Question about Bucilla 18" Felt Applique Christmas Stocking Kit - HOLIDAY DECORATING 86146
I need step by step directions for this stocking project
I need step by step instructions for this stocking kit. What to cut, what to stitch on what, what color thread to use, ect.
    Problem Solver:
  • 8 Answers
Try contacting Bucilla directly. Tell them which item number or send a picture and they should be able to help you.
Posted on Apr 23, 2014
Very blurry at top and bottom.
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop
Dec 05, 2010 | RCA D52W19 52" Rear Projection Television
Tip
Setting Timing Without 3 So Called SPECIAL TOOLS Needed
1997-2000 Ford Contour 2.0L DOHC Camshaft Set up For timing Belt Replacement.most Instructions Call For 3 Different Special Tools No NeedFORD UPGRADED TIMING PULLEYS AND TENTIONERS In a UPGRADE KIT
Remove Valve Cover And TOP Timing Belt Cover CUT BELT OFF, Go to Rear of CAMSHAFTS (OppositeSPROCKETS) Look and you will see SLOTS at the end of Each CAM they are CUT ECCENTRICALLY . Use a Piece of Sturdy FLAT STOCK HARD STEAL (STRAIGHT) Turn CAMS one at a TIME Until they are EVEN With COVER GASKET SURFACE of Head, ALIGN BOTH Cams this Way Insert FLAT STOCK IN SLOTS So CAMS Don't Spring Back, And you Have VALVE TRAIN TIMED PERFECTLY, #1 Spark Plug OUT Bar Over to TDC WOODRUF KEY Should be Pointed Straight UP. This Is ALL there is to IT. Proceed with Timing Cover Removals and front Mount, REPLACE ALL PULLEYS AS A KIT (SOLD AS KIT) Install Timing Belt Set Tensioner According to KIT Instructions ans this will Illuminate All Special Tools SAID to be NEEDED for this Procedure, (( REMOVE FLAT STOCK AT CAMSHAFT ENDS AFTER BELT IS TIGHTENED.Install New Valve Cover Gasket #1 Spark Plug and Job is Done. Cuts 1 Hour 15 Minutes off Flat Rate
on Dec 31, 2009 | Ford Contour Cars & Trucks
INSTALLATION
Yes from crutchfeid yo can get mounting kit and harness adaptor with instructions. with the harness adaptor you don't need to cut up your wiring. it plugs into the cars existing plugs.
Mar 27, 2010 | Kenwood Car Audio & Video
I have a TV 48" PTV W/RemoteModel 6P4830W TV repair said that it
The problem is not in the bulb but in the display coolant... http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits...The step by step procedures and illustrations are included in the kit.
Sep 25, 2009 | Philips Magnavox 9P6034C 60" Rear...
Color
you need to install a convergence repair kit which should take care of that issue. Heres a link to the repair kit for your model. The kit contains the parts and step by step instructions on how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/av48wp30-convergence-repair-kit/cName/convergence-repair-kits
Jul 05, 2009 | JVC AV-56WP30 56" Rear Projection...
Convergence problem that won't correct itself with the convergence menu.
You can get the convergence repair kit at the following link which contains the parts and step by step detailed instructions. The DPTV305-DOTV345 phillips convergence kit is the one you need listed under the phillips repair kits.
http://www.tvrepairkits.net/home
Jun 25, 2009 | Philips Magnavox 9P6034C 60" Rear...
Stanby timer light blinking
you need the V26 DM kit which will usually cure that issue. Its chaep and contains the Replacement capacitors and step by step instructions. Heres a link to the correct kit.
http://servicemanuals.vstore.ca/product_info.php/pName/v26-dlp-dm-pwb-repair-kit/cName/repair-kits
Jun 20, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Dear Sir I am looking for a step by step instruction booklet for the use of fred carbide router bits door system model 94-100 Paul
The bit set you're   is for the purpose of making cabinet doors, cabinet pulls and door pulls.  It's a great little system from a good company. Unfortunately, it's intended to be used by people who have routed before.  I don't know what your experience level is  this stuff but you have several different types of bits there.  You're not going to find step by step instruction on this kit, but what you can find is instructions for the different "type" of bits.  For example, the kit includes a 99-510, which is a raided panel bit.  Do a search for that.  Freud won't give a step by step on that kit, but the styles (not stiles) they offer are universal.  Also, here's 2 good resources.  A picture's worth a thousand words and I think some of the illustrations will help.  Remember, test your cuts on scrap stock, don't waste the good material.  Happy routing  http://www.newwoodworker.com/bldraspnldors.html
http://www.binkyswoodworking.com/RaisedPanelDoor.html
Apr 09, 2009 | Tools & Hardware - Others
Bucilla 18" Felt Applique Christmas Stocking Kit - HOLIDAY DECORATING 86146 Logo
718 people viewed this question
Top Bucilla Home Experts
Donni Steen
Tom Chichester
Are you a Bucilla Home Expert? Answer questions, earn points and help others
