Just bought a panasonic 42 plasma and a pioneer 8.1 surround system. using optical cable and setting imput on amp to digital has no sound but if i use rca's and switch to anolog input on amp settings i have full sound. I'd prefer to use optical cable for sound quality. checked all settings and everything seem's correct. thanks
SOURCE: Connecting DVD player to AV receiver
If you've done that already and still no response from your system, I would suggest to take back to the place where you bought it and ask them to check it for you. Tell them that you follow the user's manual to the "T" but still unable to make it work.
Good Luck.
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
SOURCE: Lost 3.2.1 surround function when I hooked up new plasma
HDMI cables contain both your audio & video in one cable. Remove your optical cable from the box and disable in in the cable box menu and that should fix your problem.
SOURCE: RXV 1500, I am unable to get 5.1 audio
Just got off the phone with Yamaha customer support, who were very helpful. The display on the amp, in the lower right hand corner, displays the source input, not the output. So, for example, you can be watching cable tv, and the cable tv is sending a 2-channel stereo signal to your receiver. Your amp shows only L and R. But since it has a processing system, depending on the processing program you have chosen it will probably distribute that sound to all five speakers. You will be confused, because you hear sound from all speakers but you only see L and R lit up. You will believe that you are not getting 5.1 sound. And you will be correct: you aren't, because the source is not sending you a five-channel signal. That's where I got panicked. So the Yamaha representative said, insert a DVD that you absolutely know contains a Dolby Digital audio. I inserted Shaolin Soccer DVD, went straight to a scene in the middle, and bingo! The center and surround right and left speaker lights lit up! So there is the 5.1 surround sound. It will light up when it detects that kind of sound from the source. Otherwise it will probably give you a sort of "fake" 5-channel sound that it creates from a 2-channel source.
Now the question becomes, are your connections getting the 5-channel sound to the amp correctly? I just confirmed that my DVD, connected with a Coaxial cable to the Yamaha, does get 5.1 surround sound, if the sound is encoded in the DVD. I have not tested this yet with video games or Blu-Rays; I will post again if and when I confirm that this works on a PS3.
To enjoy sound from the TV (Page 29)
AUX*1: When using an Audio cable
ARC*1: When using an HDMI cable
(Available when using an ARC
compatible TV)
DIGITAL IN*1: When using an Optical
digital audio cable
And from Page 29
Turn on your TV and select the appropriate audio input mode
[AUX, ARC, D-IN] to suit the connections to this unit. (Page 22)
Page 30 details how to set the audio link.
Setting the audio link with the TV
With the remote control;
Select the actual TV audio connection on the main unit.
1 Press [START] and press [3, 4] to select "Other
Functions" and press [OK].
2 Press [3, 4] to select "Setup" and press [OK].
3 Press [3, 4] to select "TV / Device Connection" and press
[OK].
4 Press [3, 4] to select "TV Audio Input".
5 Press [2, 1] to switch "AUX","ARC" or "DIGITAL IN".
Select "AUX" or "ARC"*1 in "TV Audio Input" when the
DIGITAL AUDIO IN terminal is used for the STB
connection.
Whenever the connection or settings are changed, reconfirm
the points above.
Please leave feedback
Cheers
Andy
Same problem!!!!
I have the same problem on my 1706. None of the digital inputs work coax or optical. to troubleshoot, I successfully reset the microprocessor but received the following error on the "Automatic setup" - "Caution:SP None" . There is no test tone.
All of the these features did work at one time & suddenly stopped.
i recently purchased a sony playstation 3 mainly for its blu ray player...when hooking up my optical cable from my ps3 to my yamaha reciever, i cannot get any sound from my speakers.
same problem too no solution?
I have recently tried to connect my PS3 to my Denon AVR-2803 via optical cable. No sound! I carefully set the PS3 audio setting to OPTICAL and set my Denon source (v.aux) to OPTICAL 1. There is no "digital" display on the the Denon...just "analog". When plugging the RCAs into the Denon everythings works fine. However, I was looking forward to the best possible sound via the optical cable.
I've been having the same problem, except I'm using a PS3. I have the PS3 audio set up for the optical audio out. I switch the input on the receiver to optical and after a few seconds the display switches to (unlock). I'm thinking that the optical is locked. If so how do I unlock it? I've searched the manual for something about unlocking anything and no luck. Any help?
cbrubaker
I've the same problem with my ps3 and vsx-d510.
my optical digital audio used to work but stopped working
my digital optical audio used to work but now I have to use RCA to get sound.
surround sound works for stero but not for tv? help
