Question about HP ProCurve 2124 (J4868A#ABA) 24x10/100 Mbps Networking Switch
What is the default ip address for the procurve 2124
  • 345 Answers
Procurve switches do not have a default IP address. you must put an IP address on the switch. You can find a manual for your switch at http://www.hp.com
Posted on Nov 21, 2014
5 Suggested Answers
  • 624 Answers
SOURCE: Help with hub Procurve Hp j3294a
These are non-manageable switches, not configurable thus no IP. You should be able to plug it in to your home wiring, however, if you don?t have a server or dhcp server you will have to assign IP addresses to your computers and other network devices manually.
Posted on Jan 01, 2007
  • 25 Answers
SOURCE: HP procurve 2124 (j4868a) noisy fan
This switch has a lifetime warranty. Call HP and they will have a fan or new switch for you the following day.
Posted on Apr 14, 2010
  • 53 Answers
SOURCE: What is the default IP
check out the HP website. HP has a lot of very good resources for all of their products. here is the link:
http://www.hp.com/rnd/support/manuals/2650_6108.htm
hope I could help you out on this.
Posted on Oct 21, 2010
  • 378 Answers
SOURCE: cannot ping hp procurve 2900 48 port switch
are you accessing this switch from the management VLAN? I believe this switch you will need to assign it in the CLI/Menu.
Posted on Apr 25, 2011
What is the default IP of HP ProCurve 2510-48 ?
There is no IP address when the switch ships from the factory. It is set by the user and/or the network by DHCP. If you do not know what the IP address was set to, then you'll need to return the switch ti it's factory default configuration. There should be information in the manual for the switch about the default config.
Jul 02, 2014 | HP ProCurve Computers & Internet
2626 default ip procurve
HP 2626 do not have a default IP address, you have to set the IP address on an enterprise class business switch. You can find the manual for your switch at http://www.hp.com
Dec 23, 2013 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
Default ip procurve 2510 48
there is no default ip address on a procurve switch. you have to put an IP address on the switch. You can find a manual for your switch at http://www.hp.com
Oct 12, 2013 | HP procurve switch 2510-48
J9400b defult ip adress
There should be no default IP address on a 2626 switch. HP Procurve switches are setup by default to get an IP address by DHCP. To execute the factory default reset on the switch, perform these steps:
  1. Using pointed objects, simultaneously press both the Reset and Clear buttons on the front of the switch.
  2. Continue to press the Clear button while releasing the Reset button.
  3. When the Self Test LED begins to blink, release the Clear button. The switch will then complete its self test and begin operating with its configuration restored to the factory default settings.
Be aware, using these instructions will wipe out any configuration you have on the switch
Good Luck
Jan 21, 2012 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
Mar 08, 2010 | HP ProCurve 24x10/100 Mbps Networking Hub
3 vlans, data,1; data 2,;voip,5. Ports carry voice tagged, and data. currently Windows 2000 DHCP server lives on Vlan 1 (AND WORKS). Need to upgrade. When we test the new servers we are unable to make both...
Here's what you need to do:
First, be sure to assign an ip address(in the proper subnet) to each VLAN.
Second, use the ip helper-address command in the context of each VLAN, the address used should be the address of the DHCP server
Third, Add a scope for each additional VLAN on the DHCP server.
The switch will route the DHCP request to the proper server based on the ip helper-address command parameter and based on the ip address of the VLAN that is passed tot he server, a DHCP address in the proper subnet is automatically configured.
Here is a sample:
ProCurve Switch 3500yl-24G-PWR# configure
ProCurve Switch 3500yl-24G-PWR(config)# vlan 33
ProCurve Switch 3500yl-24G-PWR (vlan-33)#ip address 192.168.33.254/24
ProCurve Switch 3500yl-24G-PWR (vlan-33)# ip helper-address 10.1.2.250
Aug 06, 2009 | HP ProCurve 4104gl Networking Switch
How to assign IP address to HP procurve1800 switch?
The 1800 series do not have CLI so you should connect directly to any RJ-45 port.
I quote from the installation guide:
"In the factory default configuration, the default IP (Internet Protocol) address of the switch is 192.168.2.10 and the subnet mask is 255.255.255.0"
So set your PC IP address in the same subnet and access it through your web browser. If it has not the default configuration, interconnect the switch ports 1 and 2 and reboot it.
Hope this helps,
take care
AFO
Dec 31, 2008 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
Procurve 2626 installation
You'll need to obtain a comms lead - connects into the console port of the switch then into an RS232 port on your laptop. Then, you will be able to connect using hyper terminal and you can give the switch an IP address, username, etc. Even a hard-reset won't allow you to configure an IP address as by default it needs to be configured through the lead. Will they not talk without being configured? If you just hard reset them, they should just behave as unmanaged switches.
Aug 14, 2008 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
Dec 14, 2006 | HP ProCurve (J3294A) 12x10/100 Mbps...
HP ProCurve 2124 (J4868A#ABA) 24x10/100 Mbps Networking Switch Logo
492 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
