Question about Casa Vieja Turn of the Century Antique Iron Ceiling Fan
I have a turn of the century 52" Viente Ceiling fan model 355-7523 that the high speed setting will not work but all other settings work fine. When I push the button on the remote to activate the high speed setting I can hear a click in the fan but there is no rotation in the blades.
The back of my Turn of the Century fan's remote control has this switch in the back of the battery housing. It's marked with 'D' and 'CFL' on either end. Can someone tell me what this switch means?
The switch is allows you to tell the remote which type of light bulb you have installed in the fixture. The CFL setting is for the included compact fluorescent bulbs. With these bulbs, you can only turn them on and off. If you put in incandescent bulbs, set the remote to D. Then you can dim the lights in the ceiling fan, in addition to turning them on and off with the remote. CFL bulbs can't be dimmed with this fixture.
I found this described in the manual for the Turn of the Century Midori 52" ceiling fan. This fan is available at Menards: https://www.menards.com/main/lighting-ceiling-fans/ceiling-fans/indoor-ceiling-fans/turn-of-the-century-reg-midori-52-contemporary-ceiling-fan/20338/p-1444433460319.htm . The direct link to the manual is currently https://hw.menardc.com/main/items/media/HONGK003/Install_Instruct/3551058-3551059_install.pdf .
I hope this helps.
Apr 01, 2018 | Dryers
My hunter ceiling fan turns very slow
Check your capacitor. If this is an add on remote, set the fan on high with the remote then pull the chain on the fan until you get high speed.
Sep 17, 2014 | Hunter 52" Ceiling Fan With Light And...
Hampton Bay Chateau Deville with remote stuck in high. Remote works fine for light with dimmer, but will not turn off fan or change speed. Stuck on high.
When you had the batteries out of the remote, did you press all the buttons to be sure one is not stuck? Also, this could be a button failure.
Nov 21, 2013 | Hampton Bay Ceiling Fan. Chateau Deville...
I purchased a Turn of the Century 52 inch remote ceiling fan, model 355-6786/6787/6788. After installing it I couldn't get the high speed button on the remote to activate the high speed on the fan. All...
I purchased a 'Turn of the Century-Apollo' model 355-6786 cieling fan. The only problem is no fan blade mounting bolts and nuts, instead I have 2 packs of mounting screws. I've dialed the Customer Service Department to no avail. Is there an unpublished WEB site?
Jun 26, 2010 | Casa Vieja Turn of the Century Antique...
HB ceiling fan is getting slower and slower bi the day
Solid-state controls change the level of power in the fan motor to control the speed of the fan. For instance, when you switch from medium to high on a solid-state fan, the speed control mechanism increases the power of the motor. Solid-state controls are generally equipped in fans with controls that have predetermined settings, such as low, medium and high.
The solid state device in or around the fan motor could be defective and in need of replacement.
https://www.hunker.com/12003281/how-does-a-ceiling-fan-speed-control-work
Dec 07, 2017 | Hampton Bay 52 In. White Redington...
Not working
How old is it? If it is more than a couple of years old, the motor windings for highest speed probably failed. They can not be repaired as cheaply as buying a new fan.
Jul 18, 2008 | Hunter 28096 Westminster 52" Ceiling Fan...
Casa Vieja Turn of the Century Antique Iron Ceiling Fan Logo
316 people viewed this question
Top Casa Vieja Dryers Experts
tsalagi152
Stan Ford
Tom Chichester
Are you a Casa Vieja Dryer Expert? Answer questions, earn points and help others
