Question about Philips Magnavox 51MP392H Rear Projection Television
Philips Magnavox 51MP392H Rear Projection TV
After powering down the set on night everything was fine. The next morning when powering up the set the convergenge was off(distorted) on the red multipoint. On the red convergence:can adjust horizontal but not vertical. blue convergence works fine. Occasionally it will flip into perfect picture, then it goes back to distortion. At this point Have done nothing inside the unit... Thanks, Deano
    Genius:
  • 1,153 Answers
A sign that amps are going bad, right now you can check resistors in convergence board alongside the amps, check resistance to see if right.
Posted on Oct 08, 2007
SOURCE:
Philips magnavox,9p5040c102 tv has power but no pic or sound, what is wrong, worked fine yesterday
I have same problem with mine, the power button turns red (as usual) but no picture. When i turned mine on last night it made a crackle noise and thats how it all started. I can even hear the normal sounds it makes as if it were turning on, but still no picture. Its a great tv I would hate to throw away. I want to fix it myself any help would be appreciated!
Aug 21, 2011 | Philips Magnavox 51MP392H Rear Projection...
Tv wont turn on just chirps
The power supply in these sets will chirp if there is a short on the secondary side. I would start with the horizontal output transistor. It is really hard to say because everything in the set is run off of this power supply. It would be best to have a technician check this out for you. Thanks for using fixya.
Dec 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
Picture has red and blue shadow images
thats a fairly easy fix. You need the DPTV305-DPTV345 convergence repair kit available at the following link.
http://servicemanuals.vstore.ca/
The kit contains the parts and the CD with instructions
Sep 29, 2009 | Philips Magnavox 51MP392H Rear Projection...
I have a Magnovox HD TV Progressive Scan (Floor Model) TV
You can find a replacement Philips/Magnavox fresnel screen, in stock, for this model (51MP392H/17) at this following link from a major parts distributor:
Philips / Magnavox 51MP392H Replacement Part Fresnel Screen
And here's a link for the Lenticular (middle) Screen, if needed:
Philips / Magnavox 51MP392H Replacement Part Lenticular Screen
Jan 16, 2009 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox Rear Projection 51mp392h convergence resistors
This means you do have some bad resistors low ohms 2.7 most of the time its only 2 of them depends on how long you played set before replacing STKs .
Oct 27, 2008 | Philips Magnavox 51MP392H Rear Projection...
No power to tv
power supply or power supply relay
Sep 16, 2008 | Philips Magnavox 51MP392H Rear Projection...
51MP392H rear projection - flashing on/off button
Power light but no audio/video is fairly common problem. Goto www.magnavoxhelp.com to see if they have a repair kit for your model.
Oct 11, 2007 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 51mp392h rear projection tv
The horizontal *forgot the name, want to say synchronizer, but i know thats not it* is going bad. Will cost about $400 to fix. Time to get a new TV.
Aug 29, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
158 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
