Question about Gigabyte Computers & Internet
Backlit keyboard - Gigabyte Computers & Internet
I'm totally confused, can be someone has other ideas what should I do to enable keyboard backlit
despite a port on the motherboard for the back-lite option, not all motherboards actually have all the supporting hardware. Those that do, but aren't equipped originally with the backlit keyboard typically haven't installed the basic drivers to operate one.
start by opening: [control panel]>[system]>[device manager] and select 'search for new hardware'
Oct 31, 2014 | Lifetime ASUS N71Vn Replacement Laptop...
Do Lenovo Z710 keyboards light up
Yes, the Z710 keyboard has backlit keys. Here is the description from Lenovo.
Backlit AccuType Keyboard The acclaimed AccuType keyboard is ergonomically designed to make typing more comfortable and to reduce errors. And, with backlit keys, you'll be able to type with ease even in low-light conditions.
Jul 08, 2014 | Lenovo IdeaPad S10-2 Netbook
Continuous beep does not boot
In my experience with Panasonic Toughbooks,
when there is a continuous beep then it means
one of the keyboard "KEYS" is stuck.
I would then press repeatedly every single key
in order to figure out which one was specifically stuck.
Otherwise try plugging in an external keyboard.
In the most extreme case, try disconnecting the built-in
keyboard and then plugging in an external keyboard.
A replacement keyboard should not cost more than
$20 or $30 except if your keyboard is one of the fancy
backlit keyboards. A backlit keyboard can be replaced
with a conventional regular keyboard without any
consequences. A backlit keyboard is usually $200+.
Good Luck,
Regards
Richard - Montreal Based
Authorized Panasonic Toughbook Dealer since 1989.
Apr 10, 2014 | Panasonic Toughbook Computers & Internet
Can I replace my non backlit keyboard with a backlit one?
If it is for your exact model than that keyboard should work. The backlight function is built into the keyboard itself not the laptop. I hope that helps
Jun 12, 2012 | ASUS K50IJ-C1 Notebook
Turn on backlit keyboard
The backlit keyboard on the CF-U1 is set to on by default from the factory. To turn the backlight on and off the key combination is Fn + Z.
Please note the keyboard icon printed under the Z key.
May 11, 2012 | Panasonic Toughbook Cf-31 Cf31 Aaaaa1m I5...
HOW DO I TURN ON THE LIGHTS OF MY LAPTOP'S KEYBOARD
The backlit keyboard is optional. You can go to support.dell.com and type in your service tag, from there you can get a parts list and see if you have the backlit keyboard. From what I'm finding, if you have the backlight, it will come on when you turn the system on. You can buy a backlit keyboard and swap it out if you must have the light.
Feb 26, 2011 | Dell Latitude E4300 Notebook
BACKLITE WON'T STAY ON
You can only change the back light level in the BIOS. Boot the computer and press F2 immediately. Once you are in the BIOS, set the back light level you want, then save and exit. When the computer comes back up, that will be your back light level.
Jun 19, 2010 | Panasonic Toughbook 29 Touch with Backlit...
How do I turn on my backlit keyboard on my dell with windows vista?
Sorry for the last answer. The expert probably didn't understand your question.
If you have purchased the optional backlit keyboard, the right-arrow key will have the backlit keyboard icon on it. The backlit keyboard provides visibility in dark environments by illuminating all symbols on the keys. The settings for this keyboard can be personalized by using
Dell QuickSet.
Backlit Keyboard Brightness Settings – Press <Fn> + right-arrow key to toggle between the three lighting states (in the given order).
The three lighting states are:
a. full keyboard/touch pad brightness
b. half keyboard/touch pad brightness
c. no lighting
Hope this helps. If you need the manual for this computer, it is located here:
http://support.dell.com/support/edocs/systems/studio1737/en/SG/F174HA01MR.pdf
Thanks for using FixYa.
Jul 21, 2009 | Dell Studio 1737 Laptop
Is the keyboard on the toshiba satellite a135-s4427 backlit and if so how do i activate it
The Toshiba Satellite A135 series stock keyboard is not backlit, and that model only supports one type of non-backlit keyboard, which is interchangeable with several other Satellite series. Here is some extended info on the keyboard for your model: http://www.machinaelectronics.com/store/buypart/Toshiba_Satellite_A135_S4427/K000044100
Jul 13, 2009 | Toshiba Satellite A135-S4427 Notebook
Open Questions:
Computers & Internet Logo
14 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
