Question about Texas Instruments TI-Nspire Graphic Calculator
Solve option on TI iNspire not available as the option is not highlighted in the menu
  • Texas Instru... Master
  • 7,993 Answers
Asking the question twice is not going to help have a solution. What helps is clear information about what you were or are trying to do. As in the computer, certain menus are contextual: they are only available if the context (the action) is appropriate.
Posted on Nov 19, 2013
Solve option on Ti iNspire calcuator not available - not able to use
Nov 19, 2013 | Texas Instruments Office Equipment &...
How do i do a hard reset on my htc inspire
  1. Power off the device.
  2. Press and hold the Volume Down and the Power Button until you see the HTC logo, followed by white screen with text and a few menu options.
  3. Press the Volume Down button to scroll down till you highlight "Factory Reset".
  4. Press the Power button to restore your phone to factory settings and also your phone will restart.
Aug 01, 2011 | HTC Inspire 4G Smartphone
How do i reset the RAM on my t9-84 graphing calculator
Try this:
1. Turn the calculator on and press the "2ND" button followed by the "+" button (to open the memory menu)
2. Scroll down to menu item number 7 (Reset) and press "ENTER"
3. Highlight the first option (All RAM) and press "ENTER"
4. The calculator will then ask if you would like to reset your RAM. Select option 2 (RESET) and press enter.
Hope this helps!
Apr 15, 2011 | Texas Instruments TI-84 Plus Calculator
The axes have disappeared in graph
I would try making sure they aren't turned off. Do this by pressing [star] [y=] this will take you to the y =
page, then press [f1] arrow down until format is highlighted and press [enter], this should open up a menu
with "axes........." as one of the options use the arrow keys to highlight the axis option and press [enter]
this will open up a menu to turn the axis "on" or "off", highlight "on" and press [enter]. Press [esc] to exit
the menu.
Mar 07, 2011 | Texas Instruments TI-89 Calculator
Why will my Ti-Inspire not turn on. Does it take
Can you describe more in details.Like did it turn on before?
Aug 02, 2010 | Texas Instruments TI-Nspire Graphic...
I cannot figure out how to solve factorials on my TI-83 Plus.
Enter the number whose factorial you want to calculate.
Press the [MATH] key under the [ALPHA]key.
Press the Right arrow 3 times to highlight the [PROB] menu.
Select option [4:!]
Press [ENTER
Note : Due to memory limitation, the argument of the factorial function must at most be equal to 69
Jul 15, 2010 | Texas Instruments TI-83 Plus Calculator
How do I solve a polynomial equation: x^4+5x^3-3x^2-43x-60 on a TI-83 plus graphing calculator?
Sorry, but what you wrote is not an equation but a polynomial expression. You want to solve the equation x^4+5x^3-3x^2-43x-60 =0.
The solve( command, can only be used with real numbers.
The solve( is available through the CATALOG : [2nd][CATALOG], scroll down till you reach the command. Highlight it and press [ENTER]. The command echodes on main screen as solve( .
You complete the command by entering the expression (not the equation), the name of the variable you solve for, the initial guess , and { lower limit, upper limit} between curly brackets, and the closing parenthesis.
Exemple:
solve (x^4+5x^3-3x^2-43x-60 , x,0 {-5,0} ) [ENTER]
should give you the negative root,
solve (x^4+5x^3-3x^2-43x-60 , x,0 {0,5} ) [ENTER]
should give you the positive root.
It is implied that the expression is 0, so you should not insert =0, otherwise you get an error. Here for the lower limit is -5 you must use the change sign symbol (-) under the 3 key, not the regular MINUS.
You may ask how I knew that there were two roots when the equation is a quartic? By first graphing it to have an idea about where the roots lie and how many there are. You should always do that to speed up the search.
There is another way to zoom in on the roots: by drawing the graph and using the tools accessible under the [2nd][CALC] menu, namely the option [2:Zero]
The resolution of the TI83/84 is not good enough for this function that grows too fast, but I am inserting a picture of the curve from another calculator with a much better resolution.
Hope it helps.
Oct 18, 2009 | Texas Instruments TI-83 Plus Calculator
Havent used my ti-inspire since last school year.wont turn on
Here is what the TI knowledge base says about a calculator failing to turn on
For the TI-Nspire™ Family:
  1. Remove thekeypad (for TI-Nspire) or the battery door (for TI-Nspire CAS) andremove at least 1 battery from each column of batteries. After 2-5seconds, reinsert the batteries and turn the unit on. This will causethe unit to reboot the operating system.
  2. Remove the keypad(for TI-Nspire) or the battery door (for TI-Nspire CAS) and remove atleast 1 battery from each column of batteries. After 2-5 seconds,reinsert the batteries and LEAVE THE UNIT OFF (do not turn on and thenback off). Hold down [Home] [Enter] [P], and while holdingthese keys, press [On]. The device will boot up as in the previousreset, but will display a menu with the following options. Please tryoptions 1, 2, 3, and 4 in that order. ** The [Home] key is located atthe top right of the TI-Nspire keypad and has a picture of a house onit.
Note:TI-Nspire family model options 2 and 4 above require that the OS be installed. The reset menu will only display if the unit is off and batteries have been removed/replaced as described above.
1. Cancel - The most non-intrusive reset option; no changes are made, the unit restarts.
2. Delete Operating System – The operating system will be deleted without deleting any documents.
3. Delete Document Folder Contents – This will delete the user’s documents, but will not delete the OS.
4. Complete Format – This will delete the OS and all documents for a total erase of memory.
Hope it helps you solve the problem.
Aug 30, 2009 | Texas Instruments TI-Nspire Graphic...
I GRAPH THE EQUATION BUT I CANNOT SEE THE COORDINATE PLANE HOW CAN I FIX THIS
Easy:
"2nd" "ZOOM" (So, the "Format" menu)
Make sure CoordOn is highlighted as well as "AxesOn".
Defaults:
(These should be highlighted on this menu)
RectGC
CoordOn
GridOff
AxesOn
LabelOff
ExprOn
Just make sure all of the first options for that menu are highlighted, and your problem should be solved!
Apr 21, 2009 | Texas Instruments TI-83 Plus Calculator
Graphing Problem -URGENT-
The problem is causedby an application called "Inequalz".
To solve the problem, go to the Apps menu and select Inequalz,
then select "quit Inequalz".
This should solve the problem.
Gr. Marijn
Nov 10, 2007 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-Nspire Graphic Calculator Logo
24 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
