Question about Sony Ps-lx50 / Ps-lx50p Stereo Turntable System Service Repair Manual
Ny Sony turntable speed is too slow. Do I need a new belt?
The records were playing and Iwent to put on another record and the speed was too slow. When I put the arm over to begin playing the turntable didn't turn. When I push the turntable manually it will start to turn but the seed is wrong.
  • 3 Answers
Yes you have stretched belt try to replace it.
Posted on Nov 19, 2013
My Rockola Tempo 1, just stopped mid record. Previously the carousel would slow down/hesitate at a certain point when selecting, but never stopped. Switched it on occasionally, with no movement.
I would put money on the belt snapping. 5 years is about right. Especially if you do not use it often. The slow down and hesitate is even more indication of a belt getting hard and then slipping and snapping. They need to keep moving to stay soft. Get a new belt and you will be likely good to go.
Oct 16, 2016 | Wurlitzer Rock-ola Jukebox
My Philco 841205 Turntable spins normally, but
If this is a belt driven turntable then when the arm rests on the record the weight cause the belt to loose traction and slip around. The only cure is a new belt. Make a note of how the belt fits before removing as the biggest problem with belt turntables is knowing how the belt fits. When removed. Measure the diameter of the belt in MM and then the thickness. You won't need to be spot on with the diameter. Put the measurments into Google with the words turntable belt. Get the one that is nearest your measurements.
Sep 16, 2014 | Audio Players & Recorders
Turntable playing too slow
there is a (v.r) for speed in side look for it and turn it a little
Mar 24, 2014 | Technics SL-BD20D Turntable
Crosley Turntable is playing too slow.
try cleaning the motor and oil with a drop of wd40 do not get it on belt
Feb 16, 2014 | Crosley RADIO CR6249-BK DELUXE KEEPSAKE...
My turntable for records is too slow
Yes your belt is stretched try replace it.
Nov 19, 2013 | Washing Machines
How can i fix my jta-460 from playing records slow
Check the RPM switch on the turntable is on the correct speed for the record you want to play. Otherwise it could be a belt problem internally.
Feb 13, 2012 | Jensen JTA460 Turntable
My turn table is going to fast when i play an record , what can i do to fix this? thanks
Hello the turn table has two speeds. 45rpm and 33rpm (rotations per minute) If you are playing a record that takes up the entire turntable you need to set it on 33rpm. For the records that only take up half of the turntable you want to set it on 45rpm. Setting the turntable on the wrong setting for a certain size record can make the record play to fast of to slow.
Mar 24, 2011 | Panasonic Technics SL-BD22D Turntable
Records turning at approximately 33 not 33 1/3. A
If it's not the belt some have speed preset controls which sometimes are found underneath (perhaps covered up) or they are on a pc board inside (accessed by underneathed).
Jul 31, 2010 | Sony PS-LX250H Turntable
Screeching turntable
Try to pin-point where the sreech comes from. You can do this by keeping your ear close to the turntable. Or you can use one of those 'bent' drinking straws to narrow it down, put one end of the straw in your ear and listen. If you find it's metal rubbing together you can use silcone grease on it.
Mar 25, 2010 | Sony PS-LX250H Turntable
Rca record player is playing slowed down or sped up
Hi there
this sounds like the belt that drives the turntable itself is slipping you can normally access it by removing the securing clip by the centre spindle and then lift the turntable up and you should be able to see the belt give the belt a good clean with isopropyl alcohol refit and hey presto (if you still get slippage order a replacement belt )
Rgards Al "Alstech "
May 26, 2009 | RCA 200-Watt 5-CD Compact System Model...
Sony Ps-lx50 / Ps-lx50p Stereo Turntable System Service Repair Manual Logo
145 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
