Question about Treadmill Doctor Exercise & Fitness
Have all power every think is on but no sound of the motor working and the blet too
I have five discs in there. The drawer won't open. I can hear whirring noise.
You can try unplugging the unit and waiting a few minutes and then replug and reboot the player. If it still does not work you might want to check the eject mechanism for operation. Maybe a blet slipped off a pulley?
Apr 06, 2015 | Audio Players & Recorders
Roller not turning already tried a new blet?
Take the roller brush out and make sure it turns freely on the end pieces that hold it in place. Clean both ends and hit with a bit of WD40. Remove hair, string, dust, dirt. Make sure the belt is oriented properly and it is properly connected to the motor shaft. AND, is the motor shaft that operates the brush turning?
Aug 28, 2010 | Halo UVST Bagged Upright Vacuum
A/C is Not blowing cold air
Even though the Compressor is engaging it doesn't mean the Compressor is working internally. I would have the Compressor tested to determine if it is working properly.
Jun 05, 2010 | 2005 Mitsubishi Outlander
My belt on my 98 galnt is makeing a a loud noise my pulles look fine but my motor mounts are out do you think because of my mounts the blets are off tune ?
One of your pulleys most likely the idler pulley is shot, the noise is the bearing going bad in it after so many years.
May 17, 2010 | 1997 Mitsubishi Galant
Reset blet button will not stay down. what does
Your rest should only be required once if the head stops. If it continues to shut off , you likely have hair or thread wound around the brush in the bearings or a motor which needs to be cleaned and lubricated.Try rolling the brush by hand if it is tight it needs service.
Most of these heads have a headlite housing which pops off to reveal two hidden screws. remove those and look for others near the neck of the head Once removed the housing lid comes off to allow access to the brush. remove the brush but be careful not to lose any spacer washers on the ends, Clean out any hair and thread and invert the belt to inspect if it has teeth , look for cracks or missing teeth. rotate the motor drive with your fingers. it should spin freely . If it is tight or grinds or scratchs you need to have it serviced or replaced. If the shaft feels tight 1 DROP of sewing machine oil or WD 40 on each end of the shaft will help, but clean out any dust first. the reassemble in reverse order.
Sep 16, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
May 28, 2009 | Reebok Vista Treadmill - RBTL13305
How to put a new timing blet on a 1993 honda accord LX 2.2 L
well chances are you now have bent valves , if you bought the car with a bad timing belt then most likely the valves are bent since that motor is an interference engine.
Feb 08, 2009 | 1993 Honda Accord
Dryer will not start
IT SOUNDS AS THOUGH YOUR MOTOR HAS LOCKED UP AND FAILED. THE BURNING SMELL IS THE VARNISH FROM THE WINDINGS OF THE MOTOR. REPLACE THE MOTOR. THEY CAN BE HAD FOR AROUND EIGHTY DOLLARS
Jan 27, 2009 | Whirlpool LER5636P Electric Dryer
Amana washer not agitating and does not spin all the time
"Its not spinning well" that means it is spinning but at a relatively low speed .....if this is so try having the motor serviced.....or replaced.......also have the capacitor checked...
Nov 10, 2008 | Maytag PAV2300 Top Load Washer
Changing
Remove top cover and lower rear panel.
Tilt m/c towards you and put belt over motor pulley and slowly force belt round drum pulley turning the pulley at the same time.
Watch your fingers, it is very tight, but persevere!!!
Sep 15, 2008 | Hotpoint First Edition WMA12 Front Load...
Exercise & Fitness Logo
Top Treadmill Doctor Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
fordexpert
Are you a Treadmill Doctor Exercise and Fitnes Expert? Answer questions, earn points and help others
