Question about Saws
Unable to tilt blade on rockwell 34-345 table saw
  • 80 Answers
SOURCE: How to change blade on 10" Craftsman table saw?
you need to grab the blade with something.maybe some pliers(if you are not going to refurbish blade) and loosen the nut in the center of the blade. i think it is a left hand thread(cw to loosen) because of the rotation of the blade. if the nut is on the left when looking from the front it is probably left handed. make sure it's unplugged and wear leather gloves so you don't get cut. install in reverse...
Posted on Jan 20, 2009
  • 59 Answers
SOURCE: old craftsman table saw parts?
most sears stores have a dept. that refurbishes and sells these tools. if it can be had, they can help.
Posted on Apr 25, 2009
  • 33 Answers
SOURCE: bought model 3400 skil table saw. have no manual.
This model does not have a knob on the side.
There is only a locking lever on the front next to a single rotating wheel for height adjustments. To tilt the blade simply twist the locking lever to the left and push the height adjustment wheel to the right. It can be a bit stiff at times to move.
Posted on Jul 19, 2009
SOURCE: How do I change the blade on my Ryobi 10" table saw?
The manual is posted on line. Changing the blade does not require turning the saw over, blocks of wood or vice grips. The advice listed above is potentially damaging to your equipment.
http://www.raygirling.com/ryobi/ryobi.htm#settadj
Posted on Sep 24, 2009
FixYaSteve
  • 57 Answers
SOURCE: Looking for a manual for a Rockwell Model 8
Exploded parts diagram is here.
They don't have the operator's instruction manual online, unfortunately.
If you need an operator's manual, the Delta 34-410 is a 10" contractors saw that's reasonably close. Please bear in mind that this is more for table saw safety and operations than specifics of setup. The 34-410 operators manual is here.
If this answer helped, please vote for it. Thanks!
Posted on Jun 13, 2010
Do you know anything about the tilt lever on a rockwell 34-625 table saw? Just purchased but the lever is really stuck and I have no way of knowing which way should loosen?
Block the saw blade by inserting a small screwdriver between the teeth against the base plate or better still place the blade in a bank screw always in the counter direction counterclockwise to loose the saw bolt sometimes you can use a burner to heat it briefly if it Very stuck
Jun 23, 2017 | Saws
12" vintage Rockwell table saw Model# 34-388 I need a manual
Check vintagemachinery's website. You might be able to find some information there about your saw. Or make a quick google search , several threads will show up upon search that could help you. If you need band saw blades, I suggest you to visit sawblade.com .
Sep 13, 2013 | Delta Rockwell 34-450 10" Tilting Arbor...
I have a delta 34-444 table saw, is it a right or left tilt, or how do i find out?
Left-tilt, right-tilt refers to the direction the top of the blade can be tilted when it is not straight up and down. There will be an indicator on the front of the saw, normally pointing to zero. When you adjust the blade away from zero, if it tilts to the left, it is a left-tilt saw.
Feb 05, 2013 | Delta Machinery Delta 34-555 Sliding Table...
How to adjust the blade at exact 90 degre
Use a carpenter square, place the square on the table top with the blade up right, adjust the tilt of the table saw blade until it is exactly parallel to the blade of the carpenter square. Check the blade in several places as the table saw blade is sometimes warped. Try to adjust until a happy median is obtained.
Apr 16, 2011 | Hitachi C10FL 10" Stationary Table Saw...
I have a 1/16" tilt
Your question is not very clear. Here are several answers.
By tilt you may be speaking of bevel adjustment 0 - 45 Some saws have hidden under the table or obvious positive bevel stops or screws in the table top for 90 and 45 degree. Adjust them.
You may have a bent or warped blade causing the "tilt."
Thin blades may be stiffened with blade stabilizing washers $14
With the saw unplugged remove the blade. Grab the threaded arbor shaft and pull it up and down. Next push the shaft straight in and out. If there is wiggle the bearings are worn and may need replacing.
Feb 26, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
Looking for owners manuals for 2 saws
Your Delta radial arm saw (RS830) manual is here. Exploded diagram for parts, etc is here.
I'm not sure on the Rockwell, but here's a link to a manual for a Rockwell-Delta 10" Tilting Arbor Unisaw, circa 1969 which seems about right for a 34-466.
If that's not quite right, there a couple other manuals for old Rockwell saws here.
If this answer helped, please vote. Thanks!
May 19, 2010 | Delta Saws
Craftsman model 708100 table saw tilt lock won't stay locked
Try removing the lock knob and putting a toothed lockwasher on the shaft. reinstall the knob.
Dec 11, 2009 | Craftsman 10" Table Saw
Wood like to clean & update my rockwell model 14 band saw need a download of this saw
try there web sight, if I'm not mistaken, Delta bought out rockwell and they should be able to help. I had an old rockwell table saw and the man shaft that the blade attached to was missing.I contacted delta with the model number of the saw and they faxed me a blue print of the shaft and we machined a new one and the saw still works great.
Jan 18, 2009 | Delta 28-060 14'' Band Saw Blade 93-1/2''...
Saws Logo
42 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
