Question about Sharp Office Equipment & Supplies
Sharp printer rendering error - Sharp Office Equipment & Supplies
MX m354u. What does error Code U2-91 indicate?
This seems a common error across a wide range of Sharp printers/copiers. It means
PCU PWB EEPROM CHECK SUM ERROR
See the following two links (for example)
Thread U2 91 on MX 5000N and SHARP MX M363N ERROR CODES Trouble Codes
If haven't got manuals or other documents which may contain helpful information they can be downloaded here. This link also contains contact information for sharp so that you might get support
MX M354N MXM354N Digital Copier Printer Sharp
6.November.2015
Feb 27, 2015 | Sharp Office Equipment & Supplies
Why is the DATA light blinking on Sharp model MX-2300N
If something is stuck in the rendering process this will happen. To fix it, first make sure the machine is in copy mode then press:
Pound, Star, C, Star
66, start
10, start
execute, yes...wait for a minute while it processes, then it will reboot.
this will clear out anything stuck in queue
Skelton Business Equipment Houston Copiers
Jun 02, 2014 | Sharp MX-2300N Color Copier
Sharp AR-M206 printer is producin an error call service f2-04
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} - Improper cartridge (destination error, life cycle error)
Identification error
model error
type error
destination error
data abnormality
Misc error
Jul 30, 2010 | Sharp AR-M162 All-In-One Laser Printer
My Sharp 237 has an error code H2-00. How do I fix it?
This is a fuser heating issue. It could be a few things. It could be a bad heating lamp or possibly a bad thermistor (all in the fuser unit). Could even be a control board problem. You could try unplugging and re-plugging the fuser wires that connect the fuser to the copier/board. Make sure there are no peices of paper stuck inside the fuser. If you have some electrical experience you could remove the fuser unit and check the lamp/thermistor continuity with a meter. Check for signs of any burn marks/arching in the fuser.
You can reset the error by pressing the following keys one after the other (make sure you are in copy mode) "P" "*" "C" "*"
enter 14 and start key.... confirm on the screen...and restart copier. (DO NOT make adjustments to anything else in service mode - it will render copier useless!!)
If none of this helps call your local dealer.
Jan 16, 2010 | Sharp AR-M237 Copier
As the bag of a sharp 2114 error h3
SHARP - 2114 - L8-1 - zero cross signal error
SHARP - 2114 - L8-3 - auto-exposure sensor malfunction
SHARP - 2114 - H2-0 - Fusing unit temperature error
SHARP - 2114 - H3-0 - Overheated fusing unit
SHARP - 2114 - H4-0 - The fusing unit doesn't heat up
SHARP - 2114 - U2-1 - EPROM error
May 29, 2009 | Sharp AR-5316 Advanced Digital Imager...
I have a F2-41 code. What does this code mean?
- Impropercartridge (destination error, life cycle error) Identification error model error type error destination error data abnormality Misc error
Apr 15, 2009 | Sharp AR-BC320 All-In-One Led Printer
I have a sharp copier MX2700N with an error code of TK2. Will this cause the copier to stop printing and is there a way to clear it
The TK2 means its time to replace the secondary transfer belt. Depending on your copier and driver setup it may prevent you from printing. If you open your print driver properties and go to the ports tab and then click on configure port button, in the next window uncheck "SNMB printing" option - this should allow you to print. You can clear the maintenance code by going into the SIM mode. press the following keys one after the other "P" "*" "C" "*" then enter 24 and "copy start key" then enter 4 (maintenance clear) and copy start key then highlight the items you want to reset and press execute then yes. restart the copier by pressing the "CA" key. do not make adjustments to other sim code items as it can render copier useless!
hope that helps.
Apr 06, 2009 | Sharp MX-2700N Color Copier
Error: Printing data is inaccurate, printing processing is stopped Printer error page is printed with this error prints fine from the webpage printer is installed on windows 2000 over a network
I got the same error with another type of sharp photocopier AR-M257
My error, I was installing the wrong driver.
I installed the Sharp driver with the PS at the end.
You can download from here depending the version of the Windows you have
http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
Good luck!!
Aug 22, 2008 | Sharp AR-M207 All-In-One Laser Printer
'H' error code
Sharp's diagnostics use the letter "H" t designate a problem with the fuser, that is the part of the mahine that heats up and maintains a set temperature. The "H" is usually followed but a number, either 3 or 4 to indicate whether the temperature is either too high or too low. In many cases, there is a temperature fuse that will blow out and render the heater powerless. It will have to be replaced by a technician who will then run a reset code to bring things back to a normal condition. Sorry I couldn't be more help.
Aloha,
Bill Monroe
Oct 20, 2007 | Sharp AL-1655CS Copier
79 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
