Question about Mitsubishi VS-50607 50" Rear Projection Television
Help with self-diagnosis/repair
I have a Mitsubishi VS-50607. It will not power on and is giving me a diagnostic code of 2 - 2. I can't seem to find any postings that would help me with the next step of isolating the problem. Can anyone lend me a hand? Thanks...Jake
  • charljef Nov 17, 2007
    The tv powers up for about 30 seconds and then shuts down. If you turn it back on right away it only stays on for about 2 seconds. Error code is 2-2
    Problem Solver:
  • 3 Answers
Hey there, do you have the service manual? I can't help you with the specific technical stuff, but the manual says, 2-2 error code: Short Protect circuit.
Posted on Oct 21, 2007
SOURCE:
What do I need to fix my mitsubishi TV that has a 2-4 error code (vertical protect)???
I had three tv's VS-50607,VS-50605, same problem.I called Mitsubishi and got no help.Took me two years to find because the sets were not acting up when I was there.Last set was out completly with 2-4 code. Found problem to be cold solder connection of DY (Yokes) on vertical .I bent the tip on my Weller gun and used a mirror and soldered. It was a sure repair.I went back to the first set,and soldered and it repaired it!,The second set got junked out before I could get to it.
Sep 18, 2011 | Mitsubishi VS-50607 50" Rear Projection...
I am geting a blink code of 1 blink followed by 2 blinks
Replace both of your STK ICs will have number on them call mats 1-800-628-1118 for parts they are big black ICs STK394-250 go by # on yours
Sep 27, 2009 | Mitsubishi VS-50607 50" Rear Projection...
I have a Mitsubishi VS-50607 and it will turn on then off.
This solution fromtroylove solved my problem. troylove11
Rank:wizard_s.gif Wiz
Rating: 85%, 1164 votes
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Jan 03, 2009 | Mitsubishi VS-50607 50" Rear Projection...
TV shutdown for roughly 10 - 15 minutes after being on for hours
Yes the vertical circuit will shutdown the set if theres a problem with the deflection circuit. This model has a history of leaking CRT coolant on the boards near the vertical IC destroying the solder and actually eating through the circuit board. Check the area near the Vertical output IC for signs of coolant leakage or solder cracks.
Mar 11, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Vertical protect
1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB.
Nov 05, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Self-diagnosis
2-4 is already listed you have to read the threads to keep from causing a repeat of the same fix.
Oct 07, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Will not turn on
Oct 06, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50607
Oct 04, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50607 Won't Turn On
Sep 25, 2007 | Mitsubishi VS-50607 50" Rear Projection...
VS50607 Mitsubishi
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.....
Sep 24, 2006 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50607 50" Rear Projection Television Logo
100 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
