Question about Dishwashers
Candy cdi 45
What is the E6 error ???
4 Suggested Answers
SOURCE: Candy CDI 45 E4 code
I have E1 code on Candy dishwasher CDI 45
Posted on Sep 29, 2010
SOURCE: Error Code E4 on my Candy CDI 45 Dishwasher
get you get it fixed? I have the same error
Posted on Jan 24, 2011
Daniel S
  • 4323 Answers
SOURCE: Error E1 on Candy dishwasher
Hi
E1 is a leakage error in your dishwasher; it is usually displayed either due to a clogged drain or due to water leakage in hose connections. If the drain pump assembly is not clogged then check the motor water seal leakage of sump assembly and also check the impeller of washing pump, if it is worn then replace the impeller. You can also make sure that the height of drain hose is not over 20". Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 30, 2011
What is error e6
e6 error air conditioner Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your e6 error air conditioner question. Get free help, tips & support from top experts on e6 error air conditioner related issues.
air conditioner e6 code Questions & Answers - Fixya
...one inverter 12k I have a DeLonghi one inverter and when I want to turn On the heater then the code error display E6 and the error code is Communication ...
1-Time Flash & E6 error troubleshooting, part 1 of 3 for ...
? 3:04
https://www.youtube.com/watch?v=sYNN1Rvc7r0
Dec 18, 2012 - Uploaded by MitsubishiHVAC
1-Time Flash & E6 error troubleshooting, part 1 of 3 for Mitsubishi Electric .... Ductless Air Conditioner ...
Jan 23, 2016 | Heating & Cooling
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Error code e6 what does that mean air conditioner will not start
DeLonghi CF210 Portable Air Conditioner Error code e6 ...
www.fixya.com > ... > DeLonghi CF210 Portable Air Conditioner
DeLonghi CF210 Portable Air Conditioner, error code e6 related issues. Get free help, solutions & advice from top DeLonghi experts.
Error e6 displaying on single split model one - Fixya
www.fixya.com/.../t4492271-error_e6_displaying_single_split_model
Apr 5, 2010 - Question about DeLonghi CF210 Portable Air Conditioner ... then the code error display E6 and the error code is Communication malfunction.
DeLonghi fix e6 error Air Conditioners Questions & Answers ...
www.fixya.com > Forum > Tags > fix e6 error > Air Conditioners
DeLonghi air conditioners fix e6 error related questions and answers. ... DelonghiFX400eco error code I Have the above air con unit 18 months old the cooling ...
DeLonghi CF210 Portable Air Conditioner Error code e6 split
Jan 01, 2016 | DeLonghi Heating & Cooling
Something went wrong after a saga api call: http://candycrush.king.com/api/gameStart with params: arg1=6&%5Fsession=72z9Sb1xUrqPkt1uX1wedg%2E1&arg0=4]
[E-Error= Error #1125][CCS error message: Something went wrong after a saga api call: https://candycrush.king.com/api/gameStart with params: arg1=11&%5Fsession=5xCvj8J2hzlaV%5FfShuC2WA%2E1&arg0=45]
Nov 06, 2013 | Facebook Apps
Error E1 on Candy dishwasher CDI 45
Hi
Daniel
Aug 30, 2011 | Dishwashers
Candy cdi 1012/2-80 is leaking at bott of door. Whats up.
my candy dishwasher is leeking from the bottom of door what can i do
Nov 23, 2010 | Candy DFI Plan Built-In Dishwasher
Oct 12, 2010 | Dishwashers
I have a candy cdi 3515 and after about 1/2 an hour into the programme it stops and a continuous alarm bleeping starts.
Is there water in the dishwasher when it stops?
Are you able to check if the water is normal temperature or warm/ hot?
Can you try the dishwasher in a short cycle and see if it completes the cycle?
Oct 11, 2010 | Candy Dishwashers
Candy cdi 1012 runs for approx 3 minutes goes to fault and does not make the spray arms move
I haven't got an answer to your problem, I just feel more comforted that someone else has the same fault as mine.
Feb 01, 2010 | Candy Dishwashers
Dishwashers Logo
13 people viewed this question
Top Dishwashers Experts
Owen Barnes
