The display on my insignia NS-C3113 is compleatly black (display's nothing) but still works. How i get it to light back up and show information again? or is there a broghtness setting for that?
    Top Expert:
  • Televison & ... Master
  • 75,311 Answers
Check its back-light inverter board.
Posted on Nov 19, 2013
techman
  • 3130 Answers
SOURCE: Insignia NS-32LCD...Manufactured 2-07
This set should still be under a manufacturers warranty. This set has a board that is very hard to get. Do not let them tell you to wait, or you will wait and not get the set repaired. You need to call and have them repair or have them replace the set before the warranty runs out. If you do you will have a hunk of junk.. Good Luck
Posted on Sep 12, 2007
  • 11 Answers
SOURCE: insignia ns-lcd32
You can download the manuals from the Insignia website at:
http://www.insignia-products.com/c-14-lcd-televisions.aspx
Jerry
Posted on Dec 08, 2008
  • 2336 Answers
SOURCE: Insignia NS-LCD37-09 turns on but no image
If your TV is less then a year old, still under manufacturers warranty. If not under warranty the defective parts could be the power supply or the back light inverter board. Both boards can be replace easily.
The way to know if you have a defective backlight inverter is by shinning a light from a flash light near the screen with the TV on and check in a 45 degrees angle if you have a dark video in the background, if the video is present then you have a backlight board failure. If no video, then is a power supply failure.
I have both boards if you want to buy them.
Let me know if you require further assistance.
Posted on Jan 08, 2009
  • 814 Answers
SOURCE: Insignia 27" lcd tv vertical colored lines across screen.
This television, appears to have had a failure in the mainboard. This is the board that controls the video functions and sound functions. The unit should be taken or sent in to a service center for testing and servicing. The service center will have all the correct service information to determine the problem for you. You can call Insignia customer support at this telephone number 1-877-467-4289. You can also got to the customer support website at www.insignia-products.com. Go to the support section and ask them for help on how to get service for your television. I hope this information helps you with your problem.
Posted on May 23, 2009
SOURCE: Insignia NS-32LCD will not turn on.
Heat the bridge rectifier with a blow dryer and see it turn right on.
Posted on Sep 13, 2009
Insignia TV goes black but heard sound
Check its main supply regulator board [SMPS], and measure the voltage that comes to the back-light inverter board is present or not. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Circuit diagrams of SMPS section of many popular brand devices are given. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Feb 28, 2016 | Insignia Televison & Video
Need manual for my tv,XVA133DLM-080507-01196
Product Support ' Insignia
www.insigniaproducts.com/support.html
Manual, Firmware, Drivers & Product Information. Most of ... For OPEN SOURCE SOFTWARE information refer to the on-screen display on your product. If you ...
[PDF]English - Insignia
www.insigniaproducts.com/.../manuals/NS-55E560A11_11-0573_MAN...
manual, or otherwise listed by an independent laboratory as suitable for your TV. •. Follow all instructions .... NS-55E560A11 Insignia 55" LED-LCD TV, 1080p.
Oct 07, 2015 | Insignia Televison & Video
Led power light comes on but screen will not come on.
"Blinks a few times" implies the TV is flashing a fault code at you. If you can find a service manual for your model, count the number of blinks and look it up in the diagnostics section.
However, the most likely problem is a burned-out electrolytic capacitor in the power supply. These are usually easy to identify visually; the top of the can-shaped capacitor should be flat, but may be bulged out and may have brown or black material leaking from the vent scores. The photo below shows a bad capacitor to the right of a good one; both have black plastic sleeves.
If this is the case, replacement capacitors are relatively cheap. However, you should look for the following criteria in choosing a new part:
>Capacitance (uF): same as the original, or 10% higher if the original value is not available
>Voltage: same or higher
>Temperature: Maximum temperature should be same or higher
>Physical size: should fit in the space occupied by the original; if buying a taller unit, make sure it will fit when the back cover is reinstalled, and make sure the capacitor will not touch heat generating parts such as heat sinks, resistors or large transistors.
>Ripple current: get the highest available without compromising too much on endurance. Ripple current may be specified in mA or A; 1 A = 1000 mA. Sometimes you can get a better rating by going to a higher voltage part, but physical size may be a limitation.
>Endurance: Try to get 8000 hours or better.
I usually use Panasonic FR1 series capacitors, although United Chemi-Con EKZN capacitors are also worth a look. 25351068-tkog3zu3xmxabptjkcidpctj-1-0.jpeg
Jan 02, 2015 | Insignia Solutions Original INSIGNIA TV...
My Insigina flat TV Screen is showing half purple and half black, what can i do to fix this right
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Nov 01, 2014 | Insignia Brand LCD LED TV remote control...
I have an Insignia NS-LCD37 was working perfectly fine, all of a sudden the TV went black, I would turn the TV on and you would get the
Most likely you have a fault in the back light circuit. To verify this, turn on the set, when the screen goes black, take a bright flashlight and shine it on the screen. It may be easier to dim the lights in the room so that you can see the faint image on the screen. If you see the faint image, you indeed have a back light problem. You will need to get a diagnoses performed on the set to track down the problem
Nov 22, 2012 | Insignia NS-LCD37 37 in. LCD TV
Tv wont turn on
does the light stay or blinking and how about the screen display totally black or a white screen. you can see in a dark room if their is a white screen. if totally black screen then with sound the cause is could be bad inverter board or screen back light. if a white screen it was the t-con board not working good.
Oct 04, 2012 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
My Insignia TV has a blue screen with parental cotrol the problem is I don't have a Control to pres display how can I unlock it???? HELP:(
Hello
When an Insignia TV is locked, it keeps you from watching all of your channels by only displaying a black screen. Insignia TVs are locked from a single button command on the remote control, so it is easy for you to lock the TV by accident. Since Insignia TVs can be locked so easily, it's important to know how to undo this command and unlock the TV yourself. So, unlock your Insignia TV with the push of a button and once again enjoy watching your favorite programs.
· Find the lock button on the Insignia remote control. The lock button is located on the third column from the left on the second row from the top of the remote.
·Stand within operating range of the Insignia TV, then aim the remote at the TV's receiver and press the "Lock" button on the remote control.
· Aim the remote at the TV and press the channel buttons to make sure the TV is unlocked. When the TV is locked, it shows a black screen and does not allow you to view anything else. If the screen remains black, press the "Lock" button again. If this doesn't work, change the batteries in the remote and start over at step
OK
Sep 17, 2011 | Insignia NS- 27" TV27 TV
Screen black. Audio works. Not even input display shows in upper corner.
Good day!!! That problemisusually cause of bad inverter board that responsible for the back light...Please try to replace it to end this issue... Thanks for using fixya..
Sep 13, 2011 | Insignia NS-LCD32 LCD TV
Hello, I have an insignia NS-C3113 aftermarket radio in my 1995 Chrysler Sebring. The radio worked fine when I bought the car a couple of months ago and has quit working since. At first the radio began to...
When you say that your stereo was cutting in and out do you mean that the power was cutting in and out or the volume. If the power is cutting out then the problem could be that the stereo is not grounded properly or the positive power is not connected properly. The only way that a fuse will be burnt out is if you short the stereo. If you have a12 volt test light it will come obviously handy to check your power source. A multimeter can also be used. I hope it helps
Oct 03, 2017 | Insignia NSC3113 Car CD MP3 Player
My insignia NS-IPSD4 ipod docking station simply put, wont work. I haven't touched it in a while and it was left unplugged. now it just turns the blue light at the ipod base on and the clock light, but...
Our recommendation is to seek service under the one-year factory warranty. Please return with the unit to the place of purchase to pursue repair options.
Mar 06, 2010 | Insignia Boombox NS-B3112
Televison & Video Logo
Top Televison & Video Experts
