Question about Fujitsu 12R1 Air Conditioner
How can I unlock airfel remote control? - Fujitsu 12R1 Air Conditioner
I bought a honda civic sport 2005 got it resprayed and i built it up and now the alarm keeps going off the key fob doesnt work etheir the battery has been flat . does any body no how to reset the fob or...
Programming
When
Remote control added or replaced. System malfunction.
How
Obtain all remote controls. A maximum of 3 remote controls can be programmed. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press lock or unlock button. System should now lock or unlock vehicle. Within 4 seconds: Press lock or unlock button. Within 10 seconds: Press lock or unlock button of first remote control. System should now lock or unlock vehicle. Press lock or unlock button of second remote control. System should now lock or unlock vehicle. Press lock or unlock button of third remote control. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed remote controls.
IMMOBILIZER CAN ONLY BE SET BY DIAGNOSTIC EQUIPMENT
May 13, 2011 | 2005 Honda Civic
Where is the re-set button to program a remote door lock for my 2000 Subaru Forester?
Obtain all keys/remote controls. Remove driver's side kick panel/lower 'A' pillar trim. Connect central locking registration connectors (white) - black wire and black/blue wire Fig. 2 . Unlock the vehicle using the key. Program first key/remote control as follows: Press unlock button Fig. 1 [1], then lock button [2]. The door lock should lock and unlock in sequence confirming programming of first key/remote control. Repeat programming procedure for remaining key(s)/remote control(s). Once the last key/remote control is programmed disconnect central locking registration connectors. Check operation of all programmed keys/remote controls.
Sep 03, 2010 | 2000 Subaru Forester
Hyundai santa fe key fob 1 works 1 does not have changed battery deal says to buy new ,can i unlock with key without alarm going off
System operation
Pressing remote control lock button locks vehicle and activates system Fig. 1 . Indicators flash once. Pressing remote control unlock button unlocks vehicle and deactivates system Fig. 1 . Indicators flash twice.
Fig. 1
Synchronization
When
System malfunction. Remote control added or replaced.
How
Access alarm system control module located under driver's side lower fascia Fig. 2 . Set memory switch to SET position. Press remote control lock or unlock button. Set memory switch to OFF position. Confirm synchronization has been successful by locking and unlocking vehicle. Repeat procedure for second remote control. Synchronization can also be carried out using diagnostic equipment.
NOTE: A maximum of 2 remote controls can be programmed. NOTE: If remote control fails, system can be deactivated as detailed in the owner's handbook.
Jul 30, 2010 | 2003 Hyundai Santa Fe
As to me to stitch the second key from ignition (with immobilizer) in memory of my car (Honda CRV-2,4 EX 2002, made in UK) if nearby is not present diller from Honda.
Programming
When
How
Obtain all remote controls. A maximum of 3 remote controls can be programmed. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press lock or unlock button. System should now lock or unlock vehicle. Within 8 seconds: Press lock or unlock button of first remote control. System should now lock or unlock vehicle. Press lock or unlock button of second remote control. System should now lock or unlock vehicle. Press lock or unlock button of third remote control. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed remote controls.
NOTE: If less than 3 remote controls are to be programmed, remove ignition key after programming last remote control
NOTE THIS IS FOR YEAR 99-02
Mar 02, 2010 | 2002 Honda CR-V
New alarm fob for pt cruiser not coded to car (correct serial numbers)
Programming
When
How
Switch ignition ON. Press and hold lock button Fig. 1 [2] for approximately 10 seconds. Keeping lock button depressed, press and hold unlock button within 10 seconds. Programming mode activated (acoustic signal will be heard). Proceed as follows: Release lock/unlock button. Complete the following within 30 seconds: Press lock or unlock button of first remote control. Correct programming indicated by a single acoustic signal. Press lock or unlock button of second remote control. Correct programming indicated by a single acoustic signal. Repeat above procedure to program any remaining remote controls. Remote controls can also be programmed using diagnostic equipment.
NOTE: A maximum of 4 remote controls can be programmed.
Feb 03, 2010 | 2001 Chrysler PT Cruiser
How to recode remote to vahicle
Programming
When
How
NOTE: If less than 3 remote controls are to be programmed, remove ignition key after programming last remote control.
Jan 18, 2010 | 2003 Honda Civic
Remote key fob will not work-battery replaced
VW/AUDI/SEAT/SKODA
Remote Control Programming (1997 ON)
Procedure
1. Switch Ignition ON and leave the key in the ignition.
2. Mechanically lock the vehicle using the Drivers door using a second
key.
3. Using the remote control press the Unlock button once, and the horn
will sound once.
4. Wait 6 seconds and press the unlock button once to activate the coding
procedure. The remote control will now be programmed.
NOTE : When performing programming on additional remotes the procedure
is the same, except you press the unlock button 2, 3 or 4 times for the
different remote.
For example : If programming 2 remotes press the unlock button twice with
a 1 second interval between each press, repeat for 3 and 4 remotes.
5. Switch Ignition OFF.
6. Remove key from ignition and check for operation.
7. The coding procedure can be repeated up to 4 times for additional remotes.
8. The ignition must be switched OFF between programming each remote
control.
Remote Control Erasing (1997 ON)
Procedure
key.
3. Press the remote control unlock button 5 times in 1 second intervals.
A short horn will sound.
4. Wait 6 seconds and press the unlock button once to activate memory
erase.
5. Switch ignition OFF, all remotes are now erased.
Dec 24, 2008 | 2004 Volkswagen New Beetle Convertible
Locked dvd
1. Press the Menu button on your remote control 2. Press the 5 button on your remote control
3. Press the 7 button on your remote control
4. Press the 5 button on your remote control
5. Press the 3 button on your remote control
6. Press the 8 button on your remote control
7. The currently selected region will be indicated on the TV.
8. Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on, or the 9 button for multi-region playback
9. Press the Menu button on your remote control
10. Press the Menu button on your remote control
Tested with Region 1 DVD's on my UK player (Region 2 bought from Comet)
Mar 02, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
Heating & Cooling Logo
487 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
