Question about Hoover Washing Machines
VT D2 will not spin sink washed items
When I hand wash anthing the machine will not spin it
SOURCE: my tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Posted on Jan 05, 2007
  • 209 Answers
SOURCE: wm noisy
drum bearings, check and investigate, remove drive belt and then rotate, if still noisy then yes its the drum bearings, if the noise stops when the belt removed the motor bearings are faulty costly repair on most models, sorry oh there is also the possibility there is something lodged within the drum cavity between the lining and the drum casing
Posted on Sep 25, 2007
ngfam1
  • 639 Answers
SOURCE: Hotpoint WMA31 Washing machine will not spin
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
astruttman
  • 45 Answers
SOURCE: water in washing machine from emptying sink.
A washing machine filling with water overnight or when not in use has two possible causes. Either the water is running into the washing machine from the sink ( If the drain hose is connected directly to the u-bend under the sink ) or one of the water valves isn't shutting off properly and water is dripping slowly but surely into the washing machine. The latter problem can take several hours before the water level rises high enough inside the washing machine to be visible.
It's easy to track down the cause of water entering the washing machine when not in use. If turning off the hot and cold water taps stops it, then it's one of the water valves not shutting off properly, and needs replacing. It's just a process of elimination to find out which one it is. If not, the water is likely to be coming from the sink (use above link). Sometimes by removing the soap dispenser drawer and carefully observing inside the soap dispenser you can clearly see water dripping in at regular intervals.
Blocked water valve filters: I've come across cases where a filter in the water valve has become caked in a brown sludgy mud-like substance due to disturbances in the plumbing. This could be because of work carried out on internal plumbing or even after workmen have turned the water off in the street to work on the water mains. After the water is turned back on, muddy or gritty water can enter the household pipework and when you use the washing machine it can draw this contaminated water into it.
In this scenario very fine grit or muck can get past the filter and stop it shutting off properly, or the filter is so blocked that water pressure to the valve is reduced enough to prevent the valve shutting off properly. Remove the water valve filter with some pliers and thoroughly clean it out. If the fault persists, replace the valve.
Important things to watch out for are -
  1. Washing machine water valves need a certain amount of water pressure to actually ensure the water is shut off properly. Therefore, if your water pressure is very low, it can seep in past the closed valve. This problem is less likely to suddenly appear unless your water pressure has suddenly dropped. It's more likely to be a problem with a new installation. ( Related: Low water pressure and washing machines )
  2. A faulty tap can mean that although you turn it off, the water supply isn't actually cut, so be careful of assuming if the fault still occurs, that you have definitely discounted the water valves. If unsure, you would have to disconnect the hot and cold fill hoses to ensure the water supply is properly cut when the taps are turned off. This problem is a lot more common with water taps that turn off with a red or blue plastic lever.
  3. If the washing machine has just been filling, you may get some dripping of water into the soap dispenser for a few minutes after. Don't mistake this for a valve not shutting off properly.
  4. If the water ever gets turned off while work is carried out on the water mains in the street or for major plumbing in your home, run lots of water in the house through taps at the sinks until it runs clear after the water is turned back on.
Faulty water valves should be replaced or there is risk of flooding.
Posted on Jan 11, 2009
SOURCE: beko wma 510 w washing
new pump washing machine will not spin or empty. what could be the problem
Posted on May 20, 2009
Whirlpool washer wet after spin cycle
Hello.
1 Measure your drainpipe to make sure it is no taller than 96 inches in height and no shorter than 30 inches; otherwise, it won't pump enough water from the washer, or the water may flow back to the washer.
2 Look at the dial selection to make sure you have selected the proper spin speed for the material you are washing. Choose the highest spin speed for that particular material. If you choose the "no spin" or "low spin" option, your whirlpool washer might not remove all of the water from your clothes.
3 Check if you have chosen the appropriate wash cycle for the type of material you are washing. The whirlpool washing machine drains quite a bit more slowly on the "Delicate" and "Hand Wash" cycles.
4 Check for excessive soap suds accumulating in the washing machine. whirlpool recommends you use only high-efficiency detergent in whirlpool washers. Other detergents can cause excessive soap suds, which could cause the washing machine to operate at a slower spin speed than selected, resulting in sopping wet clothes.
5 Add more clothing items to the washing load. If you wash only one large item, like a coat or blanket, the washer might become unbalanced and react by lowering the spin speed, causing the machine to not drain as it should during the spin cycle.
6 Examine your drain hose for clogs or kinks. Straighten the hose out to allow water to flow through. Eliminate blockage in the drainpipe or utility sink.
Thanks.
Nov 01, 2011 | Washing Machines
My washer is leval but continues to display ul code when spin cycle starts
UL does not mean the washing machine unit itself is unlevel, it means the load cannot be balance, possibly washing too small a load that the machine cannot distribute in drum evenly ( happens alot when only one or two items being washed), could be poor pump out (check filters if accessible) the machine tries to start spin with excess water or maybe it is a mixed load, lots of small items and maybe one or two large items that hinder the distribution. My machine is very temperamental when I do the sheets, because they get tangled during the wash part of the cycle and then the machine cannot get them balanced to spin. I sometime have to manual move the item about and then put it to the spin only cycle.Hope this helps
Oct 06, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Loud noise from tub when on fast spin aquarius wma48 1400 spin
possible causes are
Overloaded Machine
Putting too many items in your washing machine at one time or washing larger items, such as a quilt, can cause your washing machine to occasionally make excessive noise. Laundry can get trapped around the agitator and will hamper its movement, causing it to work harder to spin. Stop the wash cycle and remove the excess laundry on top. Take big, bulky items to a laundromat or drycleaners to wash in an industrial machine equipped to handle such items. A washing machine is more effective at cleaning laundry when water and suds can surround the clothes and penetrate fabrics.
Defective Balancing System
GE washing machines have a balancing system that includes counterweights, springs and pistons that help to evenly distribute weight inside the wash tub. If any of the system's components break, it can interfere with the drum's rotation. Rather than spin evenly in the machine, the drum might be imbalanced up or down and produce a knocking sound. The noise might become louder and more persistent each time you do a wash load until you replace the faulty component.
Washing Machine Not on Level Surface
Place your washing machine on a flat surface, preferably a concrete slab. If the floor underneath the washing machine is sloped, even the slightest bit, it can cause the machine to vibrate when it spins and agitates. Place both hands on either side of the washing machine and try to move it. If the machine moves, then adjust its feet at each of the bottom four corners of the machine by tightening or loosening the bolts with a wrench until the machine is level on all four sides.
Jun 10, 2011 | Hotpoint Washing Machines
Wt you mean by spin in washing machine
its a separate cycle all by itself.
Say U hand wash something in a sink and instead of wringing it out by hand U can put it in the washer and press this SPIN cycle.
So U can also use it to spin more water out of your garments after the regular wash and spin cycle.
Slower spin speeds mean -
  • Cheaper washing machines
  • Quieter washing machines
  • More stable washing machines
  • Longer lasting washing machines because there's less wear and tear on the bearings, motor, carbon brushes, suspension etc.*
  • Gentler on laundry
  • The drum spins for approx 4 or 5 mins. No water is added and you dont add detergent or fabric softener for the spin only option. The object of the exercise is to centrifugally remove excess water from the garments in the drum. They will still be damp but not sopping wet after the spin cycle
  • Spin takes the water out, extract is even better
May 17, 2011 | Frigidaire ATF6000ES Front Load Washer
Washer does not spin for rinse cycle water does not drain
Check the end of your drain hose that attatches to the pipe under your sink to see if there is a block. The washer will not spin if it cannot empty the water before hand. Also check to see if your coin trap has any items in it as this will also stop the draining cycle. This is normally located at the base of the appliance just infront of the pump
Hope this helps
Mar 11, 2010 | Whirlpool LSR5132PQ Top Load Washer
Simpson Aquarius washing machine 7kg: water
SOUNDS LIKE A PLUMBING PROBLEM WITH DRAIN PIPE .YOU COULD FIT NONRETURN VALVE TO DRAIN FROM WASHER BUT THAT WOULD NOT STOP SINK FROM OVER FLOWING
Jan 08, 2010 | Washing Machines
When I put towels or rugs in the washer the cycle show complete, but when I open it the items are soaking wet.
Its probably because the items are too heavy for the washer to safely spin.
If you squeeze some of the water out of them into a sink then put it on spin cycle, it should work. Otherwise spin them in two loads. Its a bit of a pain but its to protect the washing machine mechanical parts.
Hope that helps!
Dec 29, 2009 | Kenmore 43142 Front Load Washer
Smelly drain and wont spin properly
check filter may need pump then flush through on hot wash.
Jun 29, 2009 | Washing Machines
Blocked sink maybe equalls non spin or drain of washer
It depends on where the sink is blocked, and how the washing machine plumbing is set up.
If the sink is blocked in the p-trap under the sink, and the washing machine does not drain to that trap, then it's a separate problem.
That being said, if this is in fact the way the washing machine is plumbed, then it indicates that there is not an air gap between the washing machine hose and the drain. There must be an air gap or the washer will likely not drain, regardless of how it is plumbed to the sink or not.
Reply back with further information, or if you need clarification. But yes, the sink being plugged could be the cause of the washer problem, or may just be coincidental and not have anything to do with it.
Feb 03, 2009 | Indesit W 123 Front Load Washer
Washing Machines Logo
107 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
