Question about Dishwashers
Smeg Problems DIC6, brand new just installed and not working, 2 red lights showing, rinse aid and salt but surely the machine would still fill?
SOURCE: dwf50 hotpoint aquarius dishwasher
hi, just found this forum after searching the web 4 a solution to my hotpoint DWF50 problem.
I came down this morning to a machine which base tray was full of water and lights 3 ECO & 4 Fast flashing.
Anyway my solution was as i had seen a hotpoint engineer do once before was to press the start/reset button trip the catch, to fool the machine into thinking the door is closed then put in a program, press start, the machine hums slightly but doesnt do anything then after removing the large filter from the tray at the bottom underneath the lower basket insert a length of wire, with a loop on the end (Tip i used a wire coat hanger from the dry cleaners) poke in ythe hole that the dirty water drains from, after a bit of poking about the pump started working and the water drained away. Tip place a hook at the other end of your wire impliment to put your finger in to stop the wire getting caught in the pump mechanisim. After wards u have to hook back the door catch to the normal position, Tip another piece of the coat hanger with a right angled piece at the end will do this. This worked for me, saved me some money esp as D & G insurance ran out 2 weeks ago.....stu
Posted on Jun 22, 2009
  • 341 Answers
SOURCE: Indesit IDL40 lights & 4 flashing
First thing I did was to find the information I needed from where it didnt cost me. Then I decided, luckily for you that I wouldnt charge you for how it was fixed. By removing the four screws on the top part of the door and tilting the control panel down to remove it, you will see a black wire that is connected to a thermostat that should be clipped onto the inner metal panel (down and to the right) replace it in its clip and secure it with a zip tie. If this doesnt cure the problem then you will need to check the heater element because its probably blown it due to overheating, last but not least, if the element is in good condition then its got to be the PCB (part number for the Indesit IDL40UK is C00142139 approx £50) that is on the panel you removed to replace the thermostat. It is possible to repair the PCB and the fault is probably the 12v 10a relay and if your confident enough can be obtained from Maplins who do 2 possible replcements with thi same footprint (numbers JM67X and YX97F approx £2). I gleened this information from a number of sources and I thank them for it all, This as far as I can tell is all it can be and its nothing to do with no salt or rinse aid, and my machine is back up and running. I hope this helps others that have lights 2 & 4 flashing and want an answer.
Posted on Mar 14, 2010
rylee_smith
  • 8619 Answers
SOURCE: inlet/drain, salt and rinse aid light flashing
Hi
Thanks for using FixYa. The first thing that should be checked is if its draining properly as it could be that the drain hose is clogged and needs to be cleaned. The drain pump also should not be clogged. Also the stopcock should be opened fully and the water inlet valve should be checked for any clogs. Also the metal filter, impeller cover and the air gap unit should be checked. After checking this you can reset the error as follows: turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Then switch the appliance off and then back on again. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jun 06, 2010
news775
  • 699 Answers
SOURCE: my bosh classixx dishwasher is
Inside the machine in base there is a large screw cap.
Undo that put DISHWASHER salt in not cooking salt.
Make sure the salt well is full of water in it before you put in the salt. Fill salt to top.
Please dont forget to vote this answer was helpful
Many thanks
Posted on Feb 14, 2011
  • 128 Answers
SOURCE: The "Rinse Aid" red light
The rinse aid light is just an indicator to let you know the rinse aid is low. You fill it in the container next to where you put the detergent. Just push the yellow button and the lid will pop up. rinse aid is more important on the newer miele dishwashers, as they dont have "active drying" like the older dishwashers did. They depend on the rinse aid to sheet the water off the dishes at the end of the cycle. They are designed this way to reduce energy consumption. If you choose not to use rinse aid, and you dont mind wet dishes at the end of the cycle, either disregard the red light, or fill the rinse aid dispenser with water to trick the machine into thinking it is full.
If you are not going to use the onboard water softener, you can turn it off. Refer to your owners manual, or call miele tech support at 800 843 7231 and they can walk you through the programming to disable the water softener. these are not fault lights, they are simply reminders that you need to fill the containers.
Posted on Jul 20, 2011
I have a John Lewis dishwasher and all the lights are on red
all the lights will be on before you select a cycle, if the Rinse Aid and Salt warning indicator lights are on you need to add rinse and salt to the appropriate fill up locations
Dec 30, 2013 | John Lewis JLDWW1200 Dishwasher
Dishwasher salt beko
Rinse aid and salt are not necessary if you use powder that is similar to the tablets. The lights are warning you that you havent added them, you know that so ignore the lights. If you live in a hard-water (limescale) area salt can be used as well as tablets or powder to make the water kinder to the machine, but most people just use tablets without rinse-aid or salt.
Dec 14, 2013 | Dishwashers
Smeg di612ca9
Most likely you need new dispenser and you could buy it on line or you could get it from your local service centre as they might be able to order it for you
Dec 09, 2013 | Dishwashers
What do these mean on a zanussi dishwasher model DE 6854
The top light is apparently to indicate that the salt (!) has run out.
The bottom light is apparently to indicate that rinse aid has run out.
For the record, that seems to be a Zanussi DE-6854 dishwasher, and I found the manual here: (link)
"Special salt can be added in one of two ways: 1) If you are using dishwasher detergent that already contains salt, the detergent including the salt is placed in the detergent compartment. - In this case the water softener must manually be set to 1 and electronically to 1 to ensure that the special salt is taken from the detergent container only. 2) If you are using dishwasher detergent and salt separately, the special salt is to be put into the salt container. - In this case the water softener must manually be set to 1 or 2 and electronically between 1 and 5 (depending on the water hardness in your area) to ensure that the special salt is taken from the salt container only. Only use salt specifically designed for use in dishwashers. All other types of salt not specifically designed for use in a dishwasher, especially table salt, will damage the water softener. Only fill with salt just before starting one of the washing programmes. This will prevent any grains of salt or salty water, which may have been spilt, remaining on the bottom of the machine for any period of time, which may cause corrosion." (Page 6)
"Only use branded rinse aid for dishwashers. Never fill the rinse aid dispenser with any other substances (e.g. dishwasher cleaning agent, liquid detergent). This would damage the appliance." (Page 7)
The manual also explains how to turn the Rinse Aid light off permanently if you do not wish to use rinse aid.
Mar 23, 2013 | Dishwashers
What do these lights mean there not going off
Jul 20, 2011 | Miele Dishwashers
My bosh classixx dishwasher is showing the light rinse acid and salt i have just got finish rinse aid and salt **** not sore were to put it in the dishwasher there is a cap saying salt is it that?
Many thanks
Feb 14, 2011 | Bosch 24 in. SGS43C12 Classixx...
My new dishwasher leaves a white residue on my pots. pans and stainless flatware. I have not changed soap. Could the water not be hot enough?
Check the incoming water quality. If water is hard and having calcium content this could happen. Use water softeners in the inlet water to the machine.
If dish washer salt compartment available fill with the special salt meant for dish washers.
Check rinse aid compartment and fill rinse aid. Or use two in one soap tablet.
Sep 19, 2010 | Whirlpool Dishwashers
Film on dishes and inside stainless steel panel
You live in a hard water area. Even though dishwasher tablets have salt included you may have to fill the machine with extra salt. (its the large srew top cap in the bottom of your machine, open it and fill it with dishwaher salt your machine came with a large funnel to help you do this) you will have to remove the bottom drawer to do this. next make sure you have rinse aid installed in the door of your machine, next to where you put the tablets in (don't buy cheap rinse aid it's not worth it) when its full of rinse aid the indicator will turn dark, will need both salt and rince aid about every 30 cycles.
Nov 05, 2009 | Miele Optima G2470SCVi Built-in Dishwasher
Problems with my bosch dishwasher
there should be no salt getting into the wash cavity. if you are sure that it is leaving salty water on the items then either the salt cap is loose/damaged or the regeration system is faulty-this is an expensive fix.
Jun 12, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
49 people viewed this question
Top Dishwashers Experts
Owen Barnes
