Question about Moen Two handle Polished Chrome Kitchen Faucet
How do i adjust the flow rate - Moen Two handle Polished Chrome Kitchen Faucet
  • 2,113 Answers
You can swap out the aerator of any faucet with one of your choice in gallons per minute or liters per minute
Posted on Nov 19, 2013
Flow rate of device below flow rate needed to turn on unit out in spite of screw adjustment
you are in the chainsaw catagory and you talk of flow rates screw adjustments
could you post again explaining exactly what the problem is and what it affects
Dec 20, 2016 | Garden
Are there any water pumps with an adjustable flow rate?
Yes there are many water pumps with an adjustable flow rate (GPH) if you want to relocate the water pump in different aquariums. You should visit http://www.allpondsolutions.co.uk and look under adjustable water pumps.
Aug 09, 2012 | Fish
Flow rate on delta thermostatic valve
the two screws are service stops open them all the way
Jun 09, 2012 | Delta & Single Handle Shower Faucet
Water is hot until you adjust the shower temperature to warm from hot, then heat unit shuts off and it is 100% cold. Shower head is low flow so wonder if the flow is below minimum for heater to fire?? Can...
These unit is design to operate at a specific flow rate and cannot be ajusted if you need to have a warm shower you will need to get a bath remote where you can turn down the temp whenever you need without disrupting the flow rate
Jul 21, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Need flow rate and pressure adjustment proceedure for an old raypack 266 not electronic.thanks murray
The maximum flow rate for that heater to be installed in without a bypass is 125 GPM. The owner's manual can guide you thru gas pressure adjustments or adjusting the set point of the water pressure switch. Please note that unless you are installing the unit below or significantly above the water line you should not have to adjust the pressure switch. Whenever you do adjust it, be certain to turn the pump on and off several times to be certain the heater reacts to the pump condition...failure to shut down when the pump does can be a serious and dangerous condition.
Dec 15, 2009 | Raypak Millivolt Gas Pool Heater 266,000...
How do i adjust the flow rate (zero piont
the flow rate is adjusted by the dial on the spreader the higher the number the bigger the flow opening will be.
Dec 14, 2009 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
I have constant air pressure out of hvlp nozzle without pulling handle
have you tried to adjust the air regulator on the rear of the gun! there should be two adjusters, one to adjust the paint flow rate and the other to adjust the air flow rate! if you have tried this then the rubber sealer has perished inside the gun! unscrew the controller and replace the seals!
kind regards
Oct 20, 2009 | DeVilbiss Air Tools & Compressors
When i turn on the cold water to adjust the temperature of water - the hot water turns completly off. I cannot turn on the cold water at all. It is either all hot water or all cold.
It might be a question of inadequate flow. All tankless water heaters have a minimum flow rate that must be met, typically .5-.9 gpm, before the heater will operate. In the summer time the incoming ground water temperature is higher, causing you to mix more cold water and less hot water to get a lukewarm temperature. This can reduce your flow rate near or below the minimum flow rate.
Here's a test for you, try running running a sink while taking your next shower. If the hot water remains mostly constant throughout, then your problem is with flow at the showerhead. The flow at a shower head can be reduced by buildup of scale and sediment. Also all showerheads have a flow restrictor that limits flow to 2.5gpm (some even less). Removing the restrictor will increase the showerhead flow rate as well.
Also look for any error code displayed on the digital read out of the heater. Some heaters will flash on their burner indicate light as well.
Aug 17, 2009 | Water Heaters
Increasing water flow rate
With a flat head screw head driver adjust the pump pressure. The screw is on the left side of the image below.
Sep 13, 2008 | Coffee Makers & Espresso Machines
Moen Two handle Polished Chrome Kitchen Faucet Logo
48 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
