Question about Marantz New Original RC014SR Remote Control
Volume button does not react anymore rest is ok
My Bose remote turns on and off withthe comcast remote but the volume does not work unless I hitthe AUX button first. Does not work with the all button pushed.
Since multiple devices have volume controls you must inform the remote which device's volume you are changing. Just like the Power button. You wouldn't want everything in the room reacting to a generic command.
Aug 09, 2011 | Bose Cinemate Digital Home Theater System...
My Sony CDX-L350 CD Player's volume buttons dont react no matter how hard i press them, and i cant adjust the volume
Hi Kenny,
There is a manual reset that is used as a catch all remedy to handle symptoms of an unspecified origin.
It's located on the front of the unit, behind the front panel, directly behind the "ATT" button. Get a paper clip and press it.
Best regards
Aug 15, 2010 | Sony CDX-L350 CD Player
The up volume button is broken and I cant' turn it up anymore
volume is next to the down volume. maybe the button broke off and you lost it.
May 22, 2010 | SanDisk Sansa Clip MP3 Player
The volume of tv keeps going down by itself and when I close t.v it dosent open at all anymore....the light on the right bottom of tv is purple instead of blue or red
Sound like you have a bad volume button. I don't know the brand or model but if you can unplug the button board with out disconnecting the remote reciver. Do that and use the remote. If set is ok then replace button board or switches.
Nov 24, 2009 | Televison & Video
My multimedia touchpad on my acer aspire 8930G isnt working anymore... the volume leds and the mute led lights up, cant do anything with it anymore. Won't even react on adjustments made in Volume Control...
Well, I had the same problem too, so I called the acer support and solve it in a sec.
You just need to close your pc, take the battery off for a few seconds, and put it back in again.
Just as simple as that....
Good Luck!!!
Oct 14, 2009 | Acer Aspire 6920 Notebook PC
Mp3 player
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 08, 2008 | Philips GOGEAR SA6045 MP3 Player
FROZEN!!
First, try resetting the GoGear. Make sure the GoGear is on, if possible. Use a small paperclip or other device and press it into the reset hole. If the reset doesn't work, then:
Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new.
-Tha Mp3 Doctor
Jan 19, 2008 | Philips GOGEAR SA6045 MP3 Player
Marantz New Original RC014SR Remote Control Logo
60 people viewed this question
Top Marantz Televison & Video Experts
Electro Med Services...
Are you a Marantz Televison and Video Expert? Answer questions, earn points and help others
