Question about Tappan TGF320 Gas Kitchen Range
Oven thermostat - schoenberger gas system 1975
Everything on our gas stove is working, including the pilot lights. All the knobs are working on stove burners. The oven knob won't stop at the "catch" point. I was told that Tappan was bought out by Frigidaire. I believe our issue is that we need a new oven thermostat. Since this appliance is over 30 years old, is there any where on the internet to find this part or is there an equivalent part? If not, can we repair the oven thermostat and if so, how? Can you help? Thank you for your time. Sincerely, RM Kisting
  • Anonymous Mar 19, 2014
    I need to know how to put on thermostat on stove
  • 473 Answers
Will need to find the correct model # somewhere on the range then go to www.appliancepartspros.com or www.www3.sears.com and you will find it there. I found thermostats on those sites for a model # close to yours and most likely the same one. Sears was about $72 and appliancepartspros was about $78. Hopes this helps.
Posted on Oct 08, 2007
6ya staff
SOURCE:
I need to know how to light the oven? Does it have a pilot light like the stove top
most stoves do not have pilot lights but work from a pizo ignition system
when you turn on the gas knob ,the first action is to energize the pizo and that continually sparks to ignite the gas at the hob
the same is with the oven
ovens should be lit with the oven door open and once lit then the door can be closed
Jun 07, 2015 | Sears 61301 Gas Kitchen Range
Oven not working
Gas stove check gas oven safety value
Mar 17, 2014 | Ariston Technologies Ovens
I have an early 70's Magic Chef series VI oven/stove. The stove works fine. The oven takes about 30 minutes to light. When oven knob is turned pilot works fine. There is no gas odor before the oven lights.
My model is a UA119A-2W and I cannot find a place to light the oven pilot. Nor can I find a copy of the owner's manual anywhere online. Any suggestions would be appreciated.
Apr 05, 2010 | Magic Chef 31000 Gas Kitchen Range
I cant find the stove top pilot
Electric Ignition (sparking clicking noise when control knob is turned to "light" setting) do not have pilots. The spark ignites the gas.
Aug 11, 2009 | Magic Chef 31000 Gas Kitchen Range
I have a an AMANA gas stove burners work but oven doesn't
First check the book to see if you have a igniter on this stove if so it takes a moment or two to get started, if not you need to light pilot
make sure gas is getting to burner when called for by the thermostat or oven control..
Jun 11, 2009 | Ovens
Propane not getting to oven... stove top works fine..
The pilot light must be lit and stay lit before you will have any propane coming into the oven. This is a safety feature.
May 17, 2009 | Magic Chef 9122 Gas Single Oven
Garland H283 gas range. Right oven wont come on.
I just read this here:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=13&newsdesk_id=117
that explained how to test if the problem is the thermostat. It said to watch the pilot as you open the thermostat to turn on the oven. If the thermostat is ok the pilot should get bigger, if the pilot does not change when turning on the thermostat, then the thermostat is bad.
Mar 04, 2009 | Garland H283 Gas Kitchen Range
GE STOVE MODEL JGBS15GE
Often times you will have problems with the gas thermostat and not necessarily with the safety valve. Once you have lit the pilot light, turn the oven knob to any temperature. The pilot light should get bigger in size of flame. If not, the thermostat that controls the oven must be replaced. If the pilot light does get bigger, but the stove does not ignite, it is the safety valve.
Nov 12, 2007 | GE JGBS07PEAWW Gas Kitchen Range
Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Aug 14, 2007 | Tappan TGF363 Gas Kitchen Range
Tappan TGF320 Gas Kitchen Range Logo
165 people viewed this question
Top Tappan Kitchen Ranges Experts
Paul Carew
Archie Ferrarini
Archie Ferrarini
MARLON KELLER
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
