When I lock the doors on my 2000 bmw it does not make that chirp
2 Suggested Answers
bnachos
  • 38 Answers
SOURCE: bmw 323 door locks
check out Pelican auto parts. http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?please_wait=N&forumid=&threadid=&command=DWsearch&description=door%20lock%20cover&FILTER_BE46=ON&FILTER_TECH=ON&FILTER_SUPP=ON&FILTER_ACCE=ON&FILTER_CARE=ON&FILTER_STUF=ON&FILTER_PERF=ON&FILTER_MISC=ON&FILTER_GADG=ON&FILTER_TOOL=ON
You're not very specific regarding your problem, so sorta hard to provide to definiite answer. Pelican is a great source for BMW mechanical parts.
Posted on Jul 11, 2009
How do I reset anti theft in my 2002 ford f150
tis a process so here goes..... Central Security Module (CSM) enable/disable mode allows autolock feature to be turned on or off. To enter enable/disable mode, close all doors. Ensure ignition switch is in LOCK position. Perform the following steps within 30 seconds:
Turn ignition switch from LOCK to RUN position.
Press power door lock switch UNLOCK button 3 times.
Turn ignition switch from RUN to OFF position.
CSM module should chirp horn indicating CSM module is in enable/disable mode and ready to accept program changes.
Press power door lock switch UNLOCK button once to command CSM module to toggle autolock feature on or off. Press power door lock switch LOCK button once to enable/disable autolock feature. CSM module will chirp one time to indicate autolock has been disabled.
CSM module will chirp once, followed by a longer chirp to indicate autolock feature has been enabled. Press power door lock switch UNLOCK button once, then turn ignition switch to OFF position to exit enable/disable mode. CSM module should chirp once to verify a feature change. Best to you.
Dec 31, 2017 | Ford Cars & Trucks
My 2000 740il won't lock the doors
First I suggest to check fuses and wires at power door locks.
Jun 21, 2012 | 1997 BMW 7 Series
Alarm chirps 3 times while activating
On some BMW's of this vintage, lifting the handle would actuate the heated locks. So there was a microswitch on the handle itself. There's also a switch on the door jam -- part of the striker plate, at least on my E36.
Oct 01, 2017 | 1998 BMW Z3 Roadster
My horn doesn't chirp when I lock the doors.
My chevy doesn't chirp on the first press of the lock button, it just locks. If you press it again, then it chirps. To be honest, I like the fact that it doesn't chirp first - that just draws attention to the fact that you left your vehicle.
Nov 30, 2011 | 2004 GMC Envoy
2000 v reg bmw 316 drivers door lock wont open with a key
problem here can arise through the car always being locked / unlocked with remote, the actual barrel in the lock can sieze up, worst scenario is to replace the lock barrel, your local bmw dealer should be able to order you one which will fit your key (if it is original one ) you may need to show your v5 and take photograhpic id proof with you!
Jan 04, 2010 | 2000 BMW 3 Series
Central door lock and emergency button
i had this problem. I took the hazard and lock buttons out and took the white case inside out. One of the clips were broken so i taped it.
Jun 28, 2009 | 2000 BMW 3 Series
BMW Passenger door not unlocking with remote
try pressing the keyless entry unlock button twice
Jun 03, 2009 | 2000 BMW 3 Series
Recode a key 4 bmw 318i cenral locking
To carry out this procedure you need to have one working key and one key which requires programming. It may help sometimes to hold the key close to the rear view mirror as this is where the sensor is located in most models. 1. With both keys, get in the car and close all windows and doors. 2. Put working key into the ignition and turn to position 1 (the accessories should turn on) (try also position 2) 3. Turn the key back to position 0 and take the key out of the ignition. 4. Using the working key, hold down the unlock button, press the BMW logo (lock button) 3 times, and release the unlock button. Doors should lock and unlock. 5. With the new key, hold down the unlock button and press the BMW logo (lock button) 3 times and let go of the unlock button. Doors should lock and unlock and you're done!! If not working try the following PREPARATION 1. Close all doors, trunk, hood and sunroof. 2. The security system must be in 'disarm' mode. The key must be removed from the ignition key slot. ENTER CODE LEARNING MODE 3. Open trunk and leave it opened. 4. Open the drivers door and sit in the drivers seat. 5. Close the drivers door. 6. Cycle the ignition switch 5 times between the 'OFF' position and position 2,(ignition 'ON', all dash warning lamps will illuminate). The red status LED will illuminate continuously, and the siren will 'chirp' once, to indicate that the code-learning mode has been initiated. ?Do No start the engine.? The Ignition switch cycling in step #6 must be performed within 10 seconds. The sequence in steps #1-#6 must be performed within 45 seconds. REGISTER/DELETE ID CODE(S) 7. Open drivers door, (remain seated in the drivers seat) 8. Close the drivers door. 9. Press and release any button on the remote you wish to register in the system. The status LED will shut off momentarily to indicate that one code has been registered. 10. Repeat steps 7 thru 9 to register the three ID codes. It is possible for the system to memorize a total of 4 different ID codes. As a new code is initialized into the memory, the oldest code is automatically deleted. If you had lost your remotes and wished to delete the lost remote ID codes from the memory, you could initialize the ID codes from a newly purchased replacement transmitter four times thereby deleting the previous ID codes from the system memory. EXITING CODE - LEARNING MODE: 11. Open drivers door, and exit from the vehicle, leaving the door opened. 12. Close trunk. 13. Close drivers door. The LED will turn off and the siren will 'chirp twice. 14. The initialization procedure is now completed; Test all remotes to confirm operation. If this doent work your alarm/central lock needs to be reset
Mar 28, 2009 | 1996 BMW 318
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
