Question about Sharp Audio Players & Recorders
Instructions mdlp minidisc player - Sharp Audio Players & Recorders
you need to push the button longer so it will wind. remember short push is next or back track and long push is winding
Sep 25, 2013 | Sony Audio Players & Recorders
My Teac MD-H300 minidisc player will not read discs, comes up no disc
Doe the deck play LP discs or only SP discs?
My impression is that it does not support MDLP - which I suspect is your problem.
Does it play discs recorded on that machine?
Let me know if that solves it. If not, I have other thoughts.
Mar 21, 2013 | Audio Players & Recorders
Mz-r500
If you don't tell us what the problem is .....
Feb 18, 2013 | Sony Walkman MDLP MZ-G750 Recording...
Teac md-h300
There is no unit with the name you gave.
Does the unit itself say MDLP on it? If it doesn't, theres a good chance it doesn't support the LP modes and will only playback/recor unit only plays in SP or MONO.
Sep 19, 2012 | Teac MD-H300 Personal MiniDisc Player
Where can i buy this product?
Enter "Sony Mz-b10 " into a search engine. eBay has one.
Jul 29, 2011 | Sony new- Mz-b10 Mdlp Minidisc Recorder...
Suddenly the record button won't work...it just won't depress or light up...it has always work so well. Can you tell me what the problem is?
check your disc - do you have the little tab slide over to prevent recording? (like a cassette has on the top)? Also, very important with MiniDiscs, or home CD recorders, when you press STOP, you still need power for another 30 seconds or so for the unit to write the TOC - table of contents. Without the TOC, your disc cannot find where anything is. So , make sure you have a FRESH battery and/or AC adapter when recording. Try a new blank disk with fresh batteries, okay?
Jul 03, 2010 | Sony new- Mz-b10 Mdlp Minidisc Recorder...
IAM LOOKING FOR THE PRICE OF A COMPLETE MINIDISC MECHANIC UNIT FOR DENON MINIDISC RECORDER MODEL.DMD 1000 VERY URGENT.
Sorry, but it's around twelve years old and spares are no longer available. The only fix is to trplace it with another used MD deck.
You can see the specs of yours and compare it to others at MiniDisc.org, later models are far better as they have MDLP capability and some even have NetMD functions for digital file transfers onto MD's.
Feb 04, 2010 | Denon DMD-1000 Mini Disc Player
Din Unlock - Unable to record
You must have the unit switched to "DIGITAL" input - switch it to "ANALOG" and record that way. The "DIN UNLOCK" is when you have the lack of a proper digital signal, or a digital signal with copy protection, like you cannot make a digital copy of a digital Minidisc, etc...Does that make sense? Let me know if the "Analog" setting works for you. Good luck.
Nov 07, 2009 | Sony MDS-JE330 Mini Disc Player
29 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
