Question about Air Tools & Compressors
CONTROL MODUL FOR FURNACE MUFFLE 47900 THERMOLYNE
Model : F47920-26 ( CNX 146 ) Serial No : 749950810634 Amps : 4.0 Volt : 230 Watts : 920 Phase : 1
3 Suggested Answers
  • 313 Answers
SOURCE: too change rotation of a 5hp 230 volt
HAVE A LOOK INSIDE THE MOTOR CONNECTION BOX. SOMETIMES ON THE LID ARE INSTRUCTIONS OF HOW TO DO THIS. YOU DID NOT SAY IF THIS WAS A CAPACITOR START UNIT OR NOT. IF THERE IS A CAPACITOR ON THERE IT COULD BE NO GOOD WHICH WILL MAKE THE MOTOR GO WHERE IT WANTS. A GOOD CAPACITOR KICKS IT IN THE RIGHT DIRECTION ON SWITCH ON.
Posted on Jul 25, 2010
  • 214 Answers
SOURCE: how to wire a t30
yes white and black are both line voltage in.each wire will have 110 to 120 volts. Attach one wire to top of starter contactor left side the other to top of starter contactor right side. Attach green wire to ground.
Posted on Jun 03, 2011
Keeps blowing internal breaker
The unit rated at 3 HP at 115 volts draws 13.8 amps is odd, a HP in watts is 745 and should be about 2200 watts and 19 amps plus a efficiency loss. Odd to see the ratings don't jive with electric theory/formulas.
The compressor should be connected directly to the wall and if using an extension cord, the cord needs to be #12 AWG or larger to avoid line voltage loss and over amping of the motor.
Here is contact and support info: For more information, please call 800/4-MAKITA (800/462-5482) or visit makitatools.com.
My bottom line is, A 115V motor circuit needs 10 amperes per horse power or 30 amp circuit for 3 horse power. Using extension cords calls for upgrade in wire gage of the cord. The advantage of using 230 volts is it cuts the amperes in half and allows use of smaller gage wire. Watts, or volt amperes is the product of volts and amps.
May 18, 2015 | Makita MAC5200 3.0 HP Air Compressor
Coleman furnace dgaa077bdta
The control fuses keep blowing tells me one or more of the control that operate the control on 24 volts is malfuctioning. Most controls operate at about 5 watts and on a clamp on amp meter normally pull about 0.2 amp (p = current x voltage, 5 watts = 0.2 amps x 25 volts) I install 75 watt 24 volt transformer with a resettable overload to save on fuses. I reset the transformer and quickly go to the controls and determine the amp draw. When I find the one >0.2 amps I found the problem. The things to check is the emergency heat sequencer, fan control sequencer, reversing valve for heat pumps, main contactor on the condensing unit and any other 24 volt control loads. I have had to replace the themostat wire because the increase current for the thermostat wire can cause the entire length of wire to form a long heater and cause insulation degradationa and cause the thermostat wire to short out and blow the fuses.
Hope this helps
Aug 30, 2014 | Coleman Mobile Modular Home Gas Furnace...
I need to find out the BTU'S on our Fleetwood Mallard Sport 23 Ft. trailer. Model# 8333D8564 Serial # 060707847 A/c and Furnance.
On an electric furnace multiply the volts times the amps and you will get watts.Then multiply the watts x 3.143 and that is your BTU
Aug 21, 2013 | Heating & Cooling
What should i set the micro switch on the back at?
Power:
2 ohm stereo (per channel): 975W
4 ohm stereo (per channel): 660W
8 ohm stereo (per channel): 400W
4 ohm bridge-mono: 1950W
8 ohm bridge-mono: 1320W
Load Impedance: Safe with all types of loads. Rated for 4 and 8 ohms in Stereo mode, 4 ohms in Bridge-Mono mode
Voltage Gain to 1-kHz, 8-ohm rated output,
CE 1000:
30.5-dB gain at 1.4-volt sensitivity;
26-dB gain at 2.34-volt sensitivity.
CE 2000:
32.1-dB gain at 1.4-volt sensitivity;
26-dB gain at 2.83-volt sensitivity.
Required AC Mains: 50/60 Hz (North American units are 60 Hz only); 100, 120 and 230-240 VAC (+/-10%) units are available.
AC Line Current,
100 Volts: 11.4 A;
120 Volts: 9.5 A;
230-240 Volts: 5.0 A;
At Idle: All amps draw no more than 90 watts.
AC Line Connector: NEMA 5-15P (15 A).
Sep 07, 2012 | Crown CE2000 2-Channel Amplifier
I don't have a problem with my product...im trying to find out how many watts do my product use. Model #uamb-036jaz serial #6263f040410617
Brand: RUUD Manufacturer: RHEEM Model Number: UAMB-036J* Condenser Type: air-cooled Condenser Coil Model Number: RCGA-36A2 System Configuration: split-system air conditioner Cooling Capacity: 34,200 BTUHs per hour Efficiency: 12 SEER
10.5 EER Electrical Service: Single-phase Electrical Input: 3,272 watts per hour Voltage: 230 and 208
Jul 01, 2011 | Ruud UAMB Air Conditioner
How many kilowatts per hour does the Krystal Clear Model 635T filter pump use?
The simple answer is not many. I don't think your pump is that hungry to use kilowattS per hour... lets see "Kilo" is one thousand. At this site you will find the several formula for getting to your answer. Ohm's Law applies ... http://www.powerstream.com/Amps-Watts.htm
I am presuming your pump is 115 Volts and it probably plugs into a 15 amp circuit. IF IT USES 15 amps (I doubt it uses the entire value) Volts X Amps = Watts or 1725 watts or about 1.7 kilowatt. I couldn't find the amp rating for your particular model pump. I think it probably operates near 6 to 8 amps @ 115 Volts AC. If your pump runs at 6 amps that is 690 watts, 8 is 920 and 10 would be 1150. There are other factors that determine the actual amount of power consumed - load will increase the use - partially clogged filter would be an example of increased load, age of the pump could be another factor.
Here is another nifty place to convert: http://www.supercircuits.com/resources/tools/Volts-Watts-Amps-Converter
Here is a rule of thumb: If a device can run on two different voltages, the higher the voltage, the lower the amps. For example 115 volt @ 12 amps would use 1380 watts. The same device running at 230 volts would run at 6 amps and use 1380. This is the correct math answer. However, in actual use, the device would run slightly more efficient (use fewer watts). Electricians and science teachers and math teachers will all tell you different stories depending on their discipline. Heavy use devices do run more efficiently at the higher voltage (stove, dryer, furnace, hot water heater, well water pumps, swimming pool pumps)(Do not go looking for a 220 Volt pump for your above ground pool in an effort to save money. The higher voltage device will cost more and there are other practical and safety related issues in this kind of installation.)
If you lived in my area, (please don't say where you live) you would pay about 12 cents (US dollars) per kilowatt hour. If your pump runs at 10 amps 115 volts - that would be just over 12 cents per hour to run the pump.
I trust this answers your question? Thank you for your interest in FixYa.com
Mar 05, 2011 | Intex Krystal Clear Model 635 Pool Filter...
Electrical installation
From the specs that you are showing 800 watts @ 230 volts will pull under 3.5 amps. I would install a 20 amp 220 volt circuit with #12 wire. Just double check if the tub requires a 3 wire ckt (2 hots & ground) or a 4 wire ckt. ( 2 hots, neutral & ground) Make sure the ckt. is GFCI protected!
Nov 18, 2008 | Home
Ac compressor not working
This unit is a 220 volt ac unit. 12-2 wiring is usually for 120 violt circuits?
  • Amps: 22.2 / 20.0
  • Watts (Heat): 4900 / 4000
  • Watts (Cool): 1650 / 1625
  • Amps (Cool): 7.7 / 8.3
  • Voltage Rating: 230V / 208V 60Hz
  • Power Cord Length: 5' (6')
  • Horsepower (Cool): 2.49
  • Plug Type: LCDI 6-30P
  • http://www.frigidaire.com/Home-Comfort/Air-Conditioning/Window-Mounted-AC/FFRH1822R2
    hope this helps?
    Jun 05, 2017 | Frigidaire Heating & Cooling
    Air Tools & Compressors Logo
    54 people viewed this question
    Top Air Tools & Compressors Experts
    John Trevino
    Joe Garcia
    Joe Garcia
    Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
