Question about Refrigerators
Ice Maker fails on occasions to dump ice before water is dispensed
I have replaced this ice maker once before about 2 years ago. Just replaced it again because it failed to dump water and I assumed that the heating element was bad. It worked fine for about 2 weeks and then the same thing happened. After melting the ice I restarted the ice maker and it worked fine for about a day and then failed to dump the ice before dispensing water again causing it to freeze over. Could the problem be in the controls or sensors or should I replace the ice maker once again? Thanks
  • 103 Answers
Monitor the cycle as it is filling water does it over fill or is there a seepage that continue to drip, it could be the water valve. Also do you hear the tray making noise as it tries to dump the ice "the harvest cycle" try to watch it to see if it is a mechanical gearing problem
Posted on Nov 19, 2013
Testimonial: "When the water is dispensed it fills and shuts off but I have noticed when it freezes over it appears that the water may have slowly leaked out because it mounds up in the dispenser cup. Are you speaking of the inlet water valve?"
5 Suggested Answers
  • 65 Answers
SOURCE: Ice maker stopped working
are the "fingers" of the icemaker pointed toward you and slightly up? if not the icemaker is internally broken . is the red light to the right blinking twice and then a one second pause? if not the emmitter is broken. is the black hose coming from the ceiling blocked with ice ? if so the water vave is broken allowing water to seep in hose and freeze. hope this helps.
Posted on Feb 16, 2008
woodchuck789
  • 4059 Answers
SOURCE: The water dispenser and ice cube maker stopped working
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Posted on Apr 25, 2010
Testimonial: "Wow! I haven't had time to try your suggestions but am very impressed with your very rapid and thorough response. "
SOURCE: What is causing the items in the vegetable bin to
Sounds like the source of your refrigerator freezer temperature problem is due to a faulty evaporator fan motor. This fan circulates the air from the freezer to the refrigerator and back to the freezer. When it fails, temps are warm at the top, cold at the bottom, so the ice melts, and the water tank inside the fridge, near the bottom, freezes. I looked up your model #, but it shows no results so i cannot give you a part number.
Also, its possible if you have a control board microcomputer, its bad as well. Some model GE refrigerators the fan burns out part of the computer, necessitating replacing both.
Posted on Nov 09, 2010
  • 313 Answers
SOURCE: Frigidaire PLHS69EE552 ice maker won't dispense water to make new ice. Water dispenser works fine.
You need to replace the ice maker
Posted on Jul 25, 2012
My icemaker has stopped receiving water
it sounds like your water valve is bad. you have a double water valve - one side operates the ice maker and the other side operates the water dispenser. the ice maker side of the valve is bad.
you can manually pour a little water in the ice maker ice mold and wait an hour or so - if it dumps the ice then you know for sure that the ice maker is cycling and water is not getting to the ice maker from the water valved
May 25, 2010 | GE GSS20IEP Side by Side Refrigerator
No ice.
Pout about 2/3 cup of water into the ice maker . If it dumps but does not refill , replace the water inlet valve ( the piece the wall water line connects to behind the refrig ) . Also check the tube which fills the ice maker as it will freeze up , not letting water go into the ice maker . This is also caused by a bad water valve .
If the ice maker does not dump the water poured into it , replace the ice maker .
Also , check that the coils are clean under the front of the refrig , as this will cause slow ice production and can cause the ice maker not to dump due to too warm of temperature . Ice maker has to be 5 degrees to operate .
May 09, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker makes ice but will not rotate and dump the ice.
You have a thermostatically controlled heat release ice maker. Any number of issues can cause a failure to "dump" the ice. The harvest is started when the thermostat closes. A motor rotates the ejector fingers which are at rest in the 2 o'clock position. The ice maker operation will stall until the heater releases the ice from the mold. After the cubes are ejected into the ice bucket, the water valve will refill the mold with water to begin the next cycle. Lack of ice dispensing could be a failed thermostat, heater, motor or switch contact withing the ice maker module. You could simply replace the ice maker and save the expense of the service call.
Dec 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
Freezer stopped making ice cubes
Pour about 2/3 cup of water into the ice maker . If it dumps , then replace the dual water valve behind the refrig . If it does not dump the frozen cubes , replace the ice maker .
Sep 27, 2009 | GE Refrigerators
Kenmore s/s 106.56536400 ice maker stopped working.
Pour about 2/3 cup of water into ice maker . If it dumps the ice but doesn't refill , replace the dual water inlet valve . If it doesn't dump the cubes , replace the ice maker . Also check to see that the coils under refrig are clean of dust , lint , pet hair , etc. Your water valve , has 2 main solenoids . One for the water dispenser , and , one for the ice maker .
Sep 15, 2009 | Kenmore Refrigerators
No water to the ice maker
The light (receiver) , should light twice , pause , 2 times , pause , and so on . If you close the left flap (emiter) , the light should go off . This is normal operation for the optics .
Check the black tube (fill tube ) , above the ice maker , to be sure it is not iced inside , blocking water flow . If it is , then the water valve needs to be replaced , due to seeping ( not closing completely ) . Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , and the black tube is clear , replace the water valve . If the ice maker does not dump , and the frozen cubes stay in the ice maker , then replace the ice maker . Also , check the coils under the refrig , to make sure they are clean from dust , lint , pet hair , etc .
Sep 12, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water will not dispense to ice maker
The water dispenser in the door of my Kenmore side by side will not work. The ice dispenser does work. What do I need to do to fix it?
Thanks Kel
Sep 06, 2009 | KitchenAid KSCS25FKSS Side by Side...
ICE MAKER NOT GET WATER
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...the temperature(it needs to be 0-4 degree F for the ice maker to start) may be defrost problem send me a note if you need info on that
Aug 24, 2009 | Amana SXD524VW Side by Side Refrigerator
Samsung RS277 ice maker not filling with water but have water through dispenser
Aug 21, 2009 | Samsung Refrigerators
My GE Profile Arctica is not making ice and not dispensing water.
Aug 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
107 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
