Question about Brookstone Audio Players & Recorders
Brookstone pruning shears
Can I buy the blade for a hand pruning snips
How do I prune a peach tree
Do you wish the tree to produce a lot of fruit or to be a pretty tree. The trimming process will be different depending on what you wish.
Oct 09, 2014 | Fiskars Telescoping Pruning Stik Tree...
Tip
Sharpening your garden pruning shears
Every so often you will find that your gardening shears just aren't up to snuff. This will usually be most prominent when it get really difficult to cut through even the weakest of branches. Cleaning and sharpening your pruning shears is very simple and can be done in a matter of minutes.
To start you have to make sure that your shears are clean. Its not difficult to clean them, you can use a cleaning solution like scrubbing bubbles to get the dirt off, you just spray them and wipe them off with a soft cloth. If there is a lot of dirt or rust on the blade you might need to use a wire brush or a piece of steal wool to get them clean.
When you are satisfied with how clean the shears are you will need to get a sharpening stone. Carefully using your thumb on the convex blade (the big side of the shear) of the shears find the beveled edge. This will tell you the angle that you should be using to run the stone along the edge at.
When you have identified the angle that you're going to use to sharpen at, take the stone in your dominant hand and in the other hold the shears open. Applying a little bit of pressure rub the stone in small circles. You don't want to over do it, just a few times should be enough to get the blade sharp again.
The beveled edge should be the only blade that needs to be sharpened. On the flip side of the balde you shouldn't need to sharpen because it should be flat. In the case that you run your finger along the flat side and you find a bump you can use your stone to just smooth it out.
When you are satified with how smooth the blade sides are you should put a little bit of oil into the joint of the blades and open and close the blades a few times to get the oil into the gears. And finally using a cloth wipe the oil up and spread it over the blades. Wiping the oil over the blades will help to keep them from getting rusty.
To make sure that are ready to use you can test them on a piece of shrubbery or you can just head back out to the garden and get to work!
on Feb 05, 2014 | Garden
Can I use dull pruning shears to trim a rose bush?
You shouldn't use a pair of pruning shears if they are dull because they could do more harm that good for the plant.
Jan 28, 2014 | Garden
How do I sharpen my pruning shears?
You can use a mill file to sharpen your shears fairly easily. See this instructable page. Sharpen Hedge Shears with File
Are loppers the same thing as pruning shears?
loppers are similar to pruning shears, but a bit different. Loppers are used with both hands and have long handles. They are made for thick branches that pruning shears cannot cut.
Jan 29, 2013 | Garden
Fiskars pruning stik head restringing
http://gmedia.fiskars.com/faq/9240replacement.pdf
Oct 14, 2012 | Fiskars 9840 Professional Pruning Shears,...
Cannot open the stove pipe I snapped into a circle
Don't unsnap it Cut it to length One way is to use shears Another way is to use abrasive
blade on a grinder I believe you can buy hand shears at Sears they are special snips
that can cut the pipe. You need to use a screw driver to poke a hole in pipe to get started
Apr 15, 2009 | Stoves Kitchen Ranges
Trimer buing Question
Double position trimmers For extended reach while on the ground, a double position trimmer avoids you having to climb up high by allowing you to adjust the handle into a right angle to the blades for a level cut across the top of the hedge. Clippings collector As you trim your hedge, collect those stray cuttings in a clippings collector for a neater finish. Automatic cut out An important safety feature, this automatically switches off the hedge trimmer once the trigger is released. Hand guard For reassuring safety, a hand guard will protect you from the moving blades and from falling cuttings as you work.
Aug 27, 2008 | Corona Hedge Shear 10 1/2" Blade Aluminum...
Top Brookstone Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Carlos L. Burgos
Carlos L. Burgos
Are you a Brookstone Audio Player and Recorder Expert? Answer questions, earn points and help others
