Question about MSI K8NGM2-L Motherboard
Lost all USB port after restarting my computer.
Hi, I am struggling to fix the issue. Looking in my device manager, USB Host Controller shows as invalid. I have tried every single option: updated the BIOS, update the Nvidia drivers, you name it. Can anyone tell me if there is a solution for this type of problem? I am quite sure it is a driver issue, because when rebooting the computer, all USB ports are powered until windows starts, when the power goes off. I hv a XP Professional (Media Center 2002) SP2. Appreciate any help/info you guys can provide. Cheers,
  • OjBrasil Oct 08, 2007
    Just to be clear, the power goes off only for the USB ports, my computer runs fine except that I have no USB connectivity, which theses days is a big issue...
    Thanks
    I have already done that.
    I also tried buying a USB PCI card and install it, but windows XP is not able to load the drivers for this card either... Major pain in the neck...
    The one thing I hav not tried was your suggestion disabling from Windows... I will try and post the results.
    Thanks for your reply.
    Problem Solver:
  • 8 Answers
Hi OjBrasil, Just a suggestion, but did you try re-setting the bios? Also, this is a rare possibility, but I feel maybe the difference in full-speed and Hi-speed usb might be causing a problem. One more thing you can try before re-setting the bios is to go into the "Integrated Peripherals" section of your bios and disable USB, re-boot and then re-ENABLE it again.. then see what happens. Yet another thing, you can try disabling it in Windows and re-enabling it again to see if that produces any results. Can't think of anything else right now, but do keep us updated...
Posted on Oct 08, 2007
SOURCE:
Acer d257 usb port not working
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
hope this helps
Jul 24, 2012 | Acer Aspire One D257 Netbook
Hi sir, I need help on my pc, i install a usb 2.0 pci to usb card on the mother board but cant get it working, i have on device manager under other devices have an exclamation mark on universal serial...
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
http://download.cnet.com/via-usb-2-0/3000-2098_4-10163319.html
Available in this download are drivers for VIA USB 2.0 host controller on a system running on Windows 98/98SE/Me. Due to licensing agreements, USB 2.0 drivers for Windows 2000/XP are not available for download. They are supplied on CD with new mainboards or available through Windows Update. This version is a bug-fixing release.
hope this helps
Jul 30, 2011 | NEC Televison & Video
Hi, i do have a n1996, ms-6547, motherboard, imtrying to download a fix for and also for usb 2 and i can not find them,thanks in advance
control panel admistrive tools,computer management,device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers or ports(com&lpt)right click update driver
If your Device Manager shows an ENHANCED USB Host Controller, the system has High Speed USB (USB 2.0) capability.
Types of High Speed USB (USB 2.0) Host Controllers
· Intel Enhanced
· SiS Enhanced
· VIA Enhanced
· ALi Enhanced
· Standard Enhanced
· NEC Enhanced
The system shown has onboard Intel High Speed USB (USB 2.0) with an NEC High Speed USB (USB 2.0) PCI card installed.
The key word is ENHANCED. If you have an ENHANCED USB Host Controller then you have High Speed USB (USB 2.0)
All other types are USB v.1.1
hope this helps
Nov 11, 2010 | MSI MS-6547 Motherboard
Will not work in usb 2.0 but will work in usb 1.0
Connect the Player to the USB 2.0 port on the Comptuer then open the Device Manager and expand the "universal serial bus controllers" category.
Under the serial bus controller category, check if there is any exclamation mark visible. If there is any then right click on it and select Uninstall. Restart the Computer after uninstalling the device with exclamation mark. Restarting the Computer with the player connected will make the Computer recognize the connected player.
Furthermore, check whether there is any universal serial host controllers prefixed with "Enhanced".
If there is no Enhanced universal serial host controller listed under the "serial bus controller" category then it's required to install the USB 2.0 driver.
In this case, uninstall all the devices listed under the universal serial controllers category then restart the Computer to reload them automatically.
Sep 17, 2009 | Audio Players & Recorders
My Panasonic CF-74 doesn't seem to be detecting anything I am plugging into the USB ports or the COM port.
Some motherboard BIOS's allow you to specify how many USB ports you want enabled
go to your Control Panel, System, Device Manager.
go down to where it says Universal Serial Bus Controllers, click the + sign,
you will see a list of devices, probably something like this
via rev5 usb host controller
usb printing support
usb mass storage controller
usb root hub
usb root hub
right click on the ones that say via or intel or SIS, or ALI, or Standard open host controller, and choose uninstall.
you will be asked if your sure, and you will see some of the USB root hubs disappear.
If you are asked to restart, choose no, and remove the other via/sis/intel/etc open host controller (s) from your system, when they have all been removed restart your computer.
when the computer restarts, it will detect the USB controller and connected devices, reinstall the drivers/software
Jun 24, 2009 | Panasonic Toughbook 74 PC Notebook
Usb ports not working
  1. Checking USB device status in Device Manager
  1. Right-click My Computer on the Windows desktop and then click Properties.
  2. Click the Device Manager tab to display the Device Manager window as shown at the right. (For Windows 2000 systems, click the Hardware tab and then the Device Manager button.
  3. In the Device Manager list, click the + sign next to Universal serial bus controller.
  4. Verify that a USB host controller and a USB root hub are listed below Universal serial bus. image002.jpg
  5. If Universal serial bus controller, USB host controller or USB root hub are not listed, close the Device Manager and go to USB port incorrectly configured in BIOS
  6. If Universal serial bus controller, USB host controller and USB root hub are listed but one or more display a yellow exclamation point, go to USB controller IRQ conflict
  7. If you have Windows XP, right-click the Host Controller and select Properties from the drop-down menu. If you see this status message in the Properties window: The drivers for this device are not installed (code 28), go to Windows XP USB 2.0 driver not installed .
  8. If Universal serial bus controller, USB host controller and USB root hub are listed but one or more display a red X, go to USB controller or root hub disabled in Windows Device Manager.
USB port incorrectly configured in BIOS NOTE: The procedure in this section is intended for advanced users only. Incorrect BIOS settings could prevent your computer from starting or operating normally. If you are not experienced in making changes to your computer BIOS, consult your computer instructions or contact your computer manufacturer for assistance before attempting the steps below.
  1. Follow the instructions of your computer to view the BIOS settings. These settings are sometimes called CMOS settings or system setup.
  2. To view the BIOS settings, press a key, such as F2 or Delete, just after you turn on the computer. Instructions often appear on the screen briefly when you turn on the computer. Also check the instructions and manuals provided with your computer.
  3. Look for USB Interface or a similar setting in the Advanced Setup, Peripheral Configuration or another section of your computer BIOS settings.
  4. Follow the onscreen instructions or read the computer documentation to enable the USB port.
  5. Follow the onscreen instructions to save the new settings and restart the computer.
  1. USB controller or root hub disabled in Windows Device Manager
  2. Click the Device Manager tab. (On Windows 2000 and XP systems, click the Hardware tab and then the Device Manager button.)
  4. Click the line in the Device Manager containing the red X.
  5. Click the Properties button. (On Windows 2000 and XP systems, click Properties on the Action menu.)
  6. In the Communications Port Properties box, click the Resources tab.
  7. Re-enable the USB device by clicking the Enable Device button and follow the onscreen instructions.
Dec 28, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
I have a 2.5" seagate 100GB that is enclosed in a aluminum usb HDD case. The connector is a USB Y cable. It is suppose to be compatible with USB 2.0 and USB 1.1. I am running windows xp home on my pc and...
pls remove the hard disk from enclouser and plug direct to sata port and check if run well.
if not pls check with bios detection, if enclouser is good and hard is bad, there was no detection with usb port.
Apr 03, 2017 | Fanner Computers & Internet
Power Surge error message
I guess that this could be your error message:
"Error message when you wake up a Windows XP-based computer from hibernation or from standby: "Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port"
If it is the case, please try below solution:
SYMPTOMS
When you wake up a Microsoft Windows XP-based computer from hibernation or from standby, you may receive the following error message:
Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port. This error message is displayed even if there are no USB devices connected to the computer.   WORKAROUND loadTOCNode(1, 'workaround'); To work around this issue, disable the USB 2.0-enhanced host controller.
Note When you disable the USB 2.0-enhanced host controller, you lose USB 2.0 functionality. That is, you revert to USB 1.1 functionality.
To disable the USB 2.0-enhanced host controller, follow these steps: 1. Right-click My Computer, and then click Manage. 2. Under Computer Management (Local), click Device Manager. 3. In the Device Manager pane, expand Universal Serial Bus controllers. 4. Right-click the USB 2.0-enhanced host controller, and then click Disable.
Note The name of the USB 2.0-enhanced host controller may vary. 5. When you receive the confirmation message, click Yes. 6.
Close Device Manager.
I hope that this should resolve the issue for you.
Please let me know the result.
you can mail me at [email protected] for any further assistance on this issue.
I'll be glad to help you.
Oct 18, 2007 | IBM ThinkPad T43 Notebook
USB connection problem using Windows 98 Second Edition.
The cause of this problem can be traced to both the computer's hardware configuration and Windows 98SE (Second Edition). PhotoMAX cameras and other devices featuring USB (Universal Serial Bus) connections may not work with computers running Windows 98 Second Edition and equipped with the following computer hardware: * an AMD processor (350 MHz or higher) * VIA Technologies USB Host Controller or SiS 7001 USB Host Controller To find out what USB Host Controller is on your system: 1. Click Start > Settings and choose Control Panel. 2. Double click the System icon. 3. Choose the Device Manager tab. A window similar to the one shown below appears. 4. Expand the Universal Serial Bus controllers listing by clicking on the "+" sign next to the listing. 5. Note the type of host controller in the listing. The example above shows the SiS 7001 PCI to USB Open Host Controller.
Sep 14, 2005 | Polaroid PhotoMax PDC 700 Digital Camera
Sep 14, 2005 | Polaroid PhotoMax MP3 Digital Camera
Open Questions:
SBCglobal MAil TecH {1.855.536**5666}#[email protected] SuPPoRt NuMbER IDAHO This SbCgLoBaL MaiLUSA phone number is ranked #2 out of 2 because 7,728 SbCgLoBaL MaiLUSA customers tried our tools and information and gave us feedback after they called. The reason customers call # I855%^536%^5666is to reach the SbCgLoBaL MaiLUSA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, SbCgLoBaL MaiLUSA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SbCgLoBaL MaiLUSA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I855%536%5666 and ways to call or contact SbCgLoBaL MaiLUSA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL MaiLUSA Calling SbCgLoBaL MaiLUSA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL MaiLUSA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL MaiLUSA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL MaiLUSA's phone numbers against each other. Contacting SbCgLoBaL MaiLUSA in General While I855%536%5666 is SbCgLoBaL MaiLUSA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I855%536%5666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL MaiLUSA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL MaiL USA.
Oct 16, 2019 | Best Computers & Internet
See all MSI K8NGM2-L Motherboard Questions
MSI K8NGM2-L Motherboard Logo
87 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
