Question about Vizio Televison & Video
Visio TV error code RGB
Blue screen with RGB code then it turns off
3 Suggested Answers
SOURCE: Blue screen - no signal - turns off [visio tv L42hdtv10a]
With out turning on the T.V., Push the [Input] button on the remote control. The TV should turn on and activate the input menu, just continue to push [Input] until it is set on TV (or HDMI, etc.). this should solve your problem.
Posted on Nov 03, 2008
  • 693 Answers
SOURCE: when i turn tv on, visio 37" 64hz 1080p HDTV, it
The Vizio 1080P HDTV offers a variety of features and input jacks that make it a true multimedia centerpiece. Occasionally, however, there are a few scenarios in which the screen blacks out.
  1. Basic
    • Verify that all input cables and your power cord are firmly inserted. If you are viewing a program that utilizes RGB (red, green, blue) or HDMI cables, be certain your TV is not in sleep mode. It will time out and appear blacked out in this case. Verify your sleep timer hasn't been turned on. Try resetting the TV by turning it off for 30 minutes.
    Advanced
    • If you experience limited or no lights, the power supply is likely failing. If you feel comfortable doing so, open the back of the TV and look at the power supply area (shock hazard). Follow the power cord area to find it. Check for bad capacitors, which look like small batteries with connectors soldered to the board. They will be blown or bulged out. Replace them or the complete power supply.
    Other Considerations
    • Verify your surge suppressor is not bad. These often have a connected equipment guarantee that covers your repair if a power surge caused failure. You can reset all settings to original modes by pressing "Reset All Settings " in the Setup menu.
Posted on Oct 07, 2011
How do I get my Sony universal remote to work with my Visio tv!
On your Visio TV remote control there will be a Source button or Input button. Press it & on your TV screen select HDMI 1 or HDMI 2. See the TV to see how the HDMI cable is connected from TV to Set Top Box. Now take the other remote control i.e. Sony Universal remote in your hand. Press mute & Select simultaneously. A blue light will blink twice, Immediately release the buttons & enter the code. You have to be extremely fast in doing this.
Following are few codes which you can try:
002, 000, 011, 080, 111, 006, 071, 128, 1904, 925, 0000, 0834, 0810, 1685, 1786, 1032, 1972.
Check the Visio TV manual for the make of your TV & model no & if code is printed. Then contact Visio TV manufacturer or retailer for the Visio TV code to enter & synchronize with the Sony Remote Control.
Nov 13, 2016 | Sony Televison & Video
VISIO E550i-B2
The main board of the tv is faulty. Can be a hardware fault or software error. You have to replace the mother board or can consult the service center.
of you wish to get some details about television repair then check the following link
http://electro-medical.blogspot.com/
Aug 18, 2016 | Televison & Video
What is a RGB signal
RGB means Red,Green,Blue it is an old system for supplying video signal to a screen..
Feb 01, 2016 | Televison & Video
Visio 1080p screen went light
Our Visio 42" flat screen TV did the same thing. It didn't happen that often but sometimes it would go darker or the sound would go off until I changed the channel or turned TV Off then back On. I contacted Visio through my warranty and they sent me a flash drive to install info on my TV. Did not fix the problems. A year later before warranty ended I contacted Visio again. They sent a huge box for me to pack my TV in to send to the warehouse where they fix everything. It took about 2 wks. to get it back. Worked fine for about 4 months and the problems continued. I will not buy another Visio TV. I found out that they had many problems with several models.
May 03, 2014 | Televison & Video
My tv screen when on turns yellow then after a while it will switch back to normal colors what can be wrong with it....
Televisions covered: all Projection with yellow picture, but not Projection TVs with a yellowish tint surrounding objects in a nearly normal picture.
Yellow = red + green
normal picture = red + blue + green (RGB). See illustration.
Fig. 1 Additive color mixing in an RGB monitor, or RGB Projection TV.
The circuitry powering your blue output, or the blue light engine itself is starting to fail.
Operating Theory:
The lamp module shines a bright light into the optical unit; there are a series of lens and baffles, and at the top of the light engine, a lens puts the picture into a mirror which is reflected onto the screen; All video and color is processed thru the light engine. Blue most commonly fails first, leaving a yellow picture.
Dec 26, 2011 | Mitsubishi WS-55805 55" Rear Projection...
When i turn tv on, visio 37" 64hz 1080p HDTV, it
  1. Basic
    Advanced
Oct 05, 2011 | Vizio VX37L Television
How to turn on rgb from lap top to tv.
In order to connect your laptop to your TV using RGB, you need an RGB adapter. RGB is also known as component video; it breaks up a video signal into red, green and blue. laptops do not have RGB outputs. However, many laptops have VGA, DVI or HDMI outputs. An RGB adapter connects the single VGA, DVI, or HDMI cable to an RGB cable, which is actually three different cables tied together. INSTRUCTIONS:
1. Connect either the VGA, DVI or HDMI (in the order of increasing video quality) cable to the VGA, DVI or HDMI port on your laptop, depending on what is available. 2. Connect the other end of the cable to the side of the RGB adapter with the single input. 3. Connect the RGB cables to the red, green and blue ports on the other side of the RGB adapter. 4. Connect the other end of the RGB cables to an available component input on the back of the TV. 5. Tune the TV to the component video input you used through your television's menu. 6. Turn on your laptop. The laptop should now display on your TV screen.
May 30, 2011 | Computers & Internet
Screen turns blue after Windows XP boot. It is
You cannot set your PC video resolution to 1920x1080 @60Hz?
Per user manual:
1. Set computer to a resolution supported by your HDTV (see Preset PC Resolutions). If your
computer supports it, we recommend 1920x1080 @60Hz.
2. Turn off the power to your HDTV and Computer.
3. Connect the VGA cable from your computer to the RGB PC jack on your HDTV.
4. Connect the 1/8-inch audio cable from your computer to the RGB PC Audio jack on your HDTV.
This step is optional and only needed to transmit audio from the computer through the TV.
5. Turn on the power to your HDTV and computer.
6. Select RGB using the INPUT button on the remote control or side of your HDTV.
Note: Refer to your PC computer user manual for more information about the video output requirements.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Sep 07, 2010 | Vizio VM230XVT 23 in. TV
Oct 29, 2008 | Vizio GV42L 42 in. LCD Television
Visio TV and Direct TV remote
I bought a 42" Visio LCD from Costco and used code 10030 and it worked. It is the code for Goldstar TV.
Nov 17, 2007 | Televison & Video
Televison & Video Logo
81 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
