Question about HP Laserjet CM 1312NFI Color Printer
HOW TO FIX DOUBLE IMAGE ON COPIES OF AN HP LASERJET m1213nf
leroyal
  • 2120 Answers
SOURCE: how do i make double sided copies for my HP 2840
When the printer window pops up, click on preferences then features to enable manual two-sided printing.
Posted on Dec 21, 2008
SOURCE: HP Laserjet #3015. Double feeds when feeding
Separation pad (not feed rollers), is responsible for preventing double feeding. Clean or replace it.
As for toner low...hold the "go" or "online" button until both (all) lights flash then release, this should give you a supplies status page.
Posted on May 16, 2009
  • 217 Answers
SOURCE: HP 1600 Colour laserjet Double image
Colour registration problem (some printer loose their registration from time to time).
There will be an option somewhere in the menu system of the printer, or the HP 'Toolbox' to correct this.
Posted on Aug 30, 2009
  • 217 Answers
SOURCE: hp color laserjet 1600 copies have a blurred image
This sounds like a registration problem.
Use the menu (on the printer) to print antest page AND a configuration/information page.
Look (critically) at the alignment of the seperate coloure Yellow Magenta Cyan. You will probably find that these are out of aligmnent across the page.
The cause of this, is that the printer can't perform a calibration properly (printer probably takes a long time when calibrating too) and is usually down to failure of one of the sensors on the transfer belt.
Sometimes you can clean these and solve the problem, but often is a failure of the component itself. Thes are NOT available as a spare part, and the repair to correct this would need a replacement transfer belt.
Transfer belt replacement in this printer is quite an involved task, though it is within the capabilities of someone with reasonable mechanical aptitude.
Posted on Apr 05, 2010
  • 17 Answers
SOURCE: LaserJet 1020 Printer: Double Image when printing...
This more then likely need a fuser.
Posted on May 20, 2010
Scanner Error 22 Hp Laserjet M1213nf MFP printer
it is a physical broken piece that supports scanner mechanism. from what i can find. dont no if this has helped.
Jun 16, 2016 | HP Office Equipment & Supplies
How to cold reset hp M1213nf
  1. On the product control panel, press the Setup button.
  2. Use the arrows buttons to select the Service menu, and then press the OK button.
  3. Use the arrows buttons to select the Restore Defaults option, and then press the OK button. The machine automatically restarts.
Aug 14, 2014 | 2SToner HP Laserjet Pro M1213nf Printer...
How to findout how many pages printed by m1213nf MFPprinter
Press setup, select reports, press ok, select config report, press okay. A report will print out. This should have the page count on it. If not ,try "usage page" which may be listed under "reports". Good luck.
Sep 28, 2013 | 2SToner HP Laserjet Pro M1213nf Printer...
Scanner error 22 HP laserjet M1213nf MFP
Perform a power reset.
Press the Power button to turn on the printer.
With the printer turned on , disconnect the power cord from the rear of the printer.
Wait at least 30 seconds. Reconnect the power cord to the rear of the printer.
Update the firmware on the printer. I have included the url.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lang=en&lc=en&product=4075457&
May 07, 2012 | HP LaserJet M1120 MFP All-In-One Printer
Sir i have hp 2600n i have a problem my hp 2600n prints blur image or prints double image what can i do plz tell me
Try to fix the paper size from printer preferences, and check whether the printer cartridges are aligned, u can always align the printer cartridges by navigating the printer menu to the settings and then align printer cartriges. good luck
Mar 12, 2011 | HP Color LaserJet 2600n Printer
HP Laserjet 4345MFP scan to folder is too light.
make sure that you close the cover of the scanner so the original color of the image will apear on it.if you are looking the image on your computer.if the copy when you print will is light, try to change the resolution into picture quality.
Nov 15, 2009 | Office Equipment & Supplies
Apr 04, 2009 | HP Color LaserJet 2600n Printer
Hp color laserjet 1600 copies have a blurred image
Nov 24, 2008 | HP LaserJet 1600 Printer
HP Laserjet CM 1312NFI Color Printer Logo
Seeker5211
Seeker5211
