Question about GE Microwave Ovens
Jvm230bl001 what size is this unit
How do I replace the line fuse?
Deborah,
Unplug your unit and turn it around and take out the screws holding the cover on. Remove the cover, and then look for where the power cord goes into the unit and follow the black wire from the power cord to where it terminates. It will usually terminate at a circuit board where the fuse will be mounted or it will terminate at a fuse holder. Remember to use the same size fuse that you remove. You will find the size stamped on one end of the fuse. Hope this helps!
Jun 05, 2015 | GE JVM1490 Convection/Microwave Oven
I am looking for a replacement for this item.. Need same size.
Good Afternoon Howard, thank you for your post!
I am happy to assist you. I understand you are seeking the exterior dimensions on your Frigidaire microwave, FMV157GM. The unit itself has a width of 29-7/8 inches and the height of 16-1/2 inches. The unit has a depth of 15 1/32 inches. I hope this information helps to some degree. If I can be of further assistance, please feel free to reconnect.
Nov 17, 2013 | Frigidaire FMV157GM Microwave Oven
Is the GE JE1640WA microwave still available? If not what is the compatable size microwave?
Sorry to read about your problem, I hope this helps you out.
your present unit is 1.4 cu ft capacity.
so just google, 1.4 cu ft microwaves
Exterior Depth 17.25 in.
Exterior Height 12.63 in.
Exterior Width 21.88 in.this is the size of your unit
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 01, 2011 | GE JE1640WA/GA Microwave Oven
Howw do I know the correct size in order to purchase the correc pars? for example how do I know the capaciy of my unit? does the max mark indicate the no. of quarts?
it should be in your units manual. if not you can go to the manufacturers website and look up information on it. if you tell me what model you have, i can help you more.
Dec 06, 2010 | Microwave Ovens
Surface Light Bulb burned out where can I purchase new one. Model ge #JVM230BL001 Spacemaker
most hardware stores/home centers carry them,you will need to unplug the unit and you should be able to access the lamp and unscrew it from inside the cooking chamber near the top of the cavity,you may need to remove a screw holding the cover first
Jun 25, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
15A breaker tripping; Is this the right size breaker for the unit?
The breaker is sized according to the size of the wire used in the circuit. The breakers task is to protect the wire from an over current.
The allowed sizes are
#14 wire .... 15 amp breaker
#12 wire ..... 20 amp breaker
#10 wire .. 30 amp breaker
To check if the oven and circuit are compatable .. run an extension for the oven to an outlet outside the kitchen and see if it holds.
Please Vote !!
Mar 08, 2010 | Hotpoint RVM1435 Microwave Oven
Microwave shuts down after 3 seconds
you need a new magnetron and inverter board, this is an expensive repair, unit can be replaced with panasonic parts or replaced with same size panasonic unit
Jul 17, 2009 | Thermador MBBS Microwave Oven
What cause the wattage difference?
Wattage is based upon voltage & current. I would think that on the 1300W unit, either the voltage or the current is higher than that which is used on the 1200W unit.
Perhaps the magnetron in the 1300W unit is being driven harder. Are the fans the same size?, The magnetron in the 1300W could be running harder and they have a larger fan in it.
In any event, if the part numbers are the same, you should have no trouble using one units parts to fix the other.
- Jim
Feb 17, 2008 | Panasonic NN-S561 Microwave Oven
Microwave Ovens Logo
61 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
