Question about Toshiba E-Studio167 Copier
"Set Process Unit" error
My Toshiba E-Studio167 Copier in showing the error 'set process unit' in the display sometimes when I try to use it
    Champion:
    New Friend:
  • Toshiba Expert
  • 253 Answers
Checked the Developer unit connector is disconnect
Posted on Jul 19, 2016
  • 33 Answers
SOURCE: error c7
You can reset the C7 code, hold down 0&8 power machine up. Then push 87 & print, change the number to 0 with number keys press interupt key, then press 0&9 @ the same time to exit. This should clear the C7. Let me know if you need more help.
Posted on Oct 27, 2007
  • 653 Answers
SOURCE: toshiba 160 error code
For error code C44, it indicates Heater abnormality.
If 1st time occur, u can just go to 08-400, reset the value to "0" then restart the machine.
If happen again, then u need to check the thermistor. Replace it if necessary. If themistor replaced but still happen again, then u need to proceed to check themostat--> heater-->Mainboard-->Switching regulator.
Posted on Mar 09, 2009
  • 653 Answers
SOURCE: display F120 error in my Toshiba etudio 230
F120 indicates database abnormality.
What u can do:
1. Rebuild the database ( 08-684 )
2. If the error is not recovered, initialize the HDD. (Enter “2” at 08-690.)
PS: Press "0+8" & ON the machine in order to enter setting mode.
Posted on Jul 29, 2009
  • 37 Answers
SOURCE: error code F-35-1 in bizhub 7145 copier
quote is probably in the right price range. you need to look at how many copies are on your machine. look at any future repairs/supplies that will be needed. like drum, developer unit. If these are also needing to be changed soon, you will have to plan on those costs also. Any comparable machine that you get get will be expensive to repair the big items. You have to put all of the money that you spent on the machine and find out how many copies you have made. you can then figure out the cost per copy. At the same time, if this machine does everything that you need from a copier, do you want to buy a new one at much higher cost.
Posted on Oct 17, 2009
djuksoni
  • 103 Answers
SOURCE: how do I create/set up the IP address for a
On control panel press "user functions" , then select admin tab, press password and type password (default is 123456),press network and then ipv4. There you need to type in free IP address, subnet mask and gateway.
For more ask your network admin.
Posted on Oct 27, 2009
Studio 167 error code
press c and 8 simmilutery then you see error code
Jan 27, 2014 | Toshiba E-Studio167 Copier
Toshiba E studio 207 C97 error solution
sir i have Toshiba 207 copier sir now write on screen call for service C97 PROBLAM
Jun 22, 2012 | Toshiba E-Studio167 Copier
'call for service C97' appearing on screen with RED light flickering
C97 indicates charging issue. U need to check/clean the main charger and T/S block unit.
Aug 17, 2011 | Toshiba E-Studio167 Copier
Cannot load drivers for printing toshiba e-studio 167
if connect to usb cable, then u need to install usb driver b4 installing printer driver
May 26, 2011 | Toshiba E-Studio167 Copier
When start machine then display shows call for sevice F14
F14 Scanner unit FROM error
Was the main PWA replaced?
YES
Download the scanner total count value into the main PWA in the setting mode (08-388).
NO
Was the scanner unit or scanner control PWA replaced?
YES
Download the scanner total counter value of the main PWA into the scanner control PWA in the setting mode (08-389).
NO
1. Check if each connector between the scanner control PWA (CN6) and the main PWA (CN8)
is disconnected.
2. Check if each connector pin is removed or the harness is broken.
3. Check if any conductor pattern on the scanner control and main PWA is open- or shortcircuited.
4. Replace the scanner control PWA.
5. Replace the main PWA.
Nov 17, 2010 | Toshiba E-Studio167 Copier
Toshiba e-280 shows F-120 error code, i dint find this error in my service hand book. any suggestion to overcome this problum.
[F120] Database abnormality
What you can try to do is go into (08) mode by holding the 0 and 8 keys while turning on the copier. Once it comes into test mode key in 684, this rebuilds the databases. If this doesn't fix it go into (08) mode again and key in 690 and press start, key in 2 and just hit start again. This formats the HDD and hopefully the copier will work after that. If not you will likely have to replace the HDD.
Note: When you format the HDD it clears out only information such as address book and templates.
Sep 10, 2010 | Toshiba E-Studio167 Copier
I cannot print from a network system. it is installed in that system and no error is coming, but no printing taking place. pls help me to solve the prob. thanx
always replace the network cable to rule it out. Check your neck for activity lights, and try pinging to your unit by using the ip address
Oct 20, 2009 | Toshiba E-Studio167 Copier
My Toshiba e studio 167 is showing a c44 error code. What should I do?
the c44 error is an error in the fuser if you know how to take the fuser out check for toner buld up on the thermistors.. the sensors with the thin strip that presses against the hot roller gets toner build up and cant read temp properly.. you could also try turning machine off and then on whilst pressing 1 3 and * buttons together this might reset it temporarily for you.. Good Luck A
Jun 30, 2009 | Toshiba E-Studio167 Copier
Toshiba E-Studio167 Copier Logo
493 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
