Question about Samsung Refrigerators
I have a samsung fridgr freezer RL39THCSW & the fridge part kerps freezing everything
Fridge is freezing everything
SOURCE: Fridge of Fridge/Freezer keeps freezing contents.
all the food going to ice temperture at 2
Posted on Nov 25, 2007
  • 5 Answers
SOURCE: Samsung Fridge Freezer
Possible bad defrost timer.
Posted on Mar 09, 2008
  • 88 Answers
SOURCE: FRIDGE COMPARTMENT FREEZING
try this,make sure you dont have anything blocking your blower in the freezer.if that is okay if you have seperate controls for the freezer and the fridge,try setting the frige setting lower and the freezer higher,this makes the blower work more in the freezer.hope it helps.
Posted on Dec 06, 2008
SOURCE: the fridge part of my fridge freezer keeps freezing everything,
Hello
I have the same problem and have talked to the manufacturer. They said to turn off the appliance for 24 hours then it should be good as new when you switch it back on. Obviously you'll have to find somewhere for your freezer contents. I'm going to try this myself tonight.
Fridge Reboot!
Posted on Feb 06, 2009
SOURCE: E521T fisher & paykels fridge is freezing everything
trn your thermostat right down see if that helps
Posted on Mar 31, 2009
Hi I have a samsung fridge freezer. Sl39wj1/xeu. Doesn't seem to be doing anything no light but is continually flashing f5
not sure what you mean water in fridge and ur assuming? did it freeze everything or not freeze? is fan not running or compressor? any noise or sounds?
Mar 14, 2015 | Samsung Refrigerators
My Samsung RL39WBMS fridge on m fridge freezer keeps freezing food. Why is this happening all the time and how can I prevent it?
maybe the fridge is set on a colder setting and if that's not it then stick it on the lower shelves and that might help from not freezing because are fridge is the same way when it is stuck by the coolant fan
Nov 02, 2014 | Refrigerators
RF265AARSXAC The freezer is not freezing.
looks as evaporator fan is working. have you ever clean condensor under the fridge. possibility it is pluged with dust and not allowing compressor to cool down.
Also check the fan at the back of the fridge beside the compressor. see if it is working
Nov 14, 2013 | Samsung RF265AA Bottom Freezer French Door...
Hi I have a Samsung fridge freezer the fridge is not coolinng and the freezer is not freezing but the motor is going.Regards Maria
have a look here for
this guy has few videos with various diy solutions for samsung fridge freezers
Jan 27, 2011 | Samsung Refrigerators
Fridge freezing up
Check the fridge sensor. On my Hoover HNMF2805AL80 f/f, first I replaced control module - still freezing.
Have just replaced cheap fridge temperature sensor. Part No. 97061619. Trouble is you have to cut into insulation at back of fridge to replace. I just plugged in sensor & placed inside fridge at back at the bottom - so far so good, only lettuce freezing now, everything else v. cold but not frozen. :)
Jun 02, 2010 | Hotpoint RLA50 Refrigerator
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
Samsung RB215BSSB refrigerator freezes up
I had a similar problem where my evaporator coil was freezing into a block of ice, which caused my fridge to warm up due to a lack of air flow. I fixed this by doing a few things. I replaced the circuit board ($100) which was easy to do. Unfortunately, this didn't fix my problem so I took the inner fridge cover off to view the evaporator/heater coil assembly. I checked my thermo fuse and found it to be open (failed). I ordered the thermo fuse and the thermistor and replaced them both. I then plugged the fridge back up and put a regular thermometer inside the fridge to get an accurate reading of inside temp. A few days now and everything looks good. The board, fuse, and thermistor were all pretty easy to replace.
Apr 09, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Dec 06, 2008 | Refrigerators
Malfunctioning American Fridge Freezer
Is it freezing. Sometimes those led's go out.
Dec 21, 2007 | Freezers
Refrigerators Logo
95 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
