Gainsborough 8.5se shower cold water
Hi i have a gainsborough 8.5se electric shower and i got in the shower saturday night and worked as normal but when my daughter went in for a shower sunday it was just running cold water can anyone help please really appreciate any advice iv seen things like it could be filter or needs descaling but no diagrams of parts so do not know what filter looks like or pipe that may need descaling. i am in private landlord but would prefare to try n sort it my self if it only little job before i have to phone my landlord. thank you stressed mum
brainyass
  • 242 Answers
SOURCE: Gainsborough Shower Running Cold
It sounds like you have a faulty thermostat or broken heater element.
Posted on Oct 23, 2008
  • 44 Answers
SOURCE: triton opal electric shower overflow pipe
hi rob the problem is due to an activated thermal overheat switch, you cannot reset this unit as once it is activated it will require a new unit, its a nuisance i agree as i come across this regularly, however its condusive of a scaled up unit so you eventually turn up the shower setting higher to get the water hotter, & inturn activates the thermal switch.
According to which model it is the part is not that overly expensive, you can phone triton direct 7 they will post a new spare to you
Kindly
Richie
Posted on Dec 15, 2008
muralme
  • 20 Answers
SOURCE: Hi, Advice please, my shower when on hot comes
If you are taking about then neck of the shower head this is what you must do. its no need to turn the water off to the house or to the bathroom first you will need a pair of channel locks and some Teflon tape. first remove the shower head if you dont want to scar the nut on the shower head place cloth between the pliers and the fitting, once removed (very important) turn the channel locks upside down stick one side of the blue handle up in the neck of the shower and rotate to your left to loosen if you are having a leak leak there it should already be semi loose, once removed wrap the threads with the Teflon tape and re-insert making sure it is tight, then wrap the the outer end of the neck with Teflon tape and place the head back on.The reason it leaked is because the plumber who installed it did not tighten it up completly because he wanted it to look straight coming out of the wall and the additional water pressure causes it to leak wheras the hot water causes it to expand and seal
Posted on Jul 16, 2009
  • 3 Answers
SOURCE: i have a Gainsborough Royale Antique and i can not get cold water
how old is the shower?
Its a mixer, am I correct?
Posted on May 07, 2010
brohke
  • 136 Answers
SOURCE: Hi I own a Samsung
Your external drive may not be coming up due to a defected usb adapter, this might also explain why your computer fails to recognize the device. Try getting a new adapter and see if that works
Posted on Jul 04, 2011
Why is my Gainsborough 2000x shower not heating the water passing through?
I sounds as if the element has failed... if you isolate the power to the shower you could test the element with a multimeter..
Apr 18, 2017 | Gainsborough Home
I have a gainsborough ps1600 shower. Water pressure has dropped. Doesn't help when head is removed. Can still adjust temperature but not speed/power
If the water pressure dropped at a sudden moment, it sounds more like an issue with the water pressure leading into your shower, and not a problem with the shower its self. Try seeing if other water sources in the same area of your shower have the same low water pressure issue.
Stained Glass Leaded Glass St Petersburg FL
Jul 12, 2014 | Home
Got a gainsborough shower no water is coming out when i switch it on and the low flow light in coming on
inside the shower unit theres water connection to unit ,turn the water and power supply off and check the water conn filter its on the connection comming into the shower its most prob blocked good luck
Feb 18, 2011 | Hardware & Accessories
Water coming from around the bottom of gainsborough 9.5E electric shower. I think its a pressure release device. Do I need a call out or a new shower. Or can I fix it.
Piece of P: youre prob right and its the pressure relief device, which is a silicone rubber ball that gets blown out of a branch of the exit pipe just behind where the hose screws on. If you are careful you can push it back with a small (non sharp) screwdriver etc, looking up from underneath. It would be easier to see if you unscrew the hose first.
Sep 05, 2010 | Home
Hi, Advice please, my shower when on hot comes normal out of the shower head but when water temperature normal it stream out of the bottom of the wall fitting, gainsborough shower 2 years old approx....
Jul 08, 2009 | Water Pik Wall Mount Shower Head
No water coming out of shower
First you should check the screens st the ends of the hose to be sure they are not clogged. The shower head as well. Otherwise it could be the water control valve, solenoid or thermal cut off.
http://www.theshowerdoctor.com/shower-spares/gainsborough/energy-2000x.html
Mar 02, 2009 | Home
Oct 08, 2008 | Home
Computers & Internet Logo
David Payne
David Payne
