Question about Ricoh Aficio 450 Copier
Problem sc390-01 I get this message each 5 or 10 copies, I have to turn off the copy machine in order to make copies again, I have to do this very often..
  • 30 Answers
This code is for a TD (toner density) sensor error. It could be as simple as cleaning the TD sensor which is located in the area to the right of the drum. If you remove the drum unit, it will be in the area about 2/3 of the way toward the rear of the machine and is accessable through the right hand door that you open to remove jams and remove the drum unit. Just wipe you finger across the inboard surface of the sensor and if your finger comes back with a lot of toner on it, you've probably fixed the problem. If that doesn't fix it, you're going to have to throw yourself on the mercy of your friendly local technician as it's something that only he/she can fix. Let me know if that helps. Aloha. Bill Monroe
Posted on Oct 08, 2007
SOURCE:
Copies are faded and unreadable when printed or copied at the machine. The toner percentage is showing 25-0% but the machine is not giving a "change toner" message.
Remove the toner cartridge and tap it sharply with one hand whilst holding it with the other. Turn 90 degrees and do it again, repeat until the cartridge is back to being the correct way up.
This will often give you another hundred copies with a cartridge that 'appears' to be empty.
If that doesn't work, you will need to replace the toner,, if that doesn't work, you need a technician or a new machine.
Sep 08, 2015 | Office Equipment & Supplies
Maintenance message kept appearing but could still use machine. With info from your site, I think I cleared it. However, we keep getting a message that there is a paper jam (Jam 50). Could find nothing...
Maintenance message is setted by the technician, the numbers of copies that you can make with the same drum is limitted by the technician, (100k) if you reach this limit the maintenance message appears, you have to replace the maintenance kit (the opc drum, transfert corona, main corona) to avoid the bad quality copy. if you need to work with the machine you have to call the technician he can increase the counter limit to clear the warning message.
Dec 27, 2010 | Copystar CS-2030 Copier
Cannot get printer to copy
Start up your printer. Wait until it has powered on completely before beginning.
Open the printer's lid and place your item on the copying surface with the side you want copied face-down on the glass. Double-check the alignment.
Shut the printer's lid. For large items, such as books, you may want to remove the printer lid rather than forcing it closed .Choose the kind of copy you want: black-and-white or color. You also may have to select the kind of paper that you are copying.
Size the copy to the page if desired. Some multi-function printers allow you to expand or shrink the original to fit different sizes of paper.
Enter the number of copies you want. You may do this on the multi-function printer or in the print setup of your computer. Make sure the paper tray has enough paper to finish your copying job.
Press the "Start" button. Other names for this might be the "Copy" or "Print" button.
Remove the pages as they are delivered from the printer's feeding mechanism. Do not tug on the copies as they come out. Let them fall into your hands.
Take care.
Jul 05, 2010 | Brother Office Equipment & Supplies
On machine shows c610
sometimes, this code can be caused by a power fluctuation or outage. try this: turn machine on, press and hold these keys in this exact order. "stop/reset", "start" and then "left copy exposure" key. let up and quickly hit "stop/reset" again. at this time you should be in the maintenance mode and see "U000" on display. next, using the "zoom" keys, go to "U163". then press "start" and you should see "CLE". press "start" again. then press "stop/reset" twice and you should see "U000" again. press right "zoom" key to go to U001 and press "start" to get out of maint. mode. turn copier off, wait 3 secs. and turn back on. if message comes back, you truly have a bad fuser, but my experience is you'll be back up and running.
good luck,
razors
Jun 10, 2010 | Copystar CS-1510 Copier
I get an E140 error message when I turn on the copier
Hello sir; The error code you display it means optics fan not working you have to replace it.
Aug 28, 2009 | Panasonic FP-7735 Black and White Copier
Scanner failure
Solution one: Check the scanner light Make a color copy of any document by pressing the Start Copy Color button on the product control panel. While the product is making the copy, lift the scanner lid slightly to see if the scanner light is visible.
  • If the scanner mechanism moves across the scan bed, but the light is not lit, proceed to Solution six: Service the product .
  • If the light is lit, proceed to the next solution.
Solution two: Check operating conditions Extreme temperatures can affect the operation of the product. Make sure the operating conditions match those recommended in the User Guide provided with the product. Solution three: Check the power connections
  1. Make sure that the part number on the power supply matches the part number listed in the User Guide .
  2. Disconnect the power cord from any power strips or surge suppressors, and then plug it directly into a wall outlet.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the copy job is successful, you do not need to continue troubleshooting.
  4. If the error message displays again, temporarily move the product to a different room, or plug the power cord into a different wall outlet.
  5. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the error message displays again, proceed to the next solution.
Solution four: Perform a power cycle
  1. Turn the product off.
  2. Unplug the power cord from the product.
  3. Wait 30 seconds, and then connect the power cord to the product.
  4. Turn the product on.
  5. Make a color copy by pressing the Start Copy Color button on the control panel.
Solution five: Reset the product Follow these steps to reset the product. Step one: Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
Step two: Perform a semi-full reset
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
call in to hp at 1800-474-6836 and since this is a hardware issue directly tell the agent you would like an upgrade if you decide to get it.
It will have a 50% discount on the upgrade printer for you with hardware and software covered by a one year warranty which you can extend upto 3 years on the spot
Jun 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Sharp AR-5316 F5 ERROR
check the exsposure lamp this error relates to damaged or blown lamp also you check this when you turn th ecopier on you should see it self test at hte start up if there is no light it has blown or connections are bad
Jun 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Savin 4035Esp - Functional Problem Message with Code SC863
Hello sir; SC 863 means your copier hard drive not good,you need to replace one. can't repair.
May 15, 2009 | Ricoh Office Equipment & Supplies
Copy feature doesn't make copies
  1. Turn on the HP All-in-One.
  2. Disconnect the power cord from the back of the unit.
  3. Press and hold the # and 3 buttons simultaneously.
  4. While still holding down the # and 3 buttons, connect the power cord to the back of the unit.
  5. Continue holding the buttons until the Power button blinks.
  6. Follow the instructions that display on the unit to select the language settings.
Then when that's done, try printing, or copying items. If its still not working, check the ink and change those out and this should fix it.
May 11, 2009 | HP PhotoSmart C4180 All-in-One Color...
I have a xerox dc12 with error message please turn machine off and on again 9-363 have tried several times but no good! what else can I do?
That's a process problem with that machine.
May require a service call .ON and OFF is pretty much all a customer can do and wait for it to setup.
NOTE: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
Apr 28, 2008 | Xerox DocuColor 12 Printer
Ricoh Aficio 450 Copier Logo
1,138 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
