Question about Timberland Mens Quartz Watch Qt7169102
Adjust hour and local - Timberland Mens Quartz Watch Qt7169102
Need a manual or instructions for mt watch please!!!
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to resume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
Have fun :)
May 04, 2017 | Watches
How to set time on timex 1440 sports watch
Welcome to FixYa!
Here's your request.
TIME AND DATE 1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash. 2. Press ADJUST to set SECONDS to zero. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change. 5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM. 6. Press MODE when done. 7. To display DATE from Time display , press START/STOP. 8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE. 9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME 1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash. 2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change.. Press MODE when done. 5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH 1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes. 2. With time displayed, press MODE to select Chrono Mode. 3. Press START/STOP to start. 4. Press ADJUST to view lap time. Press again to sesume lap timing. 5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero. 6. Repeat for successive laps.
Thank you for using FixYa! Have a great day.
Jas247
May 06, 2011 | Timex Watches
I was adjusting my time on my watch and realised that i can't seem to align my hour hand and 12 hour hand on the exact hour reading when my minute hand is at 12!!! Help!!
Your watch needs a hand alignment. This cant be done without some specialty tools and training. Take your watch to a qualified watch repair shop and ask for a hand alignment. Make sure that when you also ask to have the watch resealed if it is water resistant. Good shops will guarantee their work.
Apr 20, 2011 | Watches
I got my Casio G-Shock 4778 aw-590 battery replaced at a local shop(not a licensed g-shock dealer) and the jerks did not set the time and my manual for the watch was thrown out years ago!
mcdevito75 here, Return to the shop for this adjustment. Or you can try, press the mode button, see the display flashing, now press set for each function you want, after each function press mode again to move onto next function, hour minute etc., when all functions are set, presss mode again for steady display. You may have to press and hold down mode button from the start for 2-3 seconds to see display flashing, once you do, you can use set to adjust all functions.
Aug 17, 2010 | Watches
How can I set the tide clock
mcdevito75 here, I've never heard of a tide clock or adjustment or timeing for tide cahnges. The tide changes every 6 hours with 45 minutes at the end of that 6 hours rest you could say before the change of the tide. Refer to your local newspaper or fishing supply outlet for tide schedule.
Jun 29, 2010 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
Ehoward watch is 10 minutes off. how do I adjust
mcdevito75 here Chances are the button you push to change the hour you also adjust the minutes with, after you adjust the hour, press the same button again to set the minutes, MAYBE!!.
Jun 21, 2010 | Watches
Watch has been running fine, now running fast.
HI there,
If you have an Automatic Wrist watch. Some adjustment has to do inside the watch. You better bring the unit to any local watch repair shop to adjust or correct the polarity of the energizer.
Hope this helps.
micro
Jul 28, 2009 | Watches
Need instructions for Timex 1440 Sport watch
TIME AND DATE
CHRONOGRAPH
Nov 22, 2008 | Timex 1440 Nylon watch
TRYING TO SET THE TIME ON A FOSSIL WATCH. ITS DIGITAL WITH LIKE A STOPWATCH APPEARANCE DQ-1147 (900509) IS ON THE BACK OF THE WATCH
I called the local Fossil Outlet in Lancaster, PA and got them to explain how to change the time. By phone they are 717 396-0823
There are four buttons on the watch.
Press the set-el botton once followed by the mode button once and this will put you into the condition to make adjustments. Each time you press the mode button a different adjustment can be made....so you go from hour to minute and so on
Once you get to the adjustment you want to make you use the right two buttons to increase or decrease the setting
Jul 26, 2008 | Fossil Watches
Armitron Watches
From the time telling mode press the set button the seconds will flash.
Press the mode button the hours will flash
Press the adjust button to change the hours
Press the mode button the minutes will flash
Press the adjust button to change the minutes
Press the mode button the month will flash
Press the adjust button to change the month
Press the mode button the date flashes
Press the adjust button to change the date
Press the mode button the day flashes
Press the adjust button to change the day
Press the set button when done.
Mar 11, 2008 | Watches
Timberland Mens Quartz Watch Qt7169102 Logo
23 people viewed this question
Top Timberland Watches Experts
Vernon Taylor
ka4iup
ka4iup
 John
John
Are you a Timberland Watch Expert? Answer questions, earn points and help others
