Question about Singer Sewing Machines
Need to replace foot pedal for SINGER 401 g13
Foot pedal broken need replacement
5 Suggested Answers
SOURCE: replacement foot pedal and wiring for Euro Pro
Here's a place that carries all the pedals. Many are used by various brands, and go under different names for different machine companies. The euro-pro manual has the manufacturer's name and the model #, or you can browse the drawings of pedals to match your own. My euro-pro 9110 uses a model also used by viking and huskevarna. This place carries the cords as well.
Good luck.
http://sewingmachine221sale.bizland.com/store/page36.html
Posted on Jul 26, 2008
  • 4 Answers
SOURCE: Need to find replacment for foot pedal.
Try calling EURO- PRO X Shark at # 1-800-361-4639. They are VERY helpful!
Hope this helps!!
Posted on Aug 21, 2009
SOURCE: just bought a used model singer 6233 need to know
The Singer 6233 was one of the models that briefly were made using air-powered foot controls. So you aren't looking for a traditional electrical connection. Instead, your pedal cord's female end will connect onto a black male nipple, that sticks out on the right side of the machine (the side with the handwheel). Just push it on until it feels snug.
Posted on Jun 01, 2010
SOURCE: wiring a foot control pedal for Singer
I have a singer advance 7422 and the outlet for the foot controller is kind of broken. A few days ago a little round black thing fell out of the outlet and now when i try to connect the foot controller it is very loose and the machine doesn't run. what should i do?
Posted on Jun 28, 2011
I have a "singer" sewing machine, model 1022. Everything was working fine but now the foot pedal won't work. How do I take this apart to repair? How/Can it be repaired?
If you're unsure how to repair it, take it to a repair shop. You can cause more damage trying to fix something, plus parts may be hard to come by for the consumer.
Jun 23, 2016 | Sewing Machines
Do you have a foot pedal for Singer 2210?
Your foot pedal works on several models of high-end machines, including a Bernina. Unfortunately, while you can easily purchase a replacement at several sites, it's pricey. However, I took a look on eBay, and there's one for sale there for $50, which is much better than $149, which is the list price. Here's the link
http://www.ebay.com/itm/Singer-2210-Quantum-DSX-DSX-II-LE-XL-1000-XL-5000-XL-6000-Foot-controller-/261741269436?pt=LH_DefaultDomain_0&hash=item3cf0fed1bc
Jan 21, 2015 | Singer Sewing Machines
Where can I find a power cord for singer simple 3116 sewing machine?
It looks like your power cord and foot pedal are incorporated into one unit, and you'll have to replace the foot pedal to get it. You can get it for $30 at sewing parts online, http://www.sewingpartsonline.com/singer-3116-simple-sewing-machine-parts.aspx?gclid=CLTXmrLC18ECFeHm7AodBioADg, and you can also get them from eBay by doing a search on Singer Simple 3116.
Oct 16, 2014 | Singer 3116 Simple
How fix singer foot control fuse broken lots little discs fell out of control
You didn't specify a model, but foot pedals are generally used by a wide variety of models of machines. Go to eBay and enter your machine's model number, and you'll probably see foot pedals for your model of machine for sale.
Aug 11, 2014 | Singer Sewing Machines
Need foot pedal control for singer 766
try calling or email these sites and ask them about the part
sewvacdoctor.com
a1sewingmachines.com
Feb 10, 2013 | Singer Sewing Machines
How to repair a non-working foot peddle on a Singer 6215C
There are a few things you can do. If you are even a little technically savvy, UNPLUG the sewing machine then take a detailed look at the pedal cord from the pedal all the way to the machine and check for any damage, pinch points, etc. If it all looks good, you should be able to open the foot pedal to see inside. There should be a small limit switch that actuates when the foot pedal is depressed. Manually cycle the pedal to ensure that the pedal mechanism is making contact with the limit switch. Listen to the limit switch as it should click when you first engage the pedal. I cannot tell you exactly what you would have to do to replace the pedal but after you have exhausted what I have suggested, I would take it to a sew & vac shop and they can replace it for you. It should not be that expensive. You can call one or two shops and get quotes for replacing the pedal.
Nov 16, 2017 | Sewing Machines
The foot pedal on my Singer Inspiration is stuck on fast speed.
Hi lawoffice474...
Unplug your foot pad from the machine and the electrical receptical.
Try moving the foot pedal with your hands, back and forth as if you were pressing your foot on it.
Did it loosen up?
If yes then you still need some maintenance...
If no then you still need some maintenance.
Disassemble the foot pedal and take as many pictures as you need to be able to reassemble it.
Once you have disassembled then you will look to oil (one drop max) the pivot points of the foot pedal, like the hinge assembly, reostat linkage,etc.
Once you have it oiled then try moving the foot pedal again my hand before reassembly.
If everything moves ok then your good to go...
Reassemble the foot control.
If not then its time to replace it with another foot pedal such as one of these at this webpage below:
Please take time to rate me thumbs up.
http://www.sewingmachinesplus.com/singer-foot-controls.php
Sep 10, 2011 | Singer Inspiration 4206
Wiring a foot control pedal for Singer Slant-o-Matic 401G sewing machine, banana socket. The machines listed are newer models and my 401 is not listed.
Faboulous machine the 401 and the best machine ever made, in the UK if I remember the two red wires go to the right hand pin and thw two blacks go to each terminal, when you rewire the plug which is fidly undo the stop motion, when you plug the machine in if it runs on without touching the foot control change the two black wires over, to rewire the foot control there are only two wires, you can't go wrong.
Jun 11, 2010 | Singer 7422
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
