Question about Lexmark S415 - multifunction fax / copier / printer / scanner color
Paper gets jammed in roller
The paper doesn't get to the 2nd set of rollers and scrunches up in middle
    Habit-Forming:
  • 135 Answers
Try to clean the rollers with alcoholic liqued
Posted on Nov 19, 2013
How to fix paper jam when printing 2 sided
make sure all rollers and rollers are clean us alcohol sparely and make sure you use quality paper also it does make a difference
Apr 07, 2016 | HP CM749A - Officejet Pro 8600...
Printer doesn't send paper all the way says paper jam, rollers are moving doesn't print
Possibly the sheet detector sensor, that had become bent out of true alignment, which is telling the printer that there are a number of sheets going through and indicating a jam situation. You need to inspect the guide roller, make sure it is free to move and touches the sheet of paper when it is loaded. If it is bent out of alignment, GENTLY try to bend it back downwards (make sure the paper thickness setting is set to paper not to card when doing so,)
Jun 13, 2011 | Canon PIXMA MP240 All-In-One InkJet...
OKI C9600 paper jam problems: Paper jams continually, either on first attempt to printing or if it prints a page the 2nd page inevitably jams. Printer has only done 1500 pages since new ,and i have removed...
Wow! That's quite the printer you have there. The C9600 does have a feed roller in the front; and it's not uncommon for paper to still get stuck. Does your paper "fan" when it goes through; or simply, go through and jam? It's possible a paper feed sensor is bad too. Another thing you might want to check is the paper tray; and that the paper is set to the proper size.
Also be aware, the OKI 9600 had a recall a year or so ago for some potential "shock issues" I would advise you to check with OKI directly to determine if this printer is part of that issue too.
Jan 04, 2011 | Office Equipment & Supplies
Paper cannot be fed right.
There is probably something causing it to jam caught up in the paper path. Try feeding a pioce of stiff card through the path to clear out and scrap of torm paper.
Also clean the rollers to remove any smoothe shine from ink.Use Isopropyl alcohol for this
Also try to use the better grade of papers rather trhan photocopy type paper often paper can be too shiny for the rollers to grip and this causes a sliding action that crumples the paper.
Sep 14, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Hp laserjet 8150 printer jams from tray 3
Check the rollers in tray 3 to see if they are slick. If not, replace the paper input unit C4214-69017.
Feb 19, 2009 | HP LaserJet 8150dn Printer
Paper Jams
Clean the rollers properly with IPA (Iso Propyl Alcohol) Industrial grade. Dot use solvents.
S. Mohan
Jan 14, 2009 | Ricoh IS 450DE VRS Flatbed Scanner
Canon Pixma MX310 Office printer. continues to jam paper. in the maintenance panel i cannot perform an alignment check or deepclean. Attempt to copy feeds a whole sheet thru and chokes on the 2nd piece. I...
Printers that jam usually have worn feed rollers, some where in the machine, or a bad sensor. If worn feed rollers are the problem the paper usually jams in different locations in the machine. If a sensor is bad the paper usually jams in the same spot each time paper is fed into the machine. A new machine does not have worn rollers, but could have a broken sensor. It sounds like the a roller might be worn. There is a company called Tech Support that use to sell a cleaning fluid for paper feed rollers. You can use alcohol but alcohol dries out rubber, but you can use it to diagnose the problem. Clean all visible rollers. Especially the rollers that the paper jams between.
Nov 20, 2008 | Office Equipment & Supplies
Paper Jam at exit
This happened with an old HP Laserjet 1100A of mine.
I had apparently dropped a screw in the paper-out slot and it was jamming the paper on just one spot.
As you know, the entire sheet is connected, so It is most likely a similar situation in which a previous jam has left a small wad of paper under one of the rollers, and this is preventing the paper from exiting the slot.
Best bet, print something and see where the paper is scrunching up. This is most likely the roller that has the paper stuck under it. Remove the toner block and blast some compressed air into the spot the jam is most likely originating and see if anything else flys out.
Also, if that does not work, you might try manually rotating the rollers backwards, which will often eject the lodged paper chunk.
Note- Please be careful inside the printer! Do not touch the bright green drum, or anything that dosen't look like it is rubber and rolls paper around!
It is very easy to mess things up in there ;)
Sep 28, 2008 | Samsung CLP 300 Laser Printer
Paper Jam with no access to clear
you will need to remove the fuser module from the machine and open the fuser to remove the wrinkeled paper inside the fuser section. then reinstall the duser in the reverse way
Jun 25, 2008 | Brother MFC-8440 All-In-One Laser Printer
Paper jam
. There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
Nov 15, 2007 | Lexmark C532n Color Laser Printer
Lexmark S415 - multifunction  fax / copier / printer / scanner   color Logo
35 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
