Question about Kimball Office Furniture Kimball Skye K29HB, High Back Executive Web Back Office Chair, Headrest
Clip on base holding gas cylinder broke k30aa
Stem goes through base chair tips over
Tip
Tips on buying a highchair
When it comes to buying a high chair for your child there are several factors you must take into consideration including how easy it is to clean, your childs comfort, how to store the high chair (does it fold away), stability and price.
I have two children and for me the most important factor is by far how easily the high chair can be cleaned. I tend to lean towards chairs with machine washable trays. The chair we use is from Fisher Price and is a dream when it comes time to clean up. Here is a link to the product -
http://www.fisher-price.com/en_US/brands/babygear/products/56887
Next you should consider the comfort of your child. Look for a high chair with a cushion/padding on the seat. Your child will be sitting in the high chair for every meal so you should invest in a comfortable chair.
You should also consider ways in which you can store your childs high chair when not in use. If you do not have a lot of extra space, you may want to look for something that can fold up and be stored away.
Stability and safety are extremely crucial factors in selecting a high chair. Look for chairs with a wide base for immovability. I recommend finding a chair with secure waist and middle straps to ensure that your child is properly restrained.
Lastly, you will need to consider price. Find something that incorporates all of these features with your budget.
on Aug 28, 2012 | Baby Gear
How to adjust height.
•This approach can increase the minimum and maximum heights, but only by 1/4 inch or so. 1) Get the cylinder out of the base. (This might not be easy. There are unanswered questions here how to do about this. I might have removed the wheels and then carefully stood on the star, or maybe hammered the cylinder out with a wood 4x4.) 2) Wrap a neat course or two of duct tape around the part of the cylinder that fits into the base. 3) Put the cylinder back into the base. This works because the bottom of the cylinder is tapered. (I invented and tested this fix. The seat wasn't too low, but the bottom of the cylinder was catching the carpet.)
•For a bigger raise you'd need to significantly modify the chair, which is technically demanding and risky. Modifications can fail. A chair made taller will be less stable because the base does not get wider.
•Tall adjustable chairs are sold for use at high counters. They often include foot rests, so that your feet won't dangle.
•If the desk or table wheels that can be removed, it might be easier to make the desk a few inches lower (at the expense of mobility) instead of raising the chair.
Nov 01, 2015 | Furniture
Office chair lowers on its own
It will be one of two things, either the gas strut is no good and in this case you might as well get a new chair. Or the lower lever is stuck in the " lower" position, if this is the case freeing it up should cure your problem
Aug 28, 2013 | Furniture
Replacing wheels on a Basyx office chair
Why not keep it simple? Go on down to your local hardware store with a sample of the wheel assembly and match it up!
Jan 22, 2013 | Basyx Furniture
Broken chair castor
the stem does not come out but u can find @office chir parts.com
Oct 09, 2012 | Calligaris New York Office Chair
I have a power chair by Drive Medical Design & Manufacturing. The chair goes in circles. I have had it in for repair, nothing is found. I get it back and the problem starts all over.
Does your chair have the nine pin connector from the joystick to the rear of the chair? If it does have them replace the main nine pin harness in the base. this harness connects the batteries and the motors and supplies the power to your motors through the joystick. I have found these give the problem you are having yet doesn't give any errors that you might have a bad motor etc Fairly cheap fix harness should cost about $20.00 Hope this helps
May 29, 2011 | Electric Mobility Geo Wheelchair Drive...
I have an electroux converstion kit for a propane clothes dryer. Need instructions.
very simple .... two brass fitting one should be flat with a large hole that goes in burner tube number staped on side of orfice with hole in it lp usually 54 0r 55 natrual gas should be a large hole and bigger number...
and one with a flat screwdriver tip that goes in the top of gas valve without plastic stem is for natural gas '''' ' lp is with a white stem
Feb 03, 2011 | Electrolux Dryers
My Moens One handle tub shower shot out at me and i could not stop the water for nothing what would make it shot out
If it is an older valve there is a small copper retaining clip that holds the cartridge in place. If this clip broke it could blow cartridge out or come out when you pulled it to turn it on.
If that is the trouble you can see the slot in the top of the valve body where the retaining clip goes.You will need to get a new clip and put the cartridge back in and insert clip to hold it. If you find that you have the hot and cold sides reversed simply turn the stem of the cartridge 180 degrees and you should be in business. Thank you
Jan 02, 2011 | Moen & One Handle Tub & Shower Faucet
Can I or how can if possible return the Pride Lift Chair to normal seating position manually.Thank you.btrapp@sasktel.net
The easiest way to do this is to tip the chair forward so that the top of the chair and the arms are on the floor. The weight of the chair will be off the lift frame in this position. Look at the motor and you will see it connected to the frame with 2 hitch pins.
It is easiest to remove the top hitch pin which will now be on the bottom because the chair is upside down. Pull the clip (looks like half of a paper clip) from the pin that goes through the square chair frame and motor round tube. Pull out the pin by lifting the bottom of the motor slightly(now at the top because the chair is upside down)with your left hand and pulling the pin out with your right hand. Find the two nylon washers that have fallen out when you do this.
Swing the motor tube out of the way toward the front of the chair. Hold on to the pin, clip, and 2 nylon washers for re-assembly. Hope this helps.
Dec 26, 2010 | Pride Mobility Products Casual CL30KD Lift...
Kimball Office Furniture Kimball Skye K29HB, High Back Executive Web Back Office Chair, Headrest Logo
46 people viewed this question
Top Kimball Office Furniture Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Kimball Office Furniture Furniture Expert? Answer questions, earn points and help others
