Lcd tv lg42500
Standby light is on,when switching on red flashes 3 times but wont switch on
SOURCE: sony tv wont start up???
Have the same problem.
It was 5 blinks
Posted on Jun 18, 2008
SOURCE: bush lcd 27006 standby flashing
Yeah your psu needs new capacitors.
Posted on Sep 21, 2008
SOURCE: TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Posted on Dec 05, 2008
welcomejee
  • 10594 Answers
SOURCE: My TV (Sony Bravia LCD KLV-32S310A) goes of after
6 times blink shows problem with back light inverter board.
TV requires back light inverter board replacement. If you have electronics repair experience and want to repair TV by yourself, let me know to guide you part purchase.
Posted on Apr 13, 2009
ginko
  • 19396 Answers
SOURCE: Standby Indicator flashing SONY KD-32NX100U
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1Theinternal circuits are jammed because of electrostaticcharges accumulating on capacitors, or because of a wrong voltage readby the main chip on your monitor controller board. this started theprotection circuit.
2 The protection circuit detected a wrongvoltage or abroken contact, identified an internal fault and kicked in, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Payparticular attention at inverter and power board, power board can beinspected looking for bulged or leaking capacitors, then tested with amultimeter. The inverter is more difficult to test , there is need toread voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
Why won't it turn on?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Dec 14, 2015 | Toshiba REGZA 52RV530U LCD TV
Hatachi 32 flat screen wont come on standby light flashes blue and red
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Dec 01, 2013 | Philips 37PF7320A 37 in. HD-Ready LCD...
Tv wont power up Standby light keeps flashing.
First step in any Sony LCD projector repair is bulb or lamp replacement. Fixes 95% of problems.
Taking apart and trying to measure things without a known good bulb is a waste of time and effort.
easyab
ConvergenceRepair.com
Feb 26, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Red standby light flashing wont do anything
turned on and off at mains switch 2 or 3 times light stopped flashing and tv now working alright
Jan 27, 2010 | Philips 32PW6506 32" TV
The tv will turn on but no the screen wont. and
Replace the lamp would be the first thing to try. Lamp door switch on this model is notorious for going bad. If you replace lamp and still won't turn on jumper door switch. If you take off back you can see switch board.
Nov 21, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
T.v on standby, red light flashing 3 times, wont switch on
Shutdown with a 3x blink pattern occurs if the 12v from the power supply (GF1 or GF2 depending on model) is lost at CN6153/pin 6 to the AU Board Q1224 to Sub Micro IC1205. The suspects, in order of likelihood, are (1) Power supply and (2) the AU board.
Aug 11, 2009 | Sony BRAVIA KDL-40V3000 Television
Standby Indicator flashes red 6 times between 2 second intervals
My TV (Sony Bravia LCD KLV-32S310A) goes of after 20 seconds when it is switched on. The standby indicator then flashes (red) five (5) times then there is a two seconds break followed by another six flashes then two seconds break etc. What might have caaused this and what should i do?
Apr 13, 2009 | Sony Televison & Video
Standby light flashes 3 times
A 3 flash pattern indicates that either the lamp is not seated correctly or that the lamp door is not latched properly. It can also be a fault with the switches that sense whether the lamp is seated or the door is latched. Try reseating the lamp and relatching the lamp door
Oct 20, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
Electro Med Services...
