Question about Maytag MER6772 Gemini Electric Kitchen Range
Maytag Gemini Model MGR6875adb/q/s/w lower oven will not heat..stays at 100
Lower oven will not heat, stays at 100
garing
  • 998 Answers
SOURCE: lower element of top oven does not heat on Maytag Gemini
replace the control
Posted on Aug 06, 2009
EllaWatson25
  • 725 Answers
SOURCE: I have a Maytag Gemini Precision touch 750 series
This sounds like your ignitor has gone out. The preheat will work because the valve doesn't have to ignite to heat to 100 degrees, but whent he unit is ready to ignite, the gas can't ignite it. If you will call or email us, we'll be sure to get the correct ignitor out to you asap so you have your oven orking right away! Thanksgiving is just around the corner, so I hope you get this repaired soon. We hope this helps and we hope to hear back from you soon.
Posted on Sep 30, 2009
mgprice
  • 744 Answers
SOURCE: Oven will not heat
Hello, your problem is going to be a bad igniter. you should replace it. Good luck! Mike
Posted on Nov 02, 2009
jumptrout51
  • 3361 Answers
SOURCE: Maytag Gemini double oven flashes F1 and stops heating.
I am attaching a Gemini manual. The checking procedures are the same for your oven.
Two component suspects for your problem would be the door latch mechanisms and the oven temperature sensors.
http://www.servicematters.com/maytag_library/docs/16010161.pdf
Posted on Feb 03, 2010
SOURCE: I have a Maytag Gemini oven. The top oven heats
It's most likely the bake ignitor - see this post:
http://www.fixya.com/support/t1293780-maytag_dual_oven_upper_oven_not_heating
Or this one (same answer):
http://www.fixya.com/support/t795095-maytag_gemini_gas_top_oven_not_work
Posted on May 11, 2010
My electric maytag gemini lower oven i not heating up but I do not get any error codes
Pull the temperature sensor and check it with a multi-meter. It should read 1100 Ohms. Post back your results.
Dec 21, 2012 | Maytag MER6772 Gemini Electric Kitchen...
Getting a F1-4 error code on my Maytag Gemini model # 6772. Came home to the upper oven at full heat with the control panel beeping. Extremely dangerous situation where the oven would not shut off at the...
Hi greg_shanoia,
The F1:-4 error code means "Runaway Clean Lower oven". You need to check the oven temperature sensor, replace if necessary.
Hope it helps.
Thank you for using FixYa.
Sep 21, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Lower oven pre-heats to 190 over an hour, does not go to bake
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jul 16, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Feb 03, 2010 | Maytag Gemini 30" Self-Cleaning...
I have a Maytag Gemini Precision touch 750 series double oven range MGR6775ADB. The lower over is not responding. It will not preheat. The display says preheat and stays at 100. There is no flame igniting.
Sep 30, 2009 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Maytag gemini model MER6770AAB - F1-2 error
Check the sensor for correct ohm reading. If it is good, replace the control. It should read 1143 at 100 degrees
Sep 18, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini bottom oven not working
both ovens on my new stainless steel maytagmgr6775 not heating up.............
Dec 08, 2008 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Maytag MER6772 Gemini Electric Kitchen Range Logo
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
