Question about Fishing
Service a Silstar Nova 10 reel - Fishing
Where can I find a bail spring for a silstar BT25 ultra lite reel.
Fixya does not sell bail springs and knows of no sources.
Aug 12, 2017 | Fishing
Tip
Top 10 Best Spinning Reels for 2016 & 2017
Let's face it! It is not easy to find the best Spinning Reel from the market.http://www.topspinningreels.com/ here you find your best spinning reel.When you are looking for a Best Spinning reel, you'll see that numerous brands have a few reels with the same name that come in various sizes (for instance a 100, 200, 400). This is typically in light of the limit of the spool, which directs the general size of the reel.In this video you will see 10 unique models of awesome quality modest turning reels. After quite a while of research, survey and searching for reels data I made my own rundown of main 10 minimal effort turning reels in slideshow design. My rundown incorporates every one of these reels.
Enjoy Our top 10 best spinning reels to buy for the 2016 & 2017 Fishing Season. The Lowest Prices Online!
Visit our website: http://topspinningreels.com/
1. PENN Spinfisher V Spinning Reel
2. Penn Battle II Spinning Reel
3. Daiwa Mini System Minispin Ultralight Spinning Reel
4. Shimano Stradic CI4+ Spinning Reel
5.Okuma Avenger ABF Graphite Bait Feeder Reel
6. Pflueger President Spinning Reel
7. Okuma Trio High Speed Spinning Reel, Black/Orange
8. Abu Garcia BMAX2 Black Max Baitcast Reel
9. Zebco Omega ZO3PRO Spincast Fishing Reel
10.Penn Clash Spinning Reel
on Nov 24, 2016 | Fishing
AKAI REEL TO REAL MODEL 1700 OPERATOR'S MANUAL
Here you are Andrew. That is a blast from the past!!
Service Manual and Owner's Manual!
Akai 1700 Manual Stereo Tape Recorder HiFi Engine
Jan 23, 2016 | Computers & Internet
Get a fishing reel schematic
CUSTOMER SERVICE
This is a link to Quantum and the "Code Red" baitcaster.
You can also try the following warranty service center.
Home
Feb 21, 2015 | Quantum Code Baitcast Reel 8 ball bearings...
Parts list,prices,and diagram(exploded view)
i have a manual on a pinnacle inertia reel.if you cant get the schematics from (www.pinnaclefishing.com/www.silstar.com,i would be more than happy to mail the one i have to you.just let me know.i have an extra copy ...
Apr 14, 2009 | Pinnacle Inertia Baitcast Reel
Replace airbag on `92 honda accord
When an SRS cable reel assembly is removed and set aside during vehicle repairs, the cable reel may rotate inside the assembly so it is no longer centered. If the assembly is reinstalled with the reel off-center, the cable can break when the steering wheel is turned to full lock. The cable reel holding fixture locks the reel while the assembly is off the vehicle, keeping it centered for reinstallation.
CABLE REEL REMOVAL PROCEDURE
1. Follow the procedure in the appropriate service manual for disconnecting the battery, and removing the dashboard panels, steering column covers, airbag, and steering wheel.
^ Always install short connectors on the connectors for the driver's and passenger's (if so equipped) airbags.
^ Make sure the front wheels are pointed straight ahead before removing the steering wheel.
2. Verify that the cable reel is centered; the yellow gear tooth is lined up with the alignment mark on the cover. Install the cable reel holding fixture in the cable reel assembly as shown. Use a TORX T-10 wrench.
3. Disconnect the 6-P connector, then remove the cable reel assembly.
CABLE REEL INSTALLATION PROCEDURE
1. Verify that the front wheels are still pointed straight ahead.
2. Reinstall the cable reel assembly, and reconnect the 6-P connector.
3. Remove the cable reel holding fixture.
4. Follow the service manual procedure for reinstallation of the steering wheel, airbag, steering column covers, and dashboard covers.
5. Verify SRS operation as described in the service manual. Road test the vehicle.
^ If the steering wheel spoke angle is not correct, change it by adjusting the tie rod ends. Do not remove and reposition the steering wheel.
PARTS INFORMATION
Cable reel holding fixture:
For 1992-95 Civic and Ohio-produced 1992-95 Accord
P/N 77900-SPO-999, H/C 4733564
For 1991 Accord Wagon, 1992-95
Prelude, 1995 Odyssey and Japan-produced
1992-95 Accord
P/N 77900-SM5-999, H/C 4733572
WARRANTY CLAIM INFORMATION
Use the Flat Rate Manual information for the repair being performed.
Jan 28, 2009 | 1992 Honda Accord
AKAI STEREO RECORDER 1722 reel to reel
so what was the answer? can the akai 1772 take 10 inch reels as well as 7 inch? please
Jan 08, 2009 | Akai Audio Players & Recorders
Fishing Logo
98 people viewed this question
Top Fishing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Steve P
Steve P
Are you a Fishing Expert? Answer questions, earn points and help others
