Question about Mitsubishi WD-65C9 65" DLP HDTV
TV suddenly turns off by itself while on (will stay on for like 20 min at a time) and the green light turns solid red.
    New Friend:
    Problem Solver:
  • 10 Answers
Make sure the fans inside are all taking the heat out good. There is 3 to 4 fans on them one for the lamp one for the mirror processor. Also the light prism has one sometimes and one for the inside cavity. Digital light processor heat up and they have cut out and over heat protection.It seems someething is heating up ..Also could be power suply problems.
Posted on Nov 19, 2013
    New Friend:
Open circuit in the horizontal section
  • 129 Answers
SOURCE: Picture comes on than turns off and red light stays on
you can reset the tv to factory default settings , but before that I need more info ab manufacture date and purchase date you can find the first one on the back cover, if the tv has more than 5000 hrs of use problably the lamp, filter or fans can cause this problem, hope it helps you . let me know
Posted on Jun 12, 2007
  • 1153 Answers
SOURCE: Replaced lamp and now can't get a picture
Hi Sally Jo, Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001. Hope this helps!
Posted on Sep 18, 2007
yankeegurl
  • 121 Answers
SOURCE: Red Light Blinks 3 times
that models plagued with bad capacitors 1000uf and above the problem you describe is 2 bad capacitors on the PWV board if you would like more information you can go to this link they have service manuals,parts and experts online for these tv's leave them an e-mail with your model number and problem and they will help you I have used this sight many many times myself
http://servicemanuals.vstore.ca/
Posted on May 10, 2008
  • 346 Answers
SOURCE: Mitsubishi Model wt-a42
change the1000uf capacitors
Posted on Nov 16, 2008
  • 126 Answers
SOURCE: TV shuts itself off after a couple minutes of being on.
One must be very careful of the quality of the replacement lamp. Many of the cheap 'deals' on the web for replacement lamps are substandard. I always recommend that replacement bulbs be the original manufacturers bulb.
Posted on May 01, 2009
Mitsubishi projection T.V
check the lamp first to see if intact or shattered.
Mar 31, 2012 | Mitsubishi Televison & Video
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
I have a Sony Grand WEGA KDF-50WE655 50-Inch LCD Projection TV and when I turn it on the screen stays black and the green light flashes for 20-30sec then the TV turns itself off and 2 red solid lights...
The tv projection Lamp inside the tv now has it been inside this tv like 1 1/2 or 2 years already and tv is on and used it like 4 or 5 hours every days?Yes,the tv now the 2 red LEDS solid lights apear.One of those light have a word "Lamp" written on it bazel frame?Yes,100% ur tv projection Lamp life are over and ending.Tries websites like Ebay.com,Partstore.com to buy a new tv projection Lamp for the replacement.
Jul 18, 2011 | Sony Grand WEGA KDF-50WE655 50" Rear...
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
LG rear projection tv. sound but no picture.
Go to a repair centre, some parts must be fixed/replaced.
Jul 22, 2009 | LG RU-52SZ30 52" Rear Projection...
VIORE LCD TV/DVD won't turn on
19 in wont turn on. red light just solid , unplugged for a day still same , is there a reset button
Aug 18, 2008 | Televison & Video
Mitsubishi WD-65C9 65" DLP HDTV Logo
93 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
