Question about HP PhotoSmart 7260 InkJet Printer
How Print index card - HP PhotoSmart 7260 InkJet Printer
How can i print on an index card
what du u mean just go 2 staples? http://www.staples.com/Index-Cards/cat_CL214476
Sep 11, 2016 | Canon Office Equipment & Supplies
Printer alignment off when trying to print to a 4x6 index cards
Use the usb port on your Surface, put the updates on a thumb drive. You should be able to reinstall drivers that way.
Aug 05, 2016 | HP Office Equipment & Supplies
Smaller items will only feed crookedly into the printer document
Check to see if you are feeding the envelopes and 4x6 cards/photo paper correctly.
Both envelopes and 4x6 cards must be loaded and centered on the paper exit tray (not inside the paper input tray).
Printing envelopes:
  • Up to 15 envelopes can be loaded at a time.
  • The print side of the envelope faces down.
  • The envelopesare centered on the paper exit tray.
  • You print the envelopes with Landscape orientation.
Printing cards:
  • Up to 35 greeting cards, index cards, postcards, or photo cardscan be loaded at a time.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
For images on how to correctly load the paper, download your printer user's guide:
http://support.dell.com/support/edocs/systems/prn946/en/index.htm
Aug 16, 2009 | Dell 946 All-In-One InkJet Printer
Want to print pictures from camera card.
I received my Brother printer today (11/5). I also go mine mainly for the scanner because my Visioneer 9320 doesn't have any drivers for VISTA, and Visioneer isn't making any updates.
My camra uses a SD card. This is how I got mine to print pictures.
I place my SD card into the printer
I then press the PHOTO CAPTURE button The display on the printer reads CONNECTING TO PC
Then the display reads PRESS (up arrow or down arrow) & OK
When you press the up or down arrow, the display will read PRINT IMAGES or PRINT INDEX
I selected PRINT INDEX and then you have to press the OK BUTTON
The printer display then will ask 6 images per line or 5 images per line.
You pick what you want then you hit the OK button.
Don't forget to put the photo paper in the tray, upside down.
Hopes this helps
Nov 03, 2008 | Brother Multi-Function Center MFC-240C...
Still no success printing from SD memory Card.
Here's what you can do. Backup your files from that SD card to your computer then reformat the card. Copy your files again to the card then try to print it.
Sep 01, 2008 | Epson Stylus RX425 Multifunction...
Reprint
The first thing to do is to set the top margin. Insert the card using the SAPI semi automatic paper insertion, pilling the rt upper bail arm forward, space up or down to the top margin you want, press & hold the code key while pulling the doing SAPI the P/W will spin and reset the top margin.
Type info on card, remove card, insert next card using SAPI, Press code and reprint key and it will repeat.
DO NOT TYPE ANYTHING AFTER A SAPI OR THE REPRINT WILL CLEAR
DickyO
Jul 09, 2008 | Lexmark Wheelwriter 10 Series II...
Printing index cards on oki printer
i changed the settings on media to rough paper & made sure all paper was to come from mp tray, but it does jam frequently, and every time it does, i need to open & re-open the front cover to get it to clear the error that appears. the error reads mismatched paper size, as there is not a custom size of small index cards of 3.5 x 5.
Mar 06, 2008 | OKI C5500n Printer
HP PhotoSmart 7260 InkJet Printer Logo
20 people viewed this question
Seeker5211
Seeker5211
