Question about Maytag Bravos XL High-Efficiency Electric Dryer
Bravos XL High-Efficiency Electric Dryer dashes
4 Suggested Answers
SOURCE: ''AF'' error on Maytag Bravos dryer
"AF" means "Air Flow". Your vents are cloged with lint. I have had to vaccum out my vents several times, both inside and out. It's been a bit of a pain.
Posted on Dec 27, 2009
carmin77
  • 113 Answers
SOURCE: Does this Maytag Bravos electric dryer require
Assuming that your house is wired correctly, if the plug will physically fit into the outlet, then the outlet is capable of driving the appliance properly. A breaker for a dryer should be rated at 30 amperes. The breaker itself could be going bad (they tend to fail to the off position).
Your best bet is to actually use an amp meter to measure the current it draws.
If you discover that someone wired your dryer with a 2 pole 20 amp breaker, then make sure the wire itself is 10 AWG before replacing it with a 2 pole 30.
:o)
Posted on Jun 03, 2011
  • 1010 Answers
SOURCE: bravos xl dryer hot to touch on exterior but not warm inside
You still have warranty, call them to fix it
Posted on Mar 29, 2013
I have a Bravos XL dryer < than 1 year old. Suddenly it stopped running & the LEDs all went out. There is power at the 250 v outlet but no panel lights or drum light. I am not sure where to start.
Hi Larry
A small cheap MultiMeter would assist here
Allowing you to trouble shoot to where power is lost.
Probe & aligator clip to Neutral or ground
& probe for 240v ac
Caution is essential near we floors
Would also be nice to have a RCD in your meter box for shock protection (ground to active phase)
....unless you've got a heart like horse!
or a portable one plugged in at the wall.
It will only save you from ground to active phase shock
not phase to neutral.
Better safe than sorry
How to Use Multimeter
THE BEST Multimeter tutorial HD
http://www.jaycar.com.au/Test-%26-Measurement/Multimeters
Mar 13, 2016 | Maytag Bravos XL High-Efficiency Electric...
Which way does the drum turn? Changed the cord and it is turning counter clockwise is that correct?
If your cord looks like this, you should be ok. The other end is also pre-manufactured and cannot be installed incorrectly. It is important that the ground connection (green wire) is connected correctly and it is tight.
Jul 16, 2015 | Maytag MEDB850YW Bravos XL High-Efficiency...
Washer drain pump continually runs even with power off.
have a technician check the power board as the pump power is not terminating when the machine switches off.
Jun 27, 2015 | Maytag Bravos XL 4.6 cu. ft....
How long should it take to run a clean washing cycle
On the high efficiency machines it takes longer, because of the amount of water used. It takes a few more cycles to complete.
Mar 04, 2015 | Maytag Bravos XL High-Efficiency Electric...
How to stop out of balance with blanket?
1large item like blanket or duvet will knock drum balance out. Bad for bearings .
Aug 09, 2014 | Maytag Bravos XL 4.6 cu. ft. Top-Load...
Replacing pulley on Blower Housing
If there is no access panel on lower right side behind machine, you will have to lift the top of the machine from the front and remove the front panel to access the inside of the machine. While there it would be a good idea to check out the drum rollers if present and drum glides for wear. Also make sure that the blower wheel is not loose on the motor shaft. All of these will cause noise issues and are common.
Jul 31, 2013 | Maytag Bravos XL High-Efficiency Electric...
Maytag Bravos XL High-Efficiency Electric Dryer Logo
14 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
