Charmglow model #HEF33 fireplace
Heat but no flame
SOURCE: flame on my electric Pyromaster is standing still is there a bulb
basically, on the bottom of the fireplace, there are 2 screws on the sides, 3 on the back, take them off, lift bottom (it wont come off, so be careful not to bend it) there are 3 christmas light type bulbs, you can find them at any hardware store. Just replace them. Problem solved.
If the flame is standing still, i assume the motor is burnt out. or the belt is off.
Posted on Sep 13, 2009
SOURCE: electric fireplace does not heat
I have a cheap electric fireplace bought in SuperCentre store-heater no longer works. It says its a one piece system. Can these heaters be replaced or repaired(probably made in China) or am i better off scrapping it and buying a new one?
Posted on Oct 18, 2009
SOURCE: My Heater stopped working on my HEF33 Electric fireplace
We have had this same problem with our heater. But I went online to find out where I could purchase replacement parts. The company that sold the fireplace went out of business. I also went on-line to try and fine a universal replacement part. So far no help to be found.
Posted on Dec 12, 2009
SOURCE: I have a fireplace model # 23EF003GRA, logs
I have the same problem. I removed the top cover and the circuit board was black around the fuse clips. I looked further and the fuse clip had heated up so much that it had separated from the board. I will contact the manufacturer tommorrow and see what they wii do for me
Posted on Feb 08, 2010
SOURCE: Charmglow Electric Fireplace ***NO HEAT** just lights up, HELP :(
Take the fan power switch apart and clean the 2 point contacts. Also clean the 4 male studs that the wires plug into. That should solve the problem.
Posted on Feb 13, 2010
I am looking for a remote for my charmglow electric fireplace Model # hef33. I have been everywhere. Help!
I recommended this site to another questioner who needed a remote for their electric fireplace and apparently they were successful in purchasing a universal remote kit. It's worth a try.
www.americanhearthandhome.com
Feb 08, 2011 | Heating & Cooling
Charmglow ventless gas fireplace burners won't ignite
is pilot flame on the thermopile good, pilot flame should cover the thermocouple and thermopile if unit has both
Jan 07, 2010 | Blue Flame Charmglow 30K BTU Propane Vent...
HEF33 flame not turning over, power OK and heater working, all lights on. Flame speed at stop and will not move.
i have pyromaster hef33. flames on my stop moveing also. i took off front glass and logs. then i got a long metal tool and.then i tap the moter that moves the rod that makes the flames move.and also i move the rod back and forth alittle bit. i did put just bit 3in one oil on both ends of the rod. so far its doing better now . this may help some one or it not. i thank the moter or rod was sticking
Jan 02, 2010 | Leisure HOMEPRIDE Electric Fireplace...
Charmglow electric fireplace flame does not flicker. Bulbs ok. HEF33WDG
You will have to connect a 12v dc power supply to the flame motor. The controller on the board has fried. I built a regulated 12 v dc power supply and tapped it into the bulb circuit so it will power the motor when the bulbs come on. You may have to find an electrician or techie to rig this up safely.Good luck!
Oct 12, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Dec 24, 2008 | Heating & Cooling
Flame on my electric Pyromaster is standing still is there a bulb
Nov 20, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Replace light bulb in a Charmglow electric fireplace
you have to remove the doors and then the lower ember cover, he lighs are underneath.... i am looking on how o make he flame move, it froze and won look like real fire anymore
Oct 21, 2008 | Kitchen Appliances - Others
Heating & Cooling Logo
98 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
