
SOURCE: staples SPL-770M shredder with overheat light even when cool
Just a FYI: I had the same problem. Nothing appeared jammed. But I took the housing cover off and low and behold the rubber roller that turns the shredders had MELTED to the inside. That's why it wouldn't work. This happened while shredding a single DVD - something I had done effortlessly on numerous occasions. You may want to check to see if the roller melted or if some debris has jammed up inside the unit, like mine did often.
Posted on Jan 08, 2010
SOURCE: Drive gear for staples shredder Model# SPL-770M is worn
is it the drive gear or is it that the shreader is dull that makes the shreader sluggish?
Posted on Jun 23, 2010
SOURCE: Runs continuous when turned on, but stops when paper is inserted
I owe this to a Steve-EE.
Mine was the LED where the paper feeds. $1.69 for a 2 pack.
http://www.radioshack.com/product/index.jsp?productId=3107633
Posted on Jul 04, 2010
How do I reset to just basic adding
Dont know what you are saying.
Basically turn it off and on if your stuck.
Jan 05, 2016 | Staples SPL-250 10-Digit Display...
How do I fix a staples spl tmc 10 paper shredder that does not feed?
It may be clogged with shredded paper. With power removed, examine the shredding mechanism and remove any bits you find. You may not be able to remove all of the bits but enough to restore operation.
Oct 09, 2014 | Office Equipment & Supplies
Staple Model SPL-XC200D Paper Shredder, During the
Fixya does not sell parts and cannot identify sources.
Jul 18, 2017 | Staples SPLXC200D Shredder
STAPLES TITANIUM CUTTER (SPL-TMC16A) CONTINUES TO RUN WITHOUT STOPPING AFTER PAPER HAS BEEN SHRED. THE FORWARD LIGHT FLASHES.
can't solve the problem, but wonder if I could get an owners manual for this same model (SPL-TMC16A)
Dec 16, 2010 | Office Equipment & Supplies
Each time I use my staples SPL-616X shredder all the paper gets stuck around the blades what can I do? Do I need to put some oil on the blades?
Yes you do need to oil the blades, but it is important to get the right oil. Most stores that sell shredders, like Staples Office Supply, also sell shredder oil. J.
Aug 01, 2010 | Staples SPL616X Cross-Cut Shredder
829 people viewed this question
jasbo
jasbo
