Question about Miller Trailblazer 325 EFI Welder 907512
Have a hard time holding a arc welding down hand it sputter really bad was wondering if the machine just does'nt like welding down hand or could it be bad brushes the machine only has 650 hours on it
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 207 Answers
Replace the brushes.
Posted on Nov 19, 2013
2 Suggested Answers
rwooley
  • 100 Answers
SOURCE: No arc on my miller trailblazer pro350
There are two sources of power for the exciter circuit on this machine. The main one takes output power from the generator then goes through the voltage regulator back to the rotating field to continue the cycle of generating. The regulator varies the power back to the rotating field to keep the output steady and correct. The other circuit provides power to the rotating field while you are starting the engine. This starts the loop. It is similar to flashing the fiels on old cars that had generators.
It power from the starting cycle portion seems to be working. This tells me the rotating field, the brushes and the main winding is all good. The problem is most likely the voltage regulator or associated wiring. There are people who repair and return these as they seem to give quite a bit of trouble. If you google the part number of the circuit board, you will probably find a few of these folks happy to repair your board. I have repaired a few myself as it is almost always the same components that fail. Dust,dirt and moisture seem to build up and cause the fault.
I hope this helps. Robert
Posted on Jan 14, 2012
I need tips for my stud welding gun. How can I replace them? Thanks John
https://studweldprod.com/
Stud Welder - Stud Welding Equipment, Gun - Stud Welders Machine
www.eastwood.com > Welding & Fab
  1. Cached
  2. Similar
Stud welding makes more sense. Our stud welder systems each have a stud gun welder that spot-welds a series of pins onto the surface of the dented metal.
What is Stud Welding? ' Sunbelt Stud Welding
www.sunbeltstudwelding.com/studwelding.htm
  1. Cached
  2. Similar
Weld studs come in a variety of designs, threaded, unthreaded, tapped, etc., ... The welding gun is activated and the fastener is welded in a fraction of a second.
Stud Welding Machines and Equipment ' Red-D-Arc Welderentals
www.red-d-arc.com/rental-equipment-subcategories.aspx?sub_cat=180
  1. Cached
  2. Similar
Red-D-Arc offers a range of fully regulated, user-friendly stud welders, stud welding machines and equipment available in single or dual gun versions and ...
Jan 30, 2017 | Welding Tools
Tip
Sharpening electrodes when tig welding in DC
Use the smallest tungsten possible, ie 1/16" welds up to 115amps. Hold the tungsten straight up the face of the grinding wheel so the striations go up the tungsten. This encourages the arc to go straight down the electrode thus avoiding arc wonder on lower amperages. It also helps to make the point as long as possible to encourage a finer arc. Happy welding.
on Feb 06, 2012 | Bobcat Miller 225 Welder Generator 907209...
What mig gun is on a Nevada 220BZ Mig Welder
Nevada MIG-220BZ MIG TIG MMA ARC DC Inverter Welder ...
www.ebay.com.au > Industrial > Welding > Welders
eBayNevada MIG-220BZ MIG TIG MMA ARC DC Inverter Welder Welding ... Nevada Welding machine; MIG Torch; Earth Clamp; Electrode Holder; Safety Mask ..
Dec 20, 2015 | Welding Tools
Craftsman 100ac infinant amp arc welder just stopped working ....the fan still runs. anybody know what's wrong with it????
probably over heated and blew the reset button
100 amp welders have a duty cycle ( time in actual welding use ) of less than 20%
that means for welding for five minutes you have to let it cool down for 20 minutes
the lower the amps the longer you can weld for
beware tat the total amperage of the welder does not mean that you can weld for a long time at that amperage
on the plate on the welder is the duty cycle and you have to be aware of it or the machine will shut down
Apr 18, 2015 | Craftsman Welding Tools
When my miller 325 efi starts to heat up, it tends to shut it self off. the techs say that its running low on oil. But this has been going on one month after I bought it. Can't trust this machine any more....
I had the same problem. I replaced the fuel module with no result. I then replaced the fuel pump with no result. I then insulated the fuel lines. I determined the fuel was vaporizing in the line. By the time it reached the pump it was vapor. Helping it now and the cooler weather is helping too. Hope this helps. My tech buddy said it has had a module issue.
Aug 03, 2013 | Miller Trailblazer 325 EFI Welder 907512
My bobcat 225g runs full bore all the time, I thought it would idle then when you strike an arc it would pick up speed,
A welder does not speed up when an arc is struck. It is normal for a gas welder to stay at a high rpm. If it did not, it would be very hard on the machine as a high amperage is needed to start an arc for welding, and to be consistant. Unlike a generator which will "idle down" when not in use.
Aug 21, 2010 | Garden
My tig welder wont arc unless I touch the metal with it
my guess would be the type of welding machine you have.usually there is extra switch which says start control also continious cycle , sometimes smaller machines dont have these switches to allow a wider variety of tweeking the welder ,also its ok if you have to touch the base metal cause thats what starts the contact with the work peice ,keep a arc after touching about 1/4 inch away from work peice ,also a good steady hand rest will make a good welder in any situation this should allow the arc to remaim stable with a comntinious weld arc puddle. happy welding
May 22, 2010 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
My Lincoln SA 200 welder will not rev up when I strike an arc.
Need code number to be exact, but sounds like the wiring to the current transformer is incorrect.
Sep 17, 2009 | Lincoln Welding Tools
Miller Trailblazer 325 EFI Welder 907512 Logo
478 people viewed this question
Top Miller Electrical Supplies Experts
Craig Butler
Craig Butler
janman
Lawrence Oravetz
Are you a Miller Electrical Supply Expert? Answer questions, earn points and help others
